| build path [message #221068] |
Fri, 02 April 2004 16:28  |
Originally posted by: Lamont_Gilbert.rigidsoftware.com
Is it possible to build in some location which is not a subdirectory of
the project folder? I can probably do this on Linux with a symbolic
link, but is their a way on windows?
I have my code on a flash memory device, but since flash has limited
life, I don't want my output to be there as well.
I could not find any options to allow this, have I overlooked them?
Respectfully,
CL Gilbert
"Verily, verily, I say unto you, He that entereth not by the door() into
the sheepfold{}, but climbeth up some other *way, the same is a thief
and a robber." John 10:1
GnuPG Key Fingerprint:
82A6 8893 C2A1 F64E A9AD 19AE 55B2 4CD7 80D2 0A2D
For a free Java interface to Freechess.org see
http://www.rigidsoftware.com/Chess/chess.html
| Re: build path [message #221127 is a reply to message #221068] |
Fri, 02 April 2004 16:49  |
Originally posted by: news-reply-200403.iclipse.org
In the package explorer, select your project, use the context menu
'New > Folder'. In the 'New folder' dialog, enter some name and select
'Advanced >>', click 'Link to folder in the file system' and browse
the actual output folder to use. Click 'Finish'. Then, in the project
properties, you can use the virtual folder as the output folder which
will output to the actual output folder you wanted to use.
Or just use an Ant builder :)
Igor
FUDForum. Page generated in 0.04344 seconds
