Re: 2.0.2 to 2.2.0m5 migration, I lost the connection end decoration - other issues with GMF 2.2.0 M [message #219126 is a reply to message #218611] |
Wed, 18 February 2009 08:49   |
Originally posted by: thomas.beyer81.t-online.de
--------------000108010402010600020105
1. Connection decorations:
I am runnung into the same issues, when shifting to gmf 2.2.0 M5a.
I think, something is messed up with the MapMode.
I use a lot of custom decorations, which worked fine in GMF 2.1.2. They
all do not show up at all with the new branch.
Also I have a decoration, consisting of template points, that is
actually painted, but about 50 times the actual (resp. wanted) size.
Screenshots are attached.
Also, the connections are not painted with antialias on, even though
activated in the preference page. Explicitely invoking setAntialias(SWT.ON);
in the constructor of the nested ConnectionFigure inside the
Corresponding EditPart seems to do the trick. However this solution
seems awkward to me.
2. Modeling assistant provider
The popup connection creation handles in GMF 2.2.0 M5a are only shown
for top-level elements, not for elements inside of compartments. popups
for creation of elements are not shown any longer at all, not even for
the diagram canvas, which is kind of sad.
Should we raise bugzilla-reports or are these know issues "under
construction"?
What can we do to help/support the GMF-team?
TIA & regards
Thomas
Brian Jakubik schrieb:
> I'm not sure if this is the right newsgroup, but if not ill post to GEF
> I suppose...
> I have lost my arrow decorations on my connections, The generated method
> createTargetDecoration() is called its sets it in the figure, but I'm
> not seeing it in my diagram... I see the connection, just no directional
> decoration...
> I'm not sure if it is related to migration problems, or if it is a
> problem with 2.2.0m5 or its dependencies.
> Any advice on where I can look to troubleshoot this a little more.
> Thanks
> Brian Jakubik
Content-Type: image/png;
name="gmf_2.1.2.png"
Content-Disposition: inline;
filename="gmf_2.1.2.png"
iVBORw0KGgoAAAANSUhEUgAAAxgAAAGOCAYAAAAU3aUTAAAAIGNIUk0AAHom AACAhAAA+gAA
AIDoAAB1MAAA6mAAADqYAAAXcJy6UTwAAAAEZ0FNQQAAsY58+1GTAAAAAXNS R0IArs4c6QAA
AAZiS0dEAP8A/wD/oL2nkwAAAAlwSFlzAAAOxAAADsQBlSsOGwAAIABJREFU eNrt3QeYU9W6
xvGPkaIejoBHRUEUBRQVOYiNXkRpAoIgSlGko0hTBGnSpElHRRRpUhUURK4g jgc4iBwLKk1A
EQQPIEVFQNShXd513bmZTGaYkplJMv/f8+RJJjt7J9nJzOx3r/Wtle3MWQYA AAAAIRDDLgAA
AABAwAAAAABAwAAAAABAwAAAAAAAAgYAAAAAAgYAAAAAAgYAAAAAAgYAAAAA EDAAAAAAhJPs
7AIAAABkhoEDB7ITIkz//v0JGAAAAAjjA9YWLdgJkRIIZ8xI1uPoIgUAAAAg ZAgYAAAAAAgY
AAAAAMIPNRgAAAAID9dck+pV17VrZ7f26sU+JGAAAAAA8YNCSt366qvsOAIG AAAAEN9RXeLi
rMq0aSlb72zA0HogYAAAAABBZcuWzXd7z549VqBAAXZKhKDIGwAAAGHhmFm8 lggFizNnzljB
ggVt7969vuCh2/7Xgev5Qso117jL+ddfb3fWr2+Lli9P9/dQqnbtDF0vMe+t WGGFypZ17z2j
