Home » Language IDEs » Java Development Tools (JDT) » 2.2 and JDT AST
2.2 and JDT AST [message #1812] |
Tue, 22 April 2003 13:02  |
Originally posted by: vranganath.cox.net
Following is the list of items proposed in Eclipse 2.2 concerning JDT.
Since, I plan to work on a project heavily based on JDT. In particular,
the Java language and the representation of a Java program in memory
(AST). Is there any resolution as far as bullets 1 and 4 are
concerned? I am asking this as I see the development cycle with release
artifacts has started for v2.2. Also, could somebody elalorate the last
bullet? How rich/powerful will the Refactoring API be? What sort of
operations will it support to change/alter the AST?
Proposed Items (Eclipse JDT subproject)
*Add early support for J2SE 1.5 features.* The next feature release
of J2SE is version 1.5 ("Tiger"), targeted to ship in the first half
of 2004. While the contents of this release are still under
discussion (JSR-176 <http://jcp.org/en/jsr/detail?id=176>), this
release is expected to contain extensions to the Java language,
including generic types (JSR-014
<http://jcp.org/en/jsr/detail?id=014>), enumerations, autoboxing,
enhanced for loops, static imports (all JSR-201
<http://jcp.org/en/jsr/detail?id=201>), metadata facility (JSR-175
<http://jcp.org/en/jsr/detail?id=175>), and compiler APIs (JSR-199
<http://jcp.org/en/jsr/detail?id=199>). Supporting these new
language and compiler features will require major changes to the
Eclipse Java compiler, JDT Core APIs, and JDT UI. Although Eclipse
2.2 will likely ship before J2SE 1.5 does, Eclipse should contain
early support for J2SE 1.5 features wherever possible [JDT Core, JDT
UI, JDT Debug]
( new) *Improve support for Java-like source files.* JSP and JSQL
are two instances of languages that embed passages of Java language
code. Eclipse should provide better support for Java-like source
files. For instance, outline views should be able to show the
hierarchy of Java elements; it should be possible to index these
files so that Java search can find the Java declarations and
references within; it should be possible to use Java code assist on
the Java passages; refactoring should be able to take these files
into account; the debugger should be able to step through the Java
passages (JSR-045 <http://jcp.org/en/jsr/detail?id=045>); error
highlighting should be supported across sections; etc. [JDT Core,
JDT UI, JDT Debug]
( new) *Support Java references from non-Java files.* References to
Java elements in particular classes can show up in specific kinds of
non-Java files, such as plug-in manifest files (plugin.xml). These
references should also participate in Java operations like search,
move, rename, and other refactoring operations. JDT will surface
APIs that enable other plug-ins to contribute to and participate in
these operations. [JDT Core, JDT UI, JDT Debug]
( new) *Harmonize Java source manipulation.* The Java model is
currently implemented in terms of JDOM, an early precursor of the
AST facility added in 2.0. JDT will move to an AST- based
implementation of the Java model, and deprecate JDOM. [JDT Core]
( new) *Present **logical view of Java objects in debugger.* The
current debugger always presents the internal structure of Java
objects. For instances of standard data structures like
java.util.HashMap, the Java debugger should be able to present a
higher level logical view of the object (i.e., to show it as a table
of key-to value mappings). [JDT Debug]
( new) *Provide API for refactoring**.* JDT should allow other
plug-ins to contribute specialized refactoring operations, and
provide the infrastructure to make it possible for them to do so.
[JDT Core, JDT UI]
waiting for reply,
Venkatesh Prasad Ranganath,
Dept. Computing and Information Science,
Kansas State University, US.
web: http://www.cis.ksu.edu/~rvprasad
Re: 2.2 and JDT AST [message #2665 is a reply to message #1812] |
Wed, 23 April 2003 13:38   |
See my comments below.
Dirk
"Venkatesh Prasad Ranganath" <vranganath@cox.net> wrote in message
news:b83rsp$hs9$1@rogue.oti.com...
The idea behind this item is to open up refactoring for non Java languages
as well. This means:
- allow others to trigger Java refactorings by creating corresponding
refactoring objects (e.g.
enhance the already exisiting refactoring support provided in 2.1)
- allow others to participate in refactorings (for example renaming a Java
method updates references
in JSP files as well).
- allow others to use the refactoring infrastructure to implement
refactorings for JSP, HTML, ....
Currently it isn't planned to make JDT internal classes used to implement
Java refactorings
(like AST rewriting, precondition checking algorithms, ...) API.
> UI, JDT Debug]
> JDT UI, JDT Debug]
> [JDT Core, JDT UI]
> waiting for reply,
Re: 2.2 and JDT AST [message #3779 is a reply to message #2665] |
Wed, 23 April 2003 23:00   |
>Dirk
>>Hi,
>Java refactorings
So, does that mean that with the current JDT implementation I cannot
extract AST corresponding to a Java File, change the AST, and have the
changes reflected in Java File? I was under the impression that this
could be done. Also, to enable/expose such support is it possible to
open a feature request?
>> these operations.
>> [JDT Core, JDT UI
>>waiting for reply,
Code formatting and CVS in/out triggers? [message #6380 is a reply to message #3779] |
Sat, 26 April 2003 01:07   |
Is there anything being done on two fronts: One, Code Formatting along the
lines of Jalopy? And two, formatting when check in/out occurs? I am all in
favor of having all code in a given repository be formatted in one specific
manner, but allowing each developer to work on it with their own format.
What I would like to see happen, if at all possible, is the ability for any
check-in to be set up to format the code in a specific way, save the file,
then check it in, as well as when checked out, a specific format applied to
it before displayed in the editor.
But I really want to see Jalopy features added to the build-in formatting of
code. Probably seems like a stupid thing to want, but I am very picky about
the code I work with. Having it formatted the way I like makes it much
easier to work on than being stuck with whatever format was last saved.
When can we expect something along these lines in the 2.2 (or is it 3.0)
branch for testing?
Re: Code formatting and CVS in/out triggers? [message #8526 is a reply to message #6380] |
Tue, 29 April 2003 11:08  |
Originally posted by: KingD.TCE.com
"Kevin" <supreme_java_guru_1@yahoo.com> wrote in message
news:b8d4ak$6vv$1@rogue.oti.com...
specific
any
to
of
about
> branch for testing?
Here is the request I submitted for this a year ago:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=12458
Dale King
Current Time: Thu Jul 17 15:53:32 EDT 2025
Powered by FUDForum. Page generated in 0.50194 seconds
