Libraries [message #220545] |
Mon, 09 July 2007 14:24 |
Originally posted by: kevin.m.meredith.lmco.com
Where can I download these libraries?
org.eclipse.emf.transaction
org.eclipse.swt
org.eclipse.ui
org.eclipse.uml2
com.ibm.xtools
Thanks!
Re: Libraries [message #220554 is a reply to message #220545] |
Mon, 09 July 2007 14:37 |
--------------070603000608000308040900
Kevin,
Probably the easiest would be to install one of the Europa packages and
the use the update manager from whatever you install to download the
other things you need:
http://www.eclipse.org/europa/
> org.eclipse.swt
> org.eclipse.ui
> org.eclipse.uml2
> com.ibm.xtools
> Thanks!
<html>
<head>
http-equiv="Content-Type">
</head>
Kevin,<br>
<br>
other things you need:<br>
<blockquote><a href="http://www.eclipse.org/europa/">http://www.eclipse.org/europa/</a><br>
</blockquote>
<br>
Kevin M wrote:
<blockquote
cite="mid:88ab8b0bc8f6c8ea62986e2348f0a8f7$1@www.eclipse.org"
type="cite">Where can I download these libraries?
<br>
<br>
<br>
org.eclipse.swt
<br>
org.eclipse.ui
<br>
org.eclipse.uml2
<br>
com.ibm.xtools
<br>
<br>
Thanks!
<br>
<br>
</blockquote>
<br>
</body>
</html>
--------------070603000608000308040900--
FUDForum. Page generated in 0.07043 seconds