0YIBAACAiKHQocDhf332RqKPP7Nzp50+fdqWr15tLZ9+2s7PlctqVq6cbq/v q/feS3ag8H9s
ctdLrtY9e9rS6dOt1I03EjAAAACQNakG45hfS0TBv4KDfxcpXatVw4WHv66/ CVgvUExMjAsV
Y/r2tXFTp6ZrwEiu9Vu2pOv2fzx4MFPChdvffJUBAAAQrkJZf9GwVi3796ef +n7esXu3Fa9W
zS4qUcIWx8b67n972TLXvSj/bbf57vvl11+tfrt2rsvRFXfc4btfXbC0rtcV KZvfULu6/caS
JW7711SsaOs2boz3GK8LV+B6+w4csGrNmlnOYsWsdJ067nX6b1NdvfTadAnW 7SvY9s+1Tf/3
QMAAAABAVHCjSP35Z7xw4V9/4Q6Gg9RgBK6XmJw5ctjJkyd9P3ceONBmjB5t G99/33oMG+a7
v2mXLrbhbMjY//nnvvu0/OazB+DHt2yxfX4hRdRa8Me2bcED0o8/2uENG+yp tm2t66BB7j51
2/Kuvdv+upx9XRXOhoe4b7+15vXrW9uA+T02nn0uvQa1yHQbPDjB+sG2f65t JvUeCBgAAACI
3IAR0NUpsMg7WA1GsPWCOXLsmOXLk8f3c+xHH1mZBg2scIUKtn3XLt/9H86e 7Voxjh0/7rtv
5sKFNrBbN9fdKlCrxo0Tfc6urVq5dR5v3tw++eqrZO0HtSb069zZt/7aL76I t7xPx45um03q
1bMf9u0LyTaTeg8pRQ0GAAAAwiZgHDtHUAhWg7EuGevJ62+/bfWrV49334nt 2y37eefFu6/8
bbfZFZddZrVatLDV8+f77j999vmCnZ0PXN+fF0hOnjplOXPmTPa+iPEbpjex ber61NnthmKb
Sb2HlKIFAwAAAGHBDTf7V1cnhQev9sL/9rnWC0ajSKkWYuQrr1jvjh1995ct XdqGTZwYdJ3L
LrnE1m3a5Pv5rnLlrPuQIW5bKTFx5kx3PXD8eKtbrZrv/lxnw4Z/HYS/KmXK WP+xY91tFaXX
rlo1zfs2PbZJwAAAAEBY86+lCFZrEXgtr56jBkMFzBfecIPNXbzYPpg1y672 G9L25eeec/dn
L1rUFT57Cp49GC9SqZJb7pkyYoR9uXmzK4S+LgUH567lolgx1x1rVO/evvtV +1G1SRNXAB5o
8vDhFrtmjVvvnQ8+sBcGDEjzvk2PbSYm2xmvbQkAAADIQAMHDrT+LVr4fh59 Ngysu/lmm7Nh
gwsRgbUWgddz/woLWkfmnA0L4UThJlgRd8R+XjNmWP/+/c/5OGowAAAAEBbU 1en6jRtt4F+t
EwPOXiafDRGJXcvnGlo1Ls7eXbaMHRgmCBgAAAAICyv95oJItrPhYsW//hWW 7ydXCoq6CRgA
AABAiIVrUEitUM0rEWko8gYAAABAwAAAAABAwAAAAAAyhEZx6jpoUND7U7u9 1NAQuGXvv5+A
AQAAAESyHNmzuzkf1m3cmGmvYe0XX7jrfHnyZOrrIGAAAAAAaXTi5El7YeBA a92zZ6a9hkmz
Z1u7Jk2sT8eO9uLrr2eJ/c4oUgAAAIhade66y2YvWmSjJk+27m3bJli+78AB a96tm63+9FMr
cf31tmDiRLv2qqt8y+q3a2cbt22zfp06xVtvx+7dVrtlS9u7f7/NGjfO6t19 d4JtH/z5Z5v/
3nv20uDBlvvCC13Q0X2XXnxxVO9zWjAAAAAQ1cb07Wvjp061PT/+mGBZl4ED rcJtt1nct99a
8/r1rW2vXvGWVS1b1o5t3mwF8uePt17ns8tmjB5tG99/33oMGxb0eV+dM8ca 1qzpwoU0O7v9
qW++GfX7m4ABAACAqHbFZZdZnyeesPZ9+iRYtjg21vp17uxud23Vylcz4S0b 9OSTFhMTYy0a
Noy3XuxHH1mZBg2scIUKtn3XrgTbPX36tL06d661a9rUd1+TevVs4syZUb+/ 6SIFAACAqNeh
WTObuXChLVq+PMGymGzZgq6jkJD9vPN8twOd2L7dtzzQkn/9y3bv3WuVGjcO ukxdtwgYAAAA
QASbMmKE3dO8uRtdylOlTBnrP3asDX7qKRs3darVrlrVt6xs6dI2bOJE6/To o/b00KHxtuUt
C6zN8IyfNs1G9+ljT7ZpkyBcjJ0yJaoDBl2kAAAAkCUUL1LEWjVu7EaX8kwe Ptxi16yxnMWK
uSFtXxgwwLfs5eees6nz59uVZ0NIpTvuiLctLZu7eLFlL1rUzXPhT12mVn3y iau5CKRgoVqQ
b3bujNr9nO3MWXzdAAAAkNEGDhxo/Vu0YEdEyuc1Y4b179//nI+jBQMAAABA yBAwAAAAABAw
AAAAAIQfRpECAABA1Pvoyy/t4W7d7Ptdu+z888+3+tWru4LuS/LlY+cQMAAA AICUUbjo07ev
NW/e3I4dO2ajn3/eKj7wgG2JjWXnhBhdpAAAABD11HKhcKHWi0suucSGnQ0Y 27//nh2TDmjB
AAAAQKbR0KcZ4cILL7TDhw/b5Zdf7n5+8cUX7cpChTLs+QkYAAAAQDpLzpwK ofL999/b+PHj
bdiwYTZp0iR7+umnbenSpValShU+CAIGAAAAkDIjR460ihUr2qhRo6xcuXL2 97//3fLmzcuO
IWAAAAAAKae6iy1btvh+njdvnh06dIgdQ8AAAAAA0u6hhx5iJ6QTRpECAABA lqQWjKpVq9of
