Not able to export a plugin [message #218726] |
Thu, 28 June 2007 19:57 |
Originally posted by: giord.uol.com.br
I'm trying to modify a plugin, but I'm not able to export it. When I try
to export the plugin the following error message is displayed:
'Unable to find plug-in: org.eclipse.stp.bpmn.diagram_0.0.0. Please
check error log for more details.'
There's nothing relvant in the error log, and the version in the
manifest file is 1.0.0.
I guess I'm doing something wrong when I created the plugin project.
That's how I did it:
1 - I connected to the CVS, selected the desired plugin folder, and
selected 'checkout as project in the workspace' and pointed to a new
project with the name suggested by the property page. (I considering the
plugin folder the one containing the plugin.xml)
2 - Resolved the dependencies and built the plugin project.
3 - Selected 'Export' -> 'Deployable plug-ins and fragments' -> Finish.
4 - The error popup: 'Unable to find plug-in:
org.eclipse.stp.bpmn.diagram_0.0.0. Please check error log for more
details.'
Am I doing something wrong?
Thanks in advance,
RGB
ps: I'm using Eclispe:
Version: 3.2.1
Build id: M20060921-0945
Re: Not able to export a plugin [message #218955 is a reply to message #218726] |
Fri, 29 June 2007 18:47 |
Should I send this post to another list?
Tks,
RGB
Roberto Barra wrote:
> details.'
> Thanks in advance,
> RGB
> Version: 3.2.1
Re: Not able to export a plugin [message #218994 is a reply to message #218979] |
Fri, 29 June 2007 21:01 |
>> Tks,
>> RGB
>>> Hi,
>>> try to export the plugin the following error message is displayed:
>>> the plugin folder the one containing the plugin.xml)
>>> details.'
>>> Thanks in advance,
>>> RGB
>>> Version: 3.2.1
> Hi. You could try the eclipse.platform.rcp group. HTH. Mark Dexter
Tks, I'll try
FUDForum. Page generated in 0.08446 seconds
