Home » Language IDEs » Java Development Tools (JDT) » How to change the label in the Debug View of my running process?
How to change the label in the Debug View of my running process? [message #219489] Sat, 19 November 2005 04:16 Go to next message
--------------080804030505090503040309
Content-Type: text/plain; charset=us-ascii; format=flowed
Attached is the image that illustrates the question in the subject line.
Basically, I launch a Java process and the Eclipse debugging framework
have the "javaw.exe" in it. Basically, I would like to change the
text/label underlined with the red line (for illustration purpose). The
text underlined with the green line is prefixed to the red underlined
label Eclipse when my process is terminated.
How would I change the red underlined text so that the Debug view will
display the process name that I want.
Thanks!
Content-Type: image/gif;
name="label.gif"
Content-Disposition: inline;
filename="label.gif"
R0lGODlh/AF/APcjANbTw6yomf39/Ozp2P38+jhWTpCQiKiooPz7+DFOSjhW U5CQkPv697Gu
sS1IPTFORcLBwdjY2LCwsPr59TFWSi1ORShIPS1wfChFOXFvZMDAwOHV1IiI gJiYmPn48+fz
28fbryA5MihBOQAAAP////f39c7Syvz8+/v7+ujY2NzNzYCAgPn38itufMfc ry5qItvrzNXm
wsbcrixvey1OPerp4cvQyPr6+Mi4uMy2uHh4ePj38Cpte9vqzMvftLjSnSpt fOTi2MfNxcbN
xfj39fX08djQ0MiwuLilpvf27idqe9XnwpLBf8bbrrbSmabJhydreuXj3N7a z6+5sq64sfPx
7e3r5ciwsKioqKCgoPb17CM+MiRoesfbrnOnWK/OkZ/Hgam0rO3r5OXi2djI yMCosHBwcIiI
iPX06yFnebjSnLXSma7OkVONPJbDeSJmeuDd0rK8srO9s+nn3+Dc0dDAwMCo qGhoaPTz6R9l
eSBleZXCeTp8Kx9keLW+s/Ty5x1ieR1jeB1jebe/tPLx7Ozq48CwsGBgYPPx 5iNBMvLw5PHv
4vDu4e/t3+/s3e7r2+3q2t3Z0bOuvrKsvbeyv+Dc0t7b0oqDqlpRlFxTlZSO r+Xi1WtjnHVu
oYJ6psvHydvX0HOG76ehuL65wtLOzG9mnn53pc3Jyl1VlmRcmdfUznRsoNnV z7+7w6Kctqag
t8TAxsfHwqyto6urod7e5+G7y9DO1amroN3d5u0aSNLS3a2uuKepnc7N1MN8 kK2tt6WnmqOk
mNbX4cnJ0aChlcfI0aiptamrudzb2M7Oybq7sp6gktiWmclXSubl7s7Q3Z2g rpydj8lPQviu
qdzc57m90JmbjPipnvJvbdna5rW6zpaZisk/OvSDguhHUtXW5K2yypSXh8EQ I9fX5K+0y5OV