f/zBziBgAAAAAGmjblOFCxe24cOHszMIGAAAAEDaDRgwwIYOHWorVqxgZ4RI smswsmXLxt4C
ACTqzJkz7AQAEefqq6+2adOm2SOPPGKfffaZb54MZEDA4J8HACAxnIQCEMma NWtmmzZtsiZN
mri5MTTbNzIoYAAAAADRSBPwxcbGEi5CgBoMAAAA4Ky7777bjh07ZtOnT2dn pEG6tWDs3bvX
+j/7bIL7Bw4aZAUKFGDPAwAAIOycPHnSRo8ebcePH7fHH3+cHRIuAcMLF5Nf ey3BsrZt2gS9
HwAAAMhsefPmtdmzZ9stt9xi1157rdWsWZOdkkJp7iKlMKHiPl17goULBQv/ xwAAAADhqGTJ
kjZ58mRr27at/fjjj+yQjA4YBQsWjHctibVQKHioixQAAAAQzlq1amXNmzd3 I0sx03cGB4w9
e/bEuz6XYHUZmqL99OnTvp91O2fOnLZ169Z4jytUqJD98ssvKXp9iQ2d+N57 77nteSMFpNcQ
i9quLtmzZ7cSJUrY6tWr+dYBAABEAI0s1adPH0aWSqE012CoYNt/fgx1g/Jv zfDCR1J1F/fe
e68tX77c18dt7dq17oD8yy+/tOLFi7v7Vq1aZWXLlrV8+fKF5I23bt3ajXNc qlSpdN/J3v55
4403XBLetWsX3zwAAIAI4I0stWDBAnv00UfZIRkRMAIpXAROyKcz+ElN0vfA Aw+4adq9gLFu
3TqrXbu2Cx1qlvIOztu0aROy16n+dBkRLgLfZ8uWLfnWAQAARBBGlkqZsJgH Q1O079692314
8u9//9sefPBBW79+ve8xH3/8sVWvXt3d3rdvn1WrVs11oypdurTt2LEjXphZ vHhxgqYsbbtO
nTo2YcIEX3cor/tSoMS2r4IfLZO4uDi3XK0t8s033yQZWNTta/Dgwda/f3++ dQAAABFEI0vN
mDHDOnXqZHPmzGGHpHfAUJcojRDVNo2tC/fdd58tXLjQ3f7Xv/5lDRs2tO3b t7tgoO5R6kbl
6dKli1WoUMEd5KvLkSr8/al1wr8YRwf3Dz/8sLVr1846d+7sa03RdbCWlcS2 r9f0zjvvuNt6
rbfeequr5RBd6z0EoxBz3nnnufelgiEAAABEFp10fuutt6xjx462bNkydkgS 0tRFKth8F6q3
CGwVSE4BuFoslApvvvlmK1y4sMXExFiVKlXcQblaJBQMPPrZS49du3a1vn37 xttW4EG86i2e
eOIJK1++fLLeV2Lb12vUl6pDhw62aNEiGzNmjPtZLRP6oo0aNSro9hRiFHIm TZpkjRo1coEJ
AAAAkaV+/fqul4y68KsXi1crjBAGjGDzXQQWfSdX/vz57aeffrIePXrYP//5 T3efPrTXzm7/
4MGDdt1118V7vAJIom8qe/YEP2sbKRFs+3o96iKlban7lorO8+TJYz/88IPr RqVRopLanvrs
KbAAAAAgMqlm+LPPPrOiRYuyMxI77g31BoNNqOdNxhc4IV+gpk2b2rvvvmuV KlVyP99+++02
f/58X6G3Ry0bXi3DuHHjXEF4UjRRyuuvv+7rznQuSW1f3aTUmuIVpNetW9d1 qbr//vuT3KZa
MFT/oVkhAQAAELm8cKFjVI0uhRAGDE2aF1h7oRYNtWx4QcIbttard9DtxEKG DtJVq+C1VqjG
IUeOHC54BAaG2NhYV2StmogXXnjhnK913rx5NnbsWDcy1bkktX01jSn0KFhI vXr1XD1GgwYN
Et2egpW2pfX4EgIAAEQHHaMqZGi0U/gd+55JZn+mxIaa9eowgh6onw0b3npe XYZ3OzXdqAAA
YfrPhL/rALKoDRs2uB4uzZo1c9MuIEQT7fnXYXiBQ60bAAAAQDTTNAaaHFrz nakHjCbmI2CE
mBcuFDzEG1XKO7Ol28kZVQoAAACIBLlz53Z1xBpYSFMlKHBoMKCsKuRF3mrN 8MKFBI4qpdv+
ywEAAIBI541iquFrK1asmKUn5Ivh6wAAAACERtWqVd2gPll5Qj4CBgAAABBC GnV07ty5boSp
rVu3Zrn3n6IajMAZugEAAAAklJUn5EtRwGAIQgBAMJyAAoCE/Cfk01C2jRo1 yhLvmy5SAAAA
QDryJuSbMWMGAQMAAABA2tStW9fWrVtno0aNspYtW9rhw4cJGAAAAEA4ibSu mZqQTzUZJ0+e
tCVLlkR1yCBgAAAAIF2VKlWKnXDW+eefbzNnzrQ6derYDTfc4IIGAQMAAABR 6ciRI9aiRYtU
L0/K+vXrM+U9Pfzww+51p3Z5esmbN68LGnr+aJwrIzu/TgAAAFnbqlWr7LHH HrPOnTsne/mO
HTusdu3atnfvXps1a5bVq1fPnnjiCStevLi7jo2NtYkTJ9rChQvd470uTRqV NNi63mP0+Pbt
27ufX3nlFTenhOzbt8/d3rhxo/Xr1y/e63v77betS5cuFhcXZ/v37/fdX758 eStTpoy9/PLL
Vrly5QTv61zL09Pdd9/tmytDs39rvxEwAAAAENF0QN67d29bs2aNLV68OMGc DUktV9jQqEiX
X3651ahRw4WE4cOHW4UKFeyRRx6xwYMH25tvvukO/hUc/Kc7CLauRwFCYUIH 3926dfMFDAUI
zZKtg3Gd/fenUZq0Tr58+eLd36FDB6tevbprKShbtqwNHTrUcubMmezl6c1/ rgzVZKhlIxrQ
RQoAACCLKl26tB08eNAdtAebEC6p5Wqh0Nn/woUL2/bt2919uXPntueee86F DB2858+fP+jz
