PROPERTIES OF COMPONENTS [message #21521] |
Thu, 12 February 2009 10:38  |
I want to know if there is some way to access any component properties.
For example:If I have got a Button and I want to know its 'Id'.
This is important because if you are testing an application the button
text may change, but the Id button will not change. If you use
bot.buttonWithLabel(label), itŽs possible that this action is outdated but
if we use bot.buttonWithId(Id), we will not have problems.
Thanks and regards.
Luis Miguel
Re: PROPERTIES OF COMPONENTS [message #23102 is a reply to message #23059] |
Thu, 19 February 2009 12:30   |
Yes, developers need to setData on components when they create it.
If you need to set components as an swtbot user, then you already have
the component and setting IDs don't have much value.
One recommendation is to keep use of IDs to a minimum, because they do
get in the way of readability because there's no way to figure out what
widget the ID corresponds to.
SWTBot provides for a far richer API to access widgets and you can find
widgets using regexes, text, within groups, with labels, or a
combination of these.
Look at one of the methods with the SWTBot class to see how matchers are
used, I suspect that you can probably do away with matchers than IDs.
-- Ketan
Luis Miguel wrote:
> I can not use these
> methods:org.eclipse.swt.widgets.Widget.setData(String key, Object
> value). What version of SWTBot have you got? Or this method is used by
> developers when they create the component?
> Can I set my own key with this method? For example, I have an
> application with two inputtexts and a button... If I want to identify
> the second input with a unique way, Can I use this method?
> Is there any snnipet about this?
> Thanks again.
> Luis Miguel
FUDForum. Page generated in 0.28277 seconds
