Home » Eclipse Projects » Subversive » it's too easy to lose history!!!
it's too easy to lose history!!! [message #21492] Thu, 19 June 2008 10:57 Go to next message
Deleting a file and adding it back will create a new file - with a
fresh history, example:
in eclipse, take any file (whose history you do not care about) under svn;
using the navigator/project explorer
right click copy and paste (so you have another copy of it)
delete the original
rename the copy as the original
checkin
history is gone
I do not know if this is an SVN client bug or an as-designed feature,
however it is very easy to lose the history of a file.
is there a way to restore it ?
or a setting to checkin a file that underwent such lifecycle not as new
but as a new version ?
Edoardo
Re: it's too easy to lose history!!! [message #21507 is a reply to message #21492] Thu, 19 June 2008 23:58 Go to previous messageGo to next message
Hi Edoardo,
Yes this behavior is very painful.
I had the same remarks few days ago and it seems to be well-known from
the development team.
One way to avoid this is to do the copy/paste directly in Windows
Explorer or MacOS Finder. If you modify the files and then refresh your
Eclipse view, Subversive will consider the file as 'modified' and not
'replaced'.
Francois
Edoardo Comar wrote:
> Deleting a file and adding it back will create a new file - with a fresh
> history, example:
> delete the original
> checkin
> history is gone
> Edoardo
Re: it's too easy to lose history!!! [message #21529 is a reply to message #21507] Fri, 20 June 2008 00:04 Go to previous messageGo to next message
Hi both,
maybe this is related to my thread "Copy/Past should have svn copy functionality" above.
Cheers, Jörg
On 06/20/08 05:58, Francois Cottet wrote:
> Hi Edoardo,
> 'replaced'.
> Francois
>> svn;
>> delete the original
>> checkin
>> history is gone
>> new but as a new version ?
>> Edoardo
Re: it's too easy to lose history!!! [message #21755 is a reply to message #21529] Fri, 20 June 2008 05:55 Go to previous messageGo to next message
I entered
https://bugs.eclipse.org/bugs/show_bug.cgi?id=237899
Jörg Thönnes wrote:
> Hi both,
> Cheers, Jörg
>> Hi Edoardo,
>> 'replaced'.
>> Regards,
>> Francois
>>> svn;
>>> delete the original
>>> checkin
>>> history is gone
>>> Edoardo
Re: it's too easy to lose history!!! [message #21800 is a reply to message #21492] Fri, 20 June 2008 11:18 Go to previous message
Originally posted by: alexander.gurov.polarion.org
Hello Edoardo,
This is standard Subversion behaviour: when you manually deleted file then
added a new one Subversion performs a file replacement. Subversive shows
this situation in commit window using "Replaced" status string.
Next moment is that when you perform copy/paste inside Eclipse IDE the
file is deleted by Eclipse first and then copied. Though the Eclipse
behaviour looks strange we can do nothing.
Regarding history loosing - you simply missed one moment :) Yes, replaced
file is a new repository element from the Subversion point of view and
Subversion does not connect it with history of a previous element with the
same name. But Subversion also tracks folder changes. So, you can access
required history by performing few steps:
1) Get the parent folder history
2) Find revision before file replacement
3) Get the history of required file using Affected Paths view.
Previous Topic:svn:needs-lock property?!
Next Topic:Polarion! Broken Update Site and No Access to Working Versions
Current Time: Tue Jul 22 12:03:59 EDT 2025
Powered by FUDForum. Page generated in 0.03798 seconds