BlvX06dPH4uJiXFn9n/44Qff/Qo4gwYNcssCu2p9+OGHLsgcO3YswXNde+21 LiD99NNP7v2k
dHl688JFNNVk0IIBAACQRal7Ups2bax79+727LPP2kUXXZSi5SdOnLDs2eMf TubJk8eOHj1q
f/vb35J87mDrigKEd33q1Cnf/adPn/Y9Xrf9qavTFVdcYbVq1bLVq1fHW6bQ MWDAANcyMmfO
nATPd67lGcGryXjggQdcy41aNiIZLRgAAABZlEZ3+vzzz+3KK6+02267zR3c Jne5uhQNGzYs
3uNVMN2jRw/7z3/+4wKJWgUkV65cru4iqXXPxVtHz6F6kECXXXaZm2vC3+zZ s12rhF6/3oeG
ik3J8ozkX5OxdetWAgYAAAAiV9euXV0ht7ohJXe5CqN1QKxWBa9rUadOnVyB t7pG9ezZ01cU
rnoL1U94LSDB1j0XrTN16lQXBipVqhRvWcGCBa1IkSLuMf5UMK7XrdcfzLmW ZzSvJkMF38G6
e0WKbGf8K26SemBAcQ4AAPyPAIDQU7hQi838+fMjcnQpWjAAAACAMKJieXUH a9CgQUS2ZBAw
AAAAgDCj2b41GlewehMCBgAAAIAUGzt2rJsn5I8//iBgAAAAAEgbdZVq1KiR FStWLMF8IQQM
AAAAACl2/vnn20MPPWSjR48mYAAZQSPXpKcLL7wwWc/l/zgAAIBQ6tKli82b N88OHTpEwAAi
3fHjx0P6OAAAgJTS3B9PPfWUbdiwgYABAAAAIO26d+9uLVq0iIhajOx8XIgk X331lRuy7bff
frPq1avHW6aZOHXfiRMnrHfv3vbcc8+5+3v06GFjxoxxk4CdOnXK3bdz504r V66c/fjjjxYT
E+O7X92g+vTpY0OGDHGPD5w8TDN9Tpgwwc477zybNm2aNW/e3Lee9zjdfuaZ Z+z555/3Pb/G
spZ169ZZ5cqV3evX8HNLlixhcjIAAHBO/rUYgTOWhxtaMBBR6tatazfffLML EVdddVW8ZY0b
N3a/cB999JGNHDnSd79uf/vtt74QIbVq1bKiRYu67fjfL7t27Ur0oF/BJC4u zk1807Fjx0Rf
56effmp//vmntW/f3kaNGuW7//777/e9/rx58/KBAgCAZIuUWgwCBiLKf//7 X/vggw8se/bs
Nnny5HjLDhw4YK1bt7by5cu7EOBR6Bg4cKDt37/fd9+2bdtsxYoVbjuBArfr 76233nLrzJkz
x44cOZLo495//333OLV2nDx50nf/7t27fa9/5syZfKAAACDZvFqMrVu3EjCA UFITofgfuHt+
//131/rg3wLRoUMHa9mypV133XXxHhtsff/tB+MFknNNeOM9LliASer1AwAA JKVv375WsWJF
AgYQKnny5HHdm/bs2WMlS5aMt0xdju69996g6xUvXjxei8Oll15qZcuWTfFB vvo+imbVDOyi
lRwXXXSRe/3qalWiRAk+UAAAEHUIGIgo6lakYu5ChQpZlSpV4i2bPXu2rVmz xhVZ+89LoVaE
AgUKWJs2bXz3LV++3B3k58iRw3LmzJns51ddhba/fv16e/vtt1P8+l999VX3 +osUKWJ33XUX
HygAAIg62c4kcwibwNF0AKSNWmEUlE6fPs3OQOT/M+F/BADwN/cvtGAAmURD 3N54443sCAAA
kCKqOQ1nzIMBZCB13dIfBZ15uPbaa92IUgAAAMmlgWZUS7pv3z7LnTs3AQPI 6o4fP85OAIAs
5NixY76DQM3TdPjwYTeHgSZ61aSsUrVqVfc4736diNJAJFpPw5Jefvnl1rNn TzeYSWxsrJvH
6ZJLLnE1hkmNfIjopJm89Z0I13BBwAAAAEgHCgrjx4+34cOH2/fff29XX321 vfTSSy5gKBwo
OHj69+/vDhZ1vw4cZe7cubZp0yZf6PCCxIgRI9wBpu5XKNG6AwYMYIdnIStX rrQKFSqE9Wsk
YAAAAISQQsWQIUOsUaNG9uWXX7pw4YWGYAJHRZTChQu7SyD/rrXqKqMJaOW5 555zk7w++OCD
bkh1hRVEp127dlm1atUIGAAAANFMLQpqqbjtttvs7rvvtkcffdTXGpFe1Kqh 7lLStWtX1yry
xhtv2NNPP+2GdVfA0XxPwSZ9ReQaPHhw2HeN4xsHhICKt6mvAICsGSymT59u o0ePti5duriA
oUtGUxcrhRpd9Jq8/vn33HOPa81o2LChCz60bEQ2dZe74YYbXIF3OIcMhqkF QiDch4sDAISe
6iluueUW++6772z16tW+ou3MphDhHXwuXbrUdZtSy0axYsVc3YYuatlA5FEd j7rU0YIBZDLN
nF29enU7ceKE9e7d2zp16uRm9t69e7cVLFjQPUZne9SUrcnvtm7dGu/x6tcq GlpW/zyef/55
93OPHj1s2LBh7n5vuTDZGABEL/2/UH2FWitUI7Fx40Y3ulO40oGoukrp4o1o pRaXfv36ufua
NWuWKS0uSDl9fvrs1P0t3NGCgajXuHFje/nll93wgCNHjrT8+fNbqVKlrEOH Dr7HtG/f3u68
8063LPDx/j799FP7888/3eNHjRoVL1DomnABANFJXVO6detmN998syus9s4g h3O4COR1m1I3
KhWfFylSxB577DGbNWuWu19F4whfqvGpU6dO0EEBwg0tGIh6Bw4csNatW8e7 T60QNWvW9P38
7rvv2tq1axN9vEcjdKhYbsKECS6EAACimw66FSZ00kn0vyLY6E6RRt2onnji CXfxuktp7g39
