Re: Run -> Debug skips over my breakpoint [message #220448 is a reply to message #220433] |
Sun, 08 July 2007 11:24 |
Terrence,
Why is there a red "x" indicating an error? It looks to me like you
need to add a try statement or you need to add a throws IOException to
the main method before the program will compile correctly and hence
before it will behave reasonably at runtime.
Terrence Brannon wrote:
> Re: http://fyodor.hcoop.net/~terry/tmp/attempt-to-debug.bmp
> my screenshot shows that when I attempt to run my application in debug
> mode, the first stop is at the exception, instead of at the breakpoint
> 3 lines earlier.
> I want to inspect the value of the variable r, but cant even get a
> breakpoint to stop there.
FUDForum. Page generated in 0.08369 seconds