hfimqc7O1pGTgtFfcsjHwJCSgbW1qwCAAP8AAOFuWAAAAgDAAAAAAAAAAAAC AAAAAAAAAAAA
AAAAAAAAAAAAAJDl5fjMfJx8gQAAAhLYmCH5BAgyACMALAAAAAD8AX8AAAj+ AAEEEECwoMGD
CBMqXMiwIcIAAQAMmEixosWLGDNq3GgxAMePIEOKHEmypMmTKFOqXMmypcuX JSESmEmTQIGa
OHPq3Mmzp0+dEWEK9Si0qNGjSJMqXcq06UQDByweMPARIoKrWBEkwKogq9ev YMOKHUs2K0SJ
TkcSTcu2rdu3cOMuNbAAKsWpdTkGYMC3L4MGDhrwfeC3sOHDiBMrXmw4qFyM ax9Lnky5suWU
EDJvNBAhAl0JdTsbkLAxwITTEygkqGDhwoUGGBqgnk27tu3buG1n2D17d4bb jitHvky8uHGW
mZMP0DwyuWbnED5qmE69uoaP0S1C2MA9O8YDHDr+d+DQoTOHqKU9qF/f4MIH EK4veAghYr39
+/jVj8jPv7+HDCSQkIF6AArYX3CTDXfcggw2mBEEJUQYHQQmMAcSBCeggMKE GW4oXQoghhji
dRxZOBEEKqToHUYLrNDZiyssUBULNNbIQgsuvABDDDLM0EADNFBgIwsjFDnC kDYeieSSTNZY
oIBPZtAkCwhuZOQISSno4JZcFgdBDWBOaMOYJmoEAQo3eHhmmitmpEEKOMQp Jw4pkLjRhBVB
kMOebV60Amc6dGDAChR1oENGAeyg6A4KKLBDAzz08AEMPvwARAOLZjrCoptm yqmnoIYq6pMB
CihqplVihCVTWnbp6qv+cX0ZRA0TCmHrEEOUeREERBRBxIS9/iqdEUcUa+wR Rthp5ol5ItGn
RQvoEIEOKwSqg4yGVgtZEtx2+wAGSiwBAxNNOPEEFN2mO4K63BrZrrtJrNvu u0Wmay+3pGZw
775JpGrRqhUZORGWBFO0qsADFJxwkRW1CuvDEC8FQRRSRDHhFBhjTMUUz1IE QRVWVDEhyCIP
e8XJKF+RLHYnWtgxRdFGgIUOWWRBLRbV1nzoRQFo4fPPWmzBhQw+dOHFF2Bw EQINQGsxAtBP
P+1z1D9TPbXTVTetdb5ad+2zvwEznLDBCw9MNsAEHwxZxGy3rdTEFU8Yxtx0 h/HycmKMIcb+
hHnvLR0ZZQQueBlkKPvg4RtJO20HZnTQwRlmnOF445ChYfnlaMSWhhprsNGG G280gEYCmI9Q
OhpXmm665apf3jrrmMeOBqkBZiD77ZaD/e/CAgM89sFXjj2w7xM57PbxyJf0 JRy0LhfH83LI
oat2c9Axx4TVXy9dHXZ0770ddRi+q7MeP8eRDhxcO8AKdyzgvvt3EAoZHvTX j0cFDeShxxNg
7MFHH/ar3wjsN8ABElCAeDBgAhdIPwUGEA9RitIDJ0g/3Z1tdxcUHtnC1rDk efCDygNT8yDg
hxJOb1d945ve7jYRDQBucIEr3J24s4EV4el8MprIHXRwhh7q4A7+GgnAH4ZI RAoQMQSACIQg
AEHEJv5hBESE4hOjOMUhQlGKU8QiFp34hwJlYIhe5KIYiWjB32VwgxpUWMA6 CMI2uvFBESrB
hAZxQoxAgBCFIMSECCEGPQ7LEIAMpCFWZqYUqaBNdcTICg6xgkY2kpGIQoQk J0nJRPyIkphE
xJUoaSRJbtKTndRkKDOJCN9Q0pSkTCUiUhW84altjQYTG9rERhHjvfGWx4PO cli4qyL4ckK+
LAIv3yQiEYkvT3vKQZ94SZFFNtIMhzDDI+XXEUVY85rYtAA2t8nNbnrzm9Yc ATjHSU5slhEp
tsSlOtf5IOfsUjkcsY48S5TIj2CBkc7+xBk+DwGZRfjzn/+kAEAHStCCGvSg RjqoQhd60LO0