j2vRooU1aNDA18qP8FCiRImIOfYgYCBLUI2Ef39FDe928cUXW69evVyLhEbh uPXWWxN9vO8X
5q+ROBiRAwCiP1iMGzfOZsyY4c72e92MopH3P03hacmSJa5FQ13ApkyZ4lo7 kPn0uei4RIX6
kYAuUoh6ar6+9957E9z/7LPP2qRJk+y1117zdXdK6vHnoloPAEDkU+1doUKF bPPmza5IOqvM
lu3VayxatMi+/vprX0v/smXL6D6VyTTBogYViBQEDES92bNn25o1a1wRtoaT 9XTs2NG1Xui+
2rVrn/PxSdGZHp1ViInhVwoAIpHqKtTHXYoXL+5aLVRMGw3doVLj+uuv983j oZYMDY3q1Wog
Y6l7nmqA6tevHzGvOduZZFal6mCLAlYAAP8jEE10pl792hcsWGD9+/ePNwAI /t/KlSvdBH4a
JGXy5MnskAykehjNY9K8efOIec10JAcAAFnSO++84w7cNFRrtBRvpxeNXPTZ Z5+5M+miblNq
4VDgQPp64YUXIm6CRAIGAADIUjSfgM7Gq3B23bp19s9//pOdkkxetynVAzz8 8MOuTqNnz55u
hCOEngLdlVdeGXGvmw7jAAAgy9CBsYqYFTI0SR7hInUeeugh+/bbb93Bb8WK FSkCTwebNm2y
22+/PSJnXacFAwAAZAmqI2jSpIlt2bIlovqzhyuNujhs2DDr06ePG4FKo29p wJMyZcqwc0JA
+1ajekXi0Pi0YAAAgCwTLlTQHUmzb0cCb4Zw1Wm0bNnSFSV7I3Ihdfbs2WNv vPGG25+RiBYM
ZClqGleT7o4dO2zfvn1uWMJ///vftn37djfxXrB+jnrMoUOHXIFV4HJtY//+ /XbTTTdZ586d
rUaNGvzjAoAws23bNnfQO23atIga6jPSVKhQwXU7Gz58uKvPWL16NTsllTSa mYq7S5YsScAA
Mis06MzUK6+84ka4+Pvf/265cuWyI0eOuBm51S/0xIkTdurUqSS388svv9h3 332X6PJff/01
0eUff/yxu0iOHDnsggsucMN2BoaSo0ePuoCjP7wvvfRSlvucBg4caP/zP//j 9kG0u+qqq9yE
jUOHDiV0AplIRbI68NVcAjoZhHQ+sMye3fr27WvPPPOM+1nD/6r7VJ06ddg5 ydSrVy93/dhj
j0Xu94CPEZFE/yCGDBlin3zyifvZCxD+fvrppyS3ocnw9AdQf/D+9re/ufCh Cff+8Y9/2NVX
X53g8Um1YGjZwYMH3W29jri4OLc9XZIKJRMnTrR58+a5pk/9IY72A1CFi3vu ucfy5MnjziCW
Ll3ahbBopc9fZ/H69etn5cqVc+GTkAFkDp3MUasF4SLjg4bof2fbtm1ddx/V aAT7P4v4NPDA
U089FdmfPx8jwpnOeI8ZM8aFArVInD59Oujj1GqgwKDl+fPntzvvvNMXCPTH rGDBglasWDG3
LL0PpN9//333D239+vWu25X/H1O1YChw6Prnn3+20aNHu/eng+169eq593vd dddF5eeocBEb
G5slvrf6PipEqbVGrRi9e/d2oRJAxtJIUZp9euHCheyMTKK6DBXVv/rqq1a0 aFGbOnWqa8VH
QmptUz2LRuiK+IDJx4lwo5YAHZDqTLfqG/yp21HOnDntvPPOs1tvvdWdFale vXq6B4fk0lnq
Bx980F2S8x5fe+011zpy/Phx16Khi96fzvxo4if9QY4GOtDW55kVaRSQunXr 8osNZAJ1m23R
ogWTwWX2webZ/2mPP/64q1NUzwHRRH0KHzo5iP+j4HXffffZE088QcAAQmHX rl2u6VRNqL/9
9puvpUKBQmf39UdIYULX0dDVRH9QdeCpS/fu3V39iMa59rpZ6TJ58mR76623 oqIblWoudEY/
K7rhhhts9+7d/JIDGUwnb9q1a2dffvklOyNMFClSxHd7ypQprsZg8ODBDBl8 1rhx41yLW5s2
baIjVPJ1R2bRuNmjRo1yrRGqpfCng2kl+UGDBkV933XtA138g5ZaMtSq4d+N SoXrGpmjS5cu
Efk+o7nmIinqLgUg4+nkTMeOHX1DqCK8zJ8/3w3QohnVV61a5U6qZVX/+c9/ XK+GtWvXRk2L
DgEDmUJnLSZNmhTvPq9rkPoe6sxGVqR6Df2R1SWwG5V+7tq1q7344otu31Wr Vi0q3rNaqZLj
zJkz/OIASBYN76mzwdHQ1SSaqVeCurGp9kDUberyyy/Pcl3a9H6XLl1qxYsX j5r3RMBAhtKB
s8KFN2SsWi8UKJ599tmoLG5OC/9uVCNHjrT+/fsgWgR5AAAZLklEQVS7lh7N 2aGZUnVmXF2n
tO8iOVwkNzik5LEAsi4NtqEhUjUHQyTOgJwVKVR4n516L9SsWdN69uxpJUqU iPr3rsFPonH2
c37zkCE+/PBDN2mMDo49jzzyiKs9oMDr3NSErIv/ftRQqAodM2fOjMgWjZQG Bj02sXW8VhAd
TKjWQ13MrrnmmnNu88Ybb7Svv/46ze9DNNKZ+hdrBDENyQsgc2g480qVKmXZ uq9IphOOChcj
RoywihUruslso/kYYfbs2a5btIY1j7YwTMBAutLZdx0Ee/NCiM68a/IxFTcj ZRQiVDDtv1+j
qUUjLRQ8NDiAalR0BkwHGeeS3HBxriDihR6NlPXoo4/anj17+LICmUSDY5xr JD+EL9Vd6n+c
6jQVLnQAHo1n+NUlqlWrVu5/VTS2tBEwkC6CtVho/Otoqh3ITJrlU5doatEI BbUiqCA+1EWd
