Line Breakpoint problems again ... [message #221239] |
Thu, 12 July 2007 22:41 |
Originally posted by: jadnohra.gmail.com
I have a problem with the debugger,
when i debug my one file test program the source file is succefully found
(I know this because the source file is opened and the line with
'main' is highlighted as the current line).
but stepping one step steps over the whole code directly to the end of
the main function.
Although the source file is found ... the lines are not found. I Set
breakpoints on some lines
and I get in the console in 'Red'
(gdb)
358-break-insert nest.cpp:6
&"No line 6 in file \"../src/nest/nest.cpp\".\n"
No line 6 in file "../src/nest/nest.cpp".
No line 4 in file "../src/nest/nest.cpp".
No line 3 in file "../src/nest/nest.cpp".
358^error,msg="No line 6 in file \"../src/nest/nest.cpp\"."
any ideas??
Thank you!
FUDForum. Page generated in 0.08108 seconds