JZ3sjKhEYRVNSE5kkdCEDCM2ytGOevSjIA2pSEdK0pKadKPnHMpEV8pStlm0 mfyETCNmStOa
2vSmOM2pTnfK0576lKYObQpEW0rUor4qAI5IqlKXytSmOvWpUI2qVKdKVaZC JKUrGapRt8rV
4zziq2ANq1jHStaymvWsaE2rWst6VbQYRatdjatcHwOJutr1rnjNq173yte+ +vWvgPXrVQdL
2MIa9rCITaxiF8vYxjr2sZCNrGQnS9nKWvaymM2sZjd71bl69rOgDa1oR0va 0sKlVKhNrWpX
y9rWuva1sI3+rWxnS9va2va2uM2tbnfL29769rfADa5whxvbiRD3uMhNrnKX y9zmOve50I2u
dGFrXN5GQhKToEQlpsvd7nr3u+ANr3jHm9zq5tYSl8CEejGRCU1sgrywHcFx jRRf6Mp3uPSF
r373y9/xmpcEiG1tJDix3gJ34r2yve9tFexaBrfWwahNXX1Tq2AJU5gEEK5t kWYr3wxfOEAe
Xm2I+0viEps4uP8NwGpVzFpPFPjFmohth5M74lLd18M1trFqK9zg3m44wUC2 bY5PTOQiG9m1
KV4xaz/x4hdnAhQNvvGP8ztj+k4Zw/nFspS3bOMs/zjCEf6ylb+MYR1TeMNV 9vL+lMkM4jZr
ecs3LrOWQbzmGc/5zWA+sp73zOfUJlm1LE5tKAZN6EIbWsQM5nGbryznKptZ x4ouc6TpnGc5
S7rSj76SmxdtaTtv2sFx7rSoHS3iUUM6031OtaqJnGQJq/jVAA6QJpr8YlGU +sNv9nSoSd1o
K3fZ15uudIU1LeYdPzrYvO7wsLPs5lBfmtOepjOaT83pT6/62tiG759TG2jU GvrbhUa0sHG9
62ebW9fkPvO4dxxta2M62V229JmJTe1LR5vH+K73pLPN735Dd9uo7TZqR0Hr ApMiyu4+d7MV
nm9rR5rNoka2vBMucXTr+92mhra8G85wVPv74yBXLsD+SyVw1Jai4JgwhYwp fWdFx9nimsay
tH/tbFy3XMyJpjmX01znX9tc2XV++czxLHMuR3ziIU+60neb4sO29hSooHUq VLH0lWvYt6B2
7pCrzvWul+q/tyXFKl5sClZ4PcpbD7Zus75cZp/97XAHO25b4QpNvAIWcM+7 3vfOdxLIve+A
D7zgB/933JbctbGQheIXHws/m/bxkG/pawuv3FnQoha1oAUtbDELx0f+86C/ 5eQH8NvDt/YW
uMhFLnShi13cwvOhj73s3TZ66fKiF77wxS92zwvYE4d4SgF+U4RvEuJnxPgn QRtIkP8Y5see
eLX3relZC4zqW7/6vsdg8Zf+z/3tO/8i3z8+LTXSSjQCH3jlh6XZrKR9ValK lmhcf/vDP/zh
xT8kvkOY+GfJf1eOX/68A37BkzoC2H8CGEsIqEGkh2QLCF3BIAwQCIHDEAzZ Zzb0l3zdh4Ek
cYHq90rtN38cBH7uJxL5Z3z/l0Yo+BEcmBbAc38qqHwA2IEoqHwmCIMKeIPq J39qdH6zlIC+
E329NX2rRQzFYAzHcITHQAzZJ0tMqDZpkzYWqH8IM4W0lH7/An8WGIDm50pZ uH5SqH096IIp
qIMjOIIMozBfKIZmRH5eOIW8A4NNSIZa+Eo86IHoB4bCc4djuIUx6H40eEZl CEseiIe7Y4Ne
mIX+O0gRQPhcyJAMyrAMkAiJsDd+NgiFeYiI95eIXYiDcoiGOGiIZvSHhyiD ISh8oKhGOSiC
UdiJqTiKZWiHa3iJMaiJGTSIKeiJACiKiQiKY8h8sEiD+teKcBiMeyiLN0iH oYhGi7hbsNaM
scYMzRCN0cgMzvAM1ggN0eB55xdLvbNBTniL3eh/tHiFaRiLa8R/BQOMxMiH hcgRxHOCnCiD
6DiIpmiFuUiGmjiM8IeOyfiO5TePpJiO3siJJQiP7DiOn/iBqhiPvYhByDiG y4hc0jANFEmR