GsM9OTQcpoZiBJA5NBrf9OnTXQ0GIpv3d1x1GirYV33C2LFjrXDhwhH/3jSw i3pwfPDBB3b7
7bdH5edHwEBIaTIxnUHWH3lPVj+znp5o0UhIdT26eH744QfX7P7pp5+6Op+3 337brr/+erfM
v8uVbqu5unPnzu7nCRMmWNOmTX1doLzrxLp1qfVE/b7VlQ1AJh3U/HUmmJGj okeFChVcFyKN
oqjWadXWRLIFCxa4k4MrVqxwkwFH7e8iX12ESuDIULRYZBxaNP7/IH/IkCHx ZkHV97Js2bK2
Zs0aN966mqR1O5gNGzbYgQMH3ChmPXr0cAEjqdoPjxc+7rjjDlu0aBFfSAAI cXDUCTOdxPEO
0tV9qk6dOhHzHtQVSqNFNWrUyF2i/jPja4u0ev/99+3ee++NNzKUzv7SVSTj natFQ8PeKohE
I2+W9/r168cbT11N0AsXLnS31adX9T+J0TJ1s2rdurULasnl1X9ozhI9/yef fMKXEQDSIWjI
JZdc4ibf1eS8GmXRG4UqXKnbnlq3586d6/4fZ4nPiq8r0kJzNGimVO/sLiND hYfEWjR69+7t
7tPZn2ibwDCpFgb/LlNJUbjwrr3Z5JNL6+gfiPYxACD9qC5DtXE6BtGofToO +e2339wJnnCa
S0LzV6l+5KuvvnJdorLCsLu+/4l8TZFadevWdWcQdGCnA7g5c+bYjBkzCBdh xGvR0NCp3pkf
BYxLL73UjcyRFWjkEW/EMnWfuuuuu1K8DbWMbNu2LcnHKJCo5eimm27iiwcA 6Uz/03QC7csv
v7RbbrnF/Y2uWrWqG6L8888/z/TXp4ke9Rr1P0EzdGelcOE+H76iSCk18Wm0 HG/oWR3ELlmy
hGARxtRdTZdx48a5yYvi4uKsX79+NmjQINe8rML85NKsq1r3+eeft5IlS6b6 NSWntsFfaifa
U9N0w4YNXRcxjYuv1puUUg2Lgsmvv/7q/mkEe21qwdD2ve5YAICMCRoqBNdF FC5UAyoKHqp7
qFGjhptfI71b7tViodnIdbJ15cqVbpAR1Y5kyc+FryaS+0uj/vsa53///v2+ +zVkXNeuXdlB
EUKflc74qBlZtTMKibpPQUPNuPpDeK4/wGqKVnOv1tfBtLaV1pCR3MemZpnO Zn3xxRfnXC9w
G/4/a9/oktLnBgBkrNtuu813W/+jdFJJB/wagUpzGulkkU6MqptVKEYbO3To kNuOTrLWqlXL
3db2VQuYlUczI2AgSe+++66bsEhnvL0ibq+YVuOMq4sUIov+CHpnWNq3b+9C xs8//+wKlDWH
RK5cudxwgIm1amzevNl3u0GDBm4YXIXPtIQMAABCTXNmqIusLmp9/v777y02 NtYVhyuIKAB0
69bNChYs6IqvVb+RnN4Y2pZ6bmhoc7VU6OSrRobSoCLROGkeAQMhFVjArTPb OgOgs93RViCc
Fambmy5e65Q+b52J0c9q1XjxxRcTDG97+PDheLOyi74PGt6VrkEAgHClMKE6 iMBaiDvvvNNW
rVrlTropgAR2g/WfK8mfumSp+61aKrxRrAgXBIwMozH1NTTmpk2b3ORzagXw RqfRF1HF0UrL
TZo0SdGwmOlNBdxK597rHD9+PMPORil9/1ScrIvqMTS87e+//+4b3tZ/PhOF jmA090OxYsVc
fQbhEwAQKTRvkjd3ksJFYt2aaG0nYISFESNG2OLFi11RaGK82a41tJoO3DTS z9VXX+2KZ9VP
MKPpzLWGNtVr8V4bBdxZi4ZZ1cV/eFv/eTQuvPDCRNfV4/T9VcjQjNkAAEQS ZoAnYIStWbNm
2cSJE+3IkSMpXlfpWM1zjRs3diMfaKSe9D5QU6gYNWqUe90aztR/7H8KuLMu b3jbwHk0kgrM
ou+9huSbP39+moq/ASC1/9NE3T01GRsAAkbE08G4iodCQeM6K2ho0jr1Dww1 hRe1sqilwr/Z
T30M1W2rR48ehAv4gob3fQmsvwhG36lgxd/JHS0qWqV2mF0AyafWdg1HqsJb Fd0CIGBELJ0x
0R80nTEJJR2otW7d2k2IFqqzwf5npP0PfDTSgkaL0hwJ9KFHoMGDB7vRpRQ0 kiuw+DsrH1xn
9XAFZKTKlSu7YbQJGAABI6KlR7jwp7kJLrvsMitXrlxIg4X61KuYe8qUKYQK nNM777yT4nVU
/F2kSBF2HoAMo9F91qxZw44ACBiRq1OnTukaLjwaLvbNN99McfG3/8zNHv9R gYDkWr9+farW
27Fjh7seMmSIG1ENANI7YFSsWJEdARAwItPUqVNtxYoVGfZ8zZo1c7UZyaFC c/WZ3717N8EC
aabZ25NTf+F1BQrWHUrdrAgYAAAQMJAEHaxnJB3gaY6CxGZN1iRoGmZWI0J5 E8XogE995zWL
pQ7wgNSYO3eu73ZMTIwLEMFCROCAASq41H2qU+rduzc7EgAAAgYSM3ToUDt+ /HiGP+/bb7+d
IGBo3oEnn3zSPv74Y98wszqwU32FJk7T3ARAWixbtsx3238oY4UNjRuuGqGC BQvaDTfcYLfe
eqtVqlQp3hDLChsaVQoA0htD1QIEjIj17rvvZsrz6mywwsSYMWN89zVt2tRX vK0/ppoorXPn
zkyOh5DRcMka0eziiy+2kiVLWunSpd2gAwwOACDcMFQtQMCISN98840dPXo0 054/sNhWrRTq
2z5hwgTqK5Au1AoWqjleACC9MVQtQMCIOJqXIjOp4Naf5shg1mQAAP4PQ9UC mSuGXZByasHI
