Home » Eclipse Projects » Remote Application Platform (RAP) » little rendering problems
little rendering problems [message #21256] Wed, 02 May 2007 11:22 Go to next message
Originally posted by: manuel.staechele.levante-software.ch
hi,
i have a few little rendering problems
1. combo boxes are simple select boxes?
2. how can i increas the size of label, combo, text boxes etc.?
the method setSitze does not work for me.
Text text = new Text (parent, SWT.NONE);
text.setSize (100, 20);
3. the headlines of my views do not show the full text i have similar to
the demo a left view with the headline "Menu" but can only see "M"...
4. i can not change "RAP Startup Page" in the title (i see the other
mailings about)
are all swt methods implemented?
i use firefox 2.0 with minFontSize 16 pixel. But looks very similiar in
internet explorer 6 too.
so many thanks
greetings
manuel
Re: little rendering problems [message #21290 is a reply to message #21256] Wed, 02 May 2007 12:13 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
Hi Manuel,
please see my comments below.
Rüdiger
Manuel Staechele wrote:
> hi,
Combo boxes with editable text area are not yet implemented, is it that
what you meant?
Could you explain why it doesn't work? If you do not use layout
managers, setting the size explicitly as in your snippet should work.
Yes, the current calculation for the width of a CTabItem is a bit rough
in some cases.
> mailings about)
We plan to make the index.html page, that is used at startup,
customizable. With this in place you can also change the title.
An overview of the differences between SWT and RWT and the status of RWT
can be found here: http://wiki.eclipse.org/index.php/RWTOverview
In addition it's worth reading the new and noteworthy pages that can be
found here: http://wiki.eclipse.org/index.php/RAP
> so many thanks
> greetings
> manuel
Re: little rendering problems [message #21826 is a reply to message #21290] Thu, 03 May 2007 03:11 Go to previous messageGo to next message
many thanks
please see my answers below.
Rüdiger Herrmann schrieb:
> Hi Manuel,
> Cheers,
> Rüdiger
>> hi,
> what you meant?
yes you right, its not realy importent..
first i build a group
group = new Group( parent, SWT.NONE );
group.setLayoutData( new RowData( 500, 200) );
group.setLayout( new GridLayout( 2, true ) );
than i add label
Label label1 = new Label(group, SWT.CENTER);
label1.setText("Name: ");
label1.setSize(200, 30);
label1.setLayoutData(new GridData(GridData.HORIZONTAL_ALIGN_CENTER));
than i add text area.
final Text text13 = new Text( group, SWT.BORDER | SWT.SINGLE | SWT.CENTER );
text13.setLayoutData(new GridData(GridData.HORIZONTAL_ALIGN_FILL));
maybe i need a swt tutorial? ;-)
> in some cases.
i choose a smaler image and it work mutch better.
>> mailings about)
cool.
at all its a real good project!
>> in internet explorer 6 too.
>> so many thanks
>> greetings
>> manuel
Re: little rendering problems [message #21870 is a reply to message #21826] Thu, 03 May 2007 03:49 Go to previous message
please see my comment below...
Cheers
Rüdiger
> many thanks
>> Hi Manuel,
>> Cheers,
>> Rüdiger
>>> hi,
>> that what you meant?
> than i add label
> SWT.CENTER );
An SWT tutorial is always a good idea and also helps programming with
RAP as we build a subset of SWT and try hard to be as close as possible.
To arrange your widget you should either use setSize() or use layout
managers. Mixing both will very likely end in a mess...
In your code snippet, if you *really* wish to set sizes explicitly and
not let the layout manager do that boring work, replace
with
label1.setLayoutData(new GridData(200, 30));
>> rough in some cases.
>>> mailings about)
> cool.
>> RWT can be found here: http://wiki.eclipse.org/index.php/RWTOverview
>> be found here: http://wiki.eclipse.org/index.php/RAP
>>> so many thanks
>>> greetings
>>> manuel
Previous Topic:Error when deploying rap application in tomcat
Next Topic:RAP Questions
Current Time: Sun Aug 31 12:05:55 EDT 2025
Powered by FUDForum. Page generated in 0.03746 seconds