0kAN1ZCR0GANk5h/mTiQybiJCMmLfTiDfoiPJumOmWiLC+mCzieKCan+hiX5 jigJh2f0jSYp
kK1YjHyok5doioEIgiKpkB6pkiWpgIaYOrhogxF5XNJwDdgQldcgDdmgDVYJ DduwhLA4lD+Z
krEIk7Zokzi5kH8IlrNofjRJiKn4fWbpikhJiNuYkyD5lQcph8aIk0mJlg0Z lMWYlnTJi4DJ
ioKolm/plwDTlMTFDd3gDYzZDdzwDeAQmdAQDhWYh3pokyFpmUzIhf7Xh27Y hSdYkGhIhYBZ
hftHj0LZfagYjHp4jN74j2/IlbIIm9y4lWmEhZqpimHImu8XhrPYSlJYhaHZ hLhZjm1ImiCY
lj/IgM0lDlApleIwDuQwndBQDpV5GSv4KvL+lYNKaYJHqZAqwYEsGRfZWRLl 6TbL2VqUJ1zi
MA3m8J7mIA7nAA30CQ3ocJ2VcZ5dop/niH8wIZ4MCRf8qYItBX3MyVzpIA4K qqDpoA7r8KDr
wA74OXsUWqHHgZjfZaEauqELgqGD96EgGqIht54iWqImeqJGRqIouqIs2qIZ 2oAuGqMyOqPP
paLg1Q44mqM6uqM82qM++qNAGqRCOqREWqQ8qlrukKRKuqRM2qRO+qRQGqVS OqVUWqVWeqVY
mqVauqVc2qVeyqWzZaM0OqZkWqZhCqNmmqZquqasJaZs+qZwuqJuGqd0WqeC N6d2mqd6enZ4
uqd++qcf16eAOqj+hNpnglqoiJqoJXaoitqojhpejPqokjqpNYqmlHqpmOpd kZqpnNqpurWp
nhqqokpdljqqpnqquAWqqLqqoaqqrPqqmOqqsDqrjyqrtHqriGqruLqrf6qr vPqrduqrwDqs
byqsxHqsZmqsyLqsM6qszPqsLOqs0DqtJSqt1HqthFeq2LqtbGqt3Pqtcaet 4DquzSqu5Hqu
0Wqu6Lqu1aqu7Pqu2Qqv8nqi3jqv9qpn9Xqv+npi+bqv/spf/fqvAutf7jqw BpttAXuwCitd
CbuwDttcDfuwEotcETuxFotiBXuxGqtfFbuxHpuqGfuxIttdHTuyJuuhJ5uy 0VWyKttasgHC
si6rsjAbsyc7szQ7sjZ7sx+bszq7sTzbsxf7s0A7sUI7tA9btEa7sEibtAe7 tEw7sE77tP8a
tVK7r1Rbtfd6tVg7r1q7tfDatV7LrmAbtug6tmRLrgEBACH+ADs=
--------------080804030505090503040309--
Re: How to change the label in the Debug View of my running process? [message #219931 is a reply to message #219489] Wed, 30 November 2005 19:07 Go to previous message
Originally posted by: jaredburns.no.spam.acm.org
This isn't possible. All you can do is change the name of your launch
configuration, which will affect the text label of the top-level launch
object.
AL wrote:
> Thanks!
Previous Topic:How do I contribute actions to the Debug View' menu?
Next Topic:how to get the full name of parameter type from the IMethod object
Current Time: Sun Jul 13 23:02:36 EDT 2025
Powered by FUDForum. Page generated in 0.04936 seconds