bBldYA4AQCQFjCVLlrAjAAJG5NAM25lt69atfBAAAAAgYBAwQmPnzp18EAAA AAg71GCkwqlT
pzL9NRw8eJAPAhHFm4QPAAAQMBBAY/9ndsjIkSMHHwQiSrCJ+bJSuMrK7x8A kMWOldkFqQsY
me2qq67igwAAAAABIxpkz575DT+FCxfmgwAAwI9aCw8fPsyOAAgYkSccuieV L1+eDwIAgADL
li1jJwAEjMhz3333ZerzqwWlZs2afBAAAAR444033HVg3ZOCxwUXXMAOAggY 4alnz56Z+vwF
CxbkQwAAIAivBSNw5LpatWrZH3/8wQ4CCBjhq0CBApn23LVr1+YDAAAgQJky ZVyIOHbsmOXO
ndt3/6RJk9z12rVr2UkAASN8Pfvss5nyvBdffLF17NiRDwBRJ73nybjxxhuT 9Vz+jwMQWbwu
zIcOHbJLLrnEd/9jjz3mCyAACBhhq0KFCplyIEK4AFLn66+/DunjAISf+vXr u+tvvvnGihYt
Gi9cbNmyhR0EEDDCX9++fTP0+RRoHnzwQXY8AABBFC9e3F1fdNFF9sEHH7ju Uuoedfnll/uW
AUh/zOSdBiVLlrQXXnjBOnXqlO7PpZEv5syZw05H1Pjhhx+sbt26tm3bNnvq qafiLdN9Ksg8
cOCATZkyxResZ8+ebd27d7cTJ064LhCi62bNmtnKlSvdQcXBgwfd/eoGNW/e PHvkkUfszz//
TDCb9rRp09zvbt68ee3NN9+0cuXK+dbzHqfbes7OnTu7nydMmGBNmzZ1t3ft 2uW6Y+i1PvPM
MzZgwABm6wbCxFtvveW6Q+nviNB6ARAwIkrVqlXdQYqCRnrRQc6HH34YFhP8 AaGibgsVK1a0
L774wl555ZV4yx5//HGbPn26GzHtnnvu8QWMVq1a2Z49e+L1re7SpYvddNNN tnTpUouJid8o
u2/fPhcugvnvf/9rR44csVGjRrltfPbZZ0Eft2HDBl/Q6dGjhy9gKHR4r1/B A0D4eO2119xg
LDrxoG5TOpEAIOPQRSoE2rdvb88//3y6bPvCCy90o17ozCwQTdR9QQf3CgVe H2nPRx99ZJUr
V3Z9qNVS4Hnvvfds7ty5Lhh4FixY4NtOoKRqlvr06ePWUYvIV199lejjhg4d 6h7XunVrF1g8
y5cv9z1v165d+UCBMKEwodm8vSHl9TcDQMbilHiIaOhYnS1p2bKl674RCsWK FbP58+fTcoGo
dPr0acuRI4fvdqC4uDjfck+1atXsyiuvdNf+LQ6nTp0KGjAC1/fnPV6/r8l5 nK79X+fJkyeT
fP0AMocmolX3SP1uq/vi+eefz04BMhgtGCFUqlQpW7FiRZpn2c6XL5/169fP Fi5cSLhA1Cpd
urQbKEFnGlu0aJFgmX4Hgrniiits06ZNvp9VO6GWipQe5I8cOdJd6yynumGl 5vddr181IA8/
/DAfKBAm/AdDGTZsGDsEyAQcvYaYmmbVbUJnTXr16mVbt261X3755dxJLybG nZmtUqWK6+cN
RDvVXdSrV8/VL4wdO9ZmzZoVb9n999/vQoBGftm8ebO7P3/+/K61YsyYMb7H vv7669aoUSPL
lSuX+x3auXNnsp7fayFR/cY777yT4tf/0ksvuef1Xr/OmALJke0m9kG6OlXl /64LTGNfJ+HM
ZvYB0vHv3JlkDnsSOAILku/48ePugGnjxo22Y8cOd2AjhQsXtn/84x+ur7kO VICo/UMT5X8/
1AqjcKPZg7Pq30/+R6QsYHBwB76DiGa0YGQAFWp369aNHQFEKRWCN2zYkB0B AAABAwBSRxNf
qjuWulnVqFHDXn75ZXYKAAAEDABIna+//pqdgJBIS51Au7rr7JXht7ITARAw AADAX04ftXb3
fZPi1V595zr2HQACBgAASCjuz6P20vCKKQwYx916ABBumAcDQMTRiEVA1Dh9 LGPXAwACBgAA
0S21LRHB1lMA79q1a8iCeWrX04SZZcuW5cMFCBgAACBDnT4a0vU0spkmj1y3 bl2mvaW1a9e6
63z58mXq6wCQOajBABC2Dh06ZM2aNbOVK1faRRddZAcPHvQtmzNnjnXp0sXN 7P3CCy+4x4nO
mm7ZssUdZGkm8Pbt27v7dRZ29uzZ1rlzZ/ezZuBu2rSpu71r1y677777bNu2 bfbMM8/YgAED
fJPG6b5atWrZgQMHbMqUKfbggw/ywSDk4v48FrL1Tpw44X4nWrdubV999VWm vJ9JkyZZu3bt
7Oabb7YXX3zRpk2bxocMEDAAIPMpQNx00022dOlSi4mJ3+C6YcMG279/vztw efLJJ30B44sv
vvAtv+uuu3wBw7vPCwo9evTwBQyFjooVK7p1FTz8Pf744zZ9+nQrWLCg3XPP PQQMhF6IWzCk
Tp06LlCPGjXKunfvnmD5vn37rHnz5rZ69WorUaKELViwwK699lrfsvr169vG jRutX79+8dbb
sWOH1a5d2/bu3WuzZs2yevXqJdi2TgTMnz/fXnrpJcudO7cLOrrv0ksv5bMG sgi6SAEIWzro
0QFSYLgQzZ6t+3XwopYOj1o77r33XhcYfvrpp0TX0UGUZ/ny5b7nCey7/tFH H1nlypWtaNGi
rqUDSA9//nE05OuNGTPGxo8fb3v27Aka3itUqGBxcXEuaLRt2zbesqpVq9qx Y8esQIEC8dZT
