Home » Archived » BIRT » Multiple query execution
Multiple query execution [message #220780] Fri, 23 February 2007 19:19 Go to next message
Is it possible to execute multiple queries in the report to display result
in one table. I know that I can create multiple datasets (each representing
one query), but then I have to assign each dataset to a different table.
Currently what I want is to execute multiple queries and the result to be
shown in one table. May be there is a way to do it using the scripting. Any
help in this regard would be appreciated.
Bidyut
Re: Multiple query execution [message #220873 is a reply to message #220780] Sun, 25 February 2007 11:21 Go to previous messageGo to next message
Originally posted by: martin.tauber.t-online.de
Hi Bidyut,
since you are using queries and I quess you are talking about
sql-queries, why aren't you just using sql to do the job for you, after
all this is a major feature of sql.
consider looking at something like this:
select a.col1, b.col2 c.col3
from table1 a, table2 b table3 c
where a.key = b.key and
a.key = c.key
regards
Martin
Bidyut Pattanayak schrieb:
> result in one table. I know that I can create multiple datasets (each
> representing one query), but then I have to assign each dataset to a
> different table. Currently what I want is to execute multiple queries
> and the result to be shown in one table. May be there is a way to do it
> using the scripting. Any help in this regard would be appreciated.
> Thanks
> Bidyut
Re: Multiple query execution [message #220907 is a reply to message #220873] Sun, 25 February 2007 19:36 Go to previous messageGo to next message
or you can try to use the stored procedure
Re: Multiple query execution [message #221187 is a reply to message #220873] Mon, 26 February 2007 13:48 Go to previous messageGo to next message
Hello Martin,
I am exactly talking about sql queries. But I can only assign one sql query
to one dataset or can I use multiple queries for one data set?
Bidyut
> Hi Bidyut,
> after all this is a major feature of sql.
> a.key = c.key
> regards
> Martin
>> it using the scripting. Any help in this regard would be appreciated.
>> Thanks
>> Bidyut
Re: Multiple query execution [message #221195 is a reply to message #220907] Mon, 26 February 2007 13:49 Go to previous messageGo to next message
Hello 70,
Stored procedure is not a viable option because our application supports
multiple database types. Hence we won't be able to write stored procedures
that can be run on Oracle, SQL Server and MySQL.
Bidyut
Re: Multiple query execution [message #221283 is a reply to message #220780] Mon, 26 February 2007 16:53 Go to previous message
I had the same problem and tried several different methods. I looked at
Stored Procedures but there seemed to be too many differences between dbs to
implement effectively. I ended up creating a View where I could specify the
multiple queries. Then you can easily access the View as any other table in
your db from Birt.
Bill
"Bidyut Pattanayak" <bidyut@yahoo.com> wrote in message
news:65c30c7bd8b48c9257d75f8f9fa@news.eclipse.org...
> different table. Currently what I want is to execute multiple queries and
> the result to be shown in one table. May be there is a way to do it using
> Thanks
> Bidyut
Previous Topic:Setting Portion of Data to Bold within 1 expression
Next Topic:BIRT Viewer: temporary files management?
Current Time: Thu Jul 10 03:28:29 EDT 2025
Powered by FUDForum. Page generated in 0.27859 seconds
