Home » Modeling » GMF (Graphical Modeling Framework) » [Templates] Couldn't find operation 'eContainer()'
[Templates] Couldn't find operation 'eContainer()' [message #218631] Fri, 13 February 2009 02:51 Go to next message
Hi, I'm modifying some gmfgen XPand templates to adjust some rules to
generate my diagram using these templates, and I want to access to the
container of the EObject, so I think I should use the eContainer()
operation that an EObject has. But when regenerating the code, an error
told me that this operation doesn't exist. I import the ecore metamodel.
The code is the following (In the
impl::diagram::editParts::NodeEditPart.xpt):
«IMPORT "http://www.eclipse.org/gmf/2008/GenModel
«IMPORT "http://www.eclipse.org/emf/2002/Ecore
«AROUND createNodeShape(gmfgen::GenNode node) FOR
gmfgen::InnerClassViewmap-»
«EXPAND xpt::Common::generatedMemberComment»
protected org.eclipse.draw2d.IFigure createNodeShape() {
«EXPAND newFigureForStereotypes FOR this.eContainer()»
return primaryShape = figure;
«ENDAROUND»
«DEFINE newFigureForStereotypes FOR gmfgen::GenNode-»
«className» figure = new «className»Aux();
«ENDDEFINE»
Exception (Couldn't find operation 'eContainer()' for
InnerClassViewmap.:in aspects::impl::diagram::editparts::NodeEditPart on
line 213 'this.eContainer()') while generating code
Couldn't find operation 'eContainer()' for InnerClassViewmap.:in
aspects::impl::diagram::editparts::NodeEditPart on line 213
'this.eContainer()'
Anybody can help me please???
Thanks!!!
Re: [Templates] Couldn't find operation 'eContainer()' [message #218672 is a reply to message #218631] Fri, 13 February 2009 06:44 Go to previous messageGo to next message
Hello Marc,
> 'this.eContainer()'
This is wirght - InnerClassViewmap is not a subclass of EObject in gmfgen.ecore
so due to the metainformation InnerClassViewmap has no .eContainer() methods...
Try to avoid usage of .eContainer() (and any other EObject-related methods)
in your templates or write java code + call it from the xpand.
Alex Shatalin
Re: [Templates] Couldn't find operation 'eContainer()' [message #218727 is a reply to message #218672] Fri, 13 February 2009 08:26 Go to previous messageGo to next message
gmfgen.ecore
methods...
I think it's not try Alex. According to the GMF documentation,
InnerClassViewmap extends from Viewmap and Viewmap extends from EObject,
and EObject has an eContainer() method. I don't underestand why doesn't
work. Could you explain me more, please? Thanks a lot!
InnerClassViewmap:
( http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse. gmf.doc/reference/api/tooling/org/eclipse/gmf/codegen/gmfgen /InnerClassViewmap.html)
Viewmap:
( http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse. gmf.doc/reference/api/tooling/org/eclipse/gmf/codegen/gmfgen /Viewmap.html)
EObject:
http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse. emf.doc/references/javadoc/org/eclipse/emf/ecore/EObject.htm l
Re: [Templates] Couldn't find operation 'eContainer()' [message #218760 is a reply to message #218727] Fri, 13 February 2009 09:37 Go to previous messageGo to next message
Hello Marc,
> EObject, and EObject has an eContainer() method. I don't underestand
That's right - this class is an instance of EObject (in java world) but in
EMF world it is not.
EClass "Viewmap" defined in gmfgen.ecore has no ESuperTypes specified, so
in EMF meta-information Viewmap is a class on top of hierarchy and is not
sublcassing EObject.. Xpand is using EMF meta-information to locate appropriate
attributes/methods, so this is a reason why corresponding operation was not
found (i know that it actually present in an underlying java object..)
Alex Shatalin
Re: [Templates] Couldn't find operation 'eContainer()' [message #218864 is a reply to message #218760] Fri, 13 February 2009 16:50 Go to previous messageGo to next message
Originally posted by: cdamus.zeligsoft.com
Hi, Alex,
IIUC, GMF now uses XPand-OCL, right? It might be worth considering
using MDT OCL's "implicit root class" option to provide access to the
EObject operations ...
cW
> Hello Marc,
> in EMF world it is not.
> so in EMF meta-information Viewmap is a class on top of hierarchy and is
> not sublcassing EObject.. Xpand is using EMF meta-information to locate
> appropriate attributes/methods, so this is a reason why corresponding
> operation was not found (i know that it actually present in an
> Alex Shatalin
Re: [Templates] Couldn't find operation 'eContainer()' [message #218930 is a reply to message #218864] Mon, 16 February 2009 06:16 Go to previous messageGo to next message
Hello Christian,
Right.
Yes, we should consider this possibility, but i kannot answer right now is
it better to switch this option on or off. Probably we have to introduce
it into the GMF genmodel.
Alex Shatalin
Re: [Templates] Couldn't find operation 'eContainer()' [message #219029 is a reply to message #218930] Mon, 16 February 2009 14:49 Go to previous messageGo to next message
Hi, Alex,
> Hello Christian,
> Right.
> is it better to switch this option on or off. Probably we have to
> introduce it into the GMF genmodel.
Yes, that's a good point. Doubtless there are some that benefit from
the current state of things. :-)
cW
> Alex Shatalin
Re: [Templates] Couldn't find operation 'eContainer()' [message #219089 is a reply to message #219029] Tue, 17 February 2009 09:06 Go to previous messageGo to next message
It seems to be a good idea. But now, the only way to get the eContainer is
using Xtend, a method that returns me the eContainer, it's true? Something
like that:
import "http://www.eclipse.org/emf/2002/Ecore";
EObject getEContainer(EObject eobj) :
eobj.eContainer()
In the XPand rule I should call this method:
«EXPAND newFigureForStereotypes FOR getEContainer(this)»
«ENDAROUND»
«ENDDEFINE»
Thanks!!!
Marc
Re: [Templates] Couldn't find operation 'eContainer()' [message #219136 is a reply to message #219089] Wed, 18 February 2009 05:08 Go to previous message
Hello Marc,
Current version of impl::diagram::editparts::NodeEditPart contains following
definition(s):
«DEFINE createNodeShape(node : gmfgen::GenNode) FOR gmfgen::Viewmap-»
so if you are modifying this particular define then you can use node variable
to get ViewMap container from there:
«EXPAND newFigureForStereotypes FOR node»
Alex Shatalin
Previous Topic:Can 2.2.0M5a be installed with eclipse 3.5M5?
Next Topic:2.0.2 to 2.2.0m5 migration, I lost the connection end decoration
Current Time: Sun Nov 09 06:56:33 EST 2025
Powered by FUDForum. Page generated in 0.03718 seconds
