Re: Workspace configuration crashes [message #219699 is a reply to message #219692] |
Wed, 04 July 2007 12:34 |
Tatu,
If you could open a bugzilla with the steps needed to reproduce this
problem (i.e., import this sample project into workspace and then
Eclipse won't start with that workspace again), that would be very
helpful for getting the problem fixed. It's really important you make
clear exactly what you've installed so that the developers can actually
reproduce this.
Tatu Lahtela wrote:
> Hi, After a while of using Eclipse Europa it crashes. Then when I
> start to restart Eclipse, the following exception appears after I
> select the workspace:
> -snip-
> Exception in thread "Thread-1" java.lang.NoClassDefFoundError
> at
> org.eclipse.ui.internal.themes.ThemeElementHelper.installFon t(ThemeElementHelper.java:101)
> at
> org.eclipse.ui.internal.themes.ThemeElementHelper.populateRe gistry(ThemeElementHelper.java:57)
> at
> org.eclipse.ui.internal.Workbench$28.runWithException(Workbe nch.java:1426)
> at
> org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
> at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
> at
> org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
> at
> org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3296)
> at
> org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2974)
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2309)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
> at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:585)
> at
> org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
> -snip-
> After that, the Eclipse silently shuts down. The only way to restart
> eclipse is to select another workspace and recreate all projects (very
> annoing when done several times..). Importing the projects will cause
> the same problem.
FUDForum. Page generated in 0.08031 seconds
