Home » Language IDEs » Java Development Tools (JDT) » Completion of variables
Completion of variables [message #1787] Tue, 22 April 2003 10:46 Go to next message
Originally posted by: pmateescu.novosadhayes.com
I have just started using Eclipse and I really like it. I think it's one
of the best interfaces I've seen.
I've added PHPEclipse and plan to use it for my other projects as well.
I have a question thought, one I couldn't figure out. (Java or PHP)...
Given this declaration:
string myOwnString;...
I want to type "my", hit a key combination (Ctrl+Space) and get all the
variables that start with my*. (Well, in PHP's case that would be
$myString).
Any suggestions on how to make it happen?
Thanks a lot!
Re: Completion of variables [message #1793 is a reply to message #1787] Tue, 22 April 2003 11:02 Go to previous message
Originally posted by: genadyb.inter.net.il
If the PHP plugin provides code completion, it should work.
You can also try different context insensitive code completion plugins.
One is "Editor Enhancements" from http://lunar-eclipse.sf.net/
(emacs-style) and the other is by "zClipse" (eclipse-style). I don't
remember their website, but you can find it by searching the
eclipse.tools group.
Genady
Philip Mateescu wrote:
> $myString).
> Thanks a lot!
Re: Completion of variables [message #1799 is a reply to message #1793] Tue, 22 April 2003 11:01 Go to previous message
Thanks!
Following your suggestion I found the TextComplete which was exactly what
I wanted.
Thanks a million again!
philip
> One is \"Editor Enhancements\" from http://lunar-eclipse.sf.net/
> (emacs-style) and the other is by \"zClipse\" (eclipse-style). I don\'t
> Genady
> > Hi,
> > I have just started using Eclipse and I really like it. I think it\'s one
> > of the best interfaces I\'ve seen.
> > I\'ve added PHPEclipse and plan to use it for my other projects as well.
> > I have a question thought, one I couldn\'t figure out. (Java or PHP)...
> > I want to type \"my\", hit a key combination (Ctrl+Space) and get all the
> > variables that start with my*. (Well, in PHP\'s case that would be
> > $myString).
> > Thanks a lot!
Previous Topic:[REQ] JSP development
Next Topic:Classpath of a plugin programmitically ?
Current Time: Thu Jul 17 20:29:32 EDT 2025
Powered by FUDForum. Page generated in 0.07887 seconds
