Home » Archived » Visual Editor (VE) » Why I can't use VE
Why I can't use VE [message #21394] Fri, 27 February 2004 22:59 Go to next message
Originally posted by: wupf.163.com
I have eclipse-SDK-3.0M7-win32 and downloaded all these files:
emf_2.0.0_20040127_1738SL.zip
GEF-runtime-3.0M7.zip
VE-SDK-I20040226.zip
and unzipped them into the eclipse directory. I verified that EMF and GEF
and VE are in the plugins directory.also I can find them in the
"TargetPlatform" ,
But I can't found them in the "plug_in details" and "feature details" and
configuration .
Why?
Who can tell me How to do ?
Thanks!
Re: Why I can't use VE [message #21403 is a reply to message #21394] Fri, 27 February 2004 23:13 Go to previous messageGo to next message
For integration build I20040226 of VE, you need Eclipse SDK integration
build I20040226, not the stable M7 release. Get it here:
http://download.eclipse.org/downloads/drops/I-I20040226-2004 02260800/index.php
You should probably also be using the latest stable build of EMF,
20040225_1234SL, not 20040127_1738SL. Get it here:
http://download.eclipse.org/tools/downloads/emf/emf_2.0.0_20 040225_1234SL.zip
> "TargetPlatform" ,
> and
> configuration .
> Why?
> Thanks!
Re: Why I can't use VE [message #21411 is a reply to message #21403] Fri, 27 February 2004 23:33 Go to previous message
Thanks a lot!
"R.U. Deranged" <yes_this_is_a_real_address@earthlink.net>
??????:opr32bc6aabc47nv@news.eclipse.org...
hp
p
GEF
> > "TargetPlatform" ,
> > and
> > configuration .
> > Why?
> > Thanks!
Re: Why I can't use VE [message #582791 is a reply to message #21394] Fri, 27 February 2004 23:13 Go to previous message
> "TargetPlatform" ,
> and
> configuration .
> Why?
> Thanks!
Re: Why I can't use VE [message #582810 is a reply to message #21403] Fri, 27 February 2004 23:33 Go to previous message
Thanks a lot!
hp
p
GEF
> > "TargetPlatform" ,
> > and
> > configuration .
> > Why?
> > Thanks!
Previous Topic:Why I can't use VE
Next Topic:VE I20040226 problem: Event popup menu
Current Time: Wed Jul 16 10:47:42 EDT 2025
Powered by FUDForum. Page generated in 0.05563 seconds
