Bug: Eclipse on linux are not reading my eclipse.ini [message #219974] |
Thu, 05 July 2007 12:21 |
Originally posted by: tiller.daimi.au.dk
I have just downloaded the new eclipse 3.3 for Linux (The one called
Eclipse IDE for Java Developers)
And it is working, but it's not reading the included eclipse.ini file.
This causes the problems that the std heap size is something like 12MB
and the max heap size is 64MB.
Does anyone know what can cause eclipse to ignore eclipse.ini?
Martin T
Re: Bug: Eclipse on linux are not reading my eclipse.ini [message #220097 is a reply to message #219982] |
Thu, 05 July 2007 13:57 |
I found the problem. I had renamed my eclipse to eclipse.real and
then eclipse need the ini file to be called eclipse.real.ini insted of
eclipse.ini
I don't know if this is a feature or a bug, but renaming the eclipse
file did not cause this problem when I was running the eclipse3.3 RC3/4
Well it's working now.
Remy Chi Jian Suen wrote:
> Every single argument must be on a new line. Confirm this. I think
> leading/trailing whitespaces may be a problem, also confirm this.
> Rem
FUDForum. Page generated in 0.07875 seconds
