Home » Language IDEs » Java Development Tools (JDT) » Adding Java Cryptographic Extension to plugin.xml
Adding Java Cryptographic Extension to plugin.xml [message #218655] Thu, 10 November 2005 11:57 Go to next message
Originally posted by: Aaron.Davis.Dynetics.com
I am creating an Eclipse Application that uses a Java Cryptographic
Extension (JCE) that is packaged in a JAR file that would normally resides
in the lib/ext folder of my JRE (Java 2 SDK, Standard Edition - Version
1.4.1). I have included this JAR file in the classpath and added it to the
<runtime> tag of my plugin.xml file.
While running the application, it fails when it attempts to use some of the
cryptographic functions from the extension. The only way I can get the
Eclipse Application to work correctly is by physically adding the JAR file
to the lib/ext folder of my JRE. If I use the same cryptographic functions
while running a Java Application in Eclipse, it works fine.
Is there a way to run my Eclipse plugin without having to add the JAR file
to the lib/ext folder of my JRE? Do I need to make some more modifications
to the plugin.xml file?
Aaron
Re: Adding Java Cryptographic Extension to plugin.xml [message #219463 is a reply to message #218655] Fri, 18 November 2005 18:30 Go to previous message
Originally posted by: ggerard.ggerard.com
I think this is what you might be after:
http://help.eclipse.org/help31/index.jsp?topic=/org.eclipse. platform.doc.isv/reference/misc/bundle_manifest.html
Check out the buddy loader option. There's an "ext" value that's set-able.
greg
> Aaron
Previous Topic:2 contexts under webapp - eclipse is getting confused
Next Topic:Communicating between Eclispe and a launch of Eclipse
Current Time: Wed Jul 23 10:41:08 EDT 2025
Powered by FUDForum. Page generated in 0.02867 seconds