GJ8xY4YLHwrpwbz66qtuZnuFC1H4nzp1Kh8yQMAAgPCgLlBB/3j5hY7Tp0/7 butgRmdf1VKR
2Dq69l/n5MmTrktV4LY8OghTl6nEXguQJunQgiFXXHGF9enTJ14rnmfx4sW+ 1gmFaq9mwls2
aNAg93vSokWLeOvFxsZamTJlrHDhwrZ9+/aEL+ns748ChrpHeZo0aWITJ07k cwayELpIAQhb
5cqVs44dO7r+3MFaMYJRa0bNmjVt0aJFyX6eUqVKWd++fV1XK5299aeaDh2I DR8+nA8E6ZSi
j6ZuFKlkrNehQwebOXNm0N+HxH6nFBKyZ8+eaOBWjYe3PNCSJUts9+7dVqlS paDL1HULAAED
ADLN66+/bo0aNbJcuXLZlVdeaTt37jznOgojt9xyS4KgkBT1FdfzqP5i7Nix Nm/ePN+yV155
xe6//35XMF68eHHbvHkzHwxC6/Sx1BV5J3M91RypfshrpZMqVapY//79bfDg wTZu3DhXV+HR
0LLDhg2zTp062dNPPx1vW96ywNoMj7pkjR492oX1wHCh3y0CBkDAAICQ+f33 3+2CCy5I0TqF
ChWyTz75JMH93ghPwX5u2bKlu4j/QVBS69xxxx3urKscPnzYunXr5ltWsmTJ oF1Bkktne4Gk
g8JRO3J4b7qtp2DcqlUr1+3JM3nyZGvcuLGNGDHChQb/UP3yyy9b3bp13TLd Vpcn/2UK3AMH
DnS/G96gCqLfk1WrVrkR3gIpWKjY/JtvvrHrrruOzxwgYABA2hQrVswdiJQv Xz7sX6sKwVWg
GioaMveqq67iS4Akg0Jcaoq8E1kvMEyLAoEu/uHdv+7C34033mjfffed72dv hDYvrHz99ddB
19NACKpnSszWrVv5rAECBgCEhkZ1UncMFYiGIx1QqfuVupDUqFHDnaUNlV69 ern3DyQeFI7Z
xl3X298KPZfiVVM7AzgAEDAARDSFCw0be/fdd7uzqOqS5N8fPLMldkY2tdQt Si0XChc6a6v5
CIDEXJNvZarXjfuT/QeAgAEgC8qbN6+b0Evh4pFHHnGTdUU7dYvSaFYKF3r/ QGJ2bFvBTgBA
wACA1IQMjSKjCwAAiF5MtAcAAAAgZGjBAAAgg2W7iX0AgIABAABC5AzzNYKA iyhGFykAAAAA
BAwAAAAABAwAAAAABAwAAAAAIGAAAAAAIGAAAAAAIGAAAAAAIGAAAAAAAAED AAAAAAEDAAAA
AAEDAAAAAAgYAAAAAAgYAAAAAAgYAAAAAAgYAAAAAEDAAAAAAEDAAAAAAEDA AAAAAAACBgAA
AAACBgAAAAACBgAAAAACBgAAAAAQMAAAAAAQMAAAAAAQMAAAAACAgAEAAACA gAEAAACAgAEA
AACAgAEAAAAABAwAAAAABAwAAAAABAwAAAAAIGAAAAAAIGAAAAAAIGAAAAAA yDKyp+TB2bJl
Y48BAAAASHvAOHPmDHsLAAAAQJLoIgUAAACAgAEAAACAgAEAAACAgAEAAAAA BAwAAAAABAwA
AAAABAwAAAAABAwAAAAAIGAAAAAAIGAAAAAAIGAAAAAAAAEDAAAAAAEDAAAA AAEDAAAAAAED
AAAAAAgYAAAAAAgYAAAAAAgYAAAAAEDAAAAAAEDAAAAAAEDAAAAAAEDAAAAA AAACBgAAAAAC
BgAAAAACBgAAAAAQMAAAAAAQMAAAAAAQMAAAAAAQMAAAAACAgAEAAACAgAEA AACAgAEAAAAA
BAwAAAAABAwAAAAABAwAAAAABAwAAAAAIGAAAAAAIGAAAAAAIGAAAAAAAAED AAAAAAEDAAAA
AAEDAAAAAAEDAAAAAAgYAAAAAAgYAAAAAAgYAAAAAEDAAAAAAEDAAAAAAEDA AAAAAEDAAAAA
AAACBgAAAAACBgAAAAACBgAAAAACBrsAAAAAAAEDAAAAAAEDAAAAAAEDAAAA AAgYAAAAAAgY
AAAAAAgYAAAAAAgYAAAAAEDAAAAAAEDAAAAAAEDAAAAAAAACBgAAAAACBgAA AAACBgAAAAAC
BgAAAAAQMAAAAAAQMAAAAAAQMAAAAACAgAEAAACAgAEAAACAgAEAAACAgAEA AAAABAwAAAAA
BAwAAAAABAwAAAAAIGAAAAAAIGAAAAAAIGAAAAAAIGAAAAAAAAEDAAAAAAED AAAAAAEDAAAA
AAgYAAAAAAgYAAAAAAgYAAAAAAgYAAAAAEDAAAAAAEDAAAAAAEDAAAAAAAAC BgAAAAACBgAA
AAACBgAAAAACBgAAAAAQMAAAAAAQMAAAAAAQMAAAAACAgAEAAACAgAEAAACA gAEAAACAgAEA
AAAABAwAAAAABAwAAAAABAwAAAAABAwAAAAAIGAAAAAAIGAAAAAAIGAAAAAA AAEDAAAAAAED
AAAAAAEDAAAAAAEDAAAAAAgYAAAAAAgYAAAAAAgYAAAAAEDAAAAAAEDAAAAA AEDAAAAAAEDA
AAAAAAACBgAAAAACBgAAAAACBgAAAAAQMAAAAAAQMAAAAAAQMAAAAAAQMAAA AACAgAEAAACA
gAEAAACAgAEAAAAABAwAAAAABAwAAAAABAwAAAAABAwAAAAAIGAAAAAAIGAA AAAAIGAAAAAA
AAEDAAAAAAEDAAAAAAEDAAAAAAEDAAAAAAgYAAAAADJJdnYBAAAZK9tN7AMA BAwAABACZzaz
DwBEN7pIAQAAACBgAAAAACBgAAAAACBgAAAAAAABAwAAAAABAwAAAAABAwAA AAABAwAAAABC
4X8BVXhf3q8VmOMAAAAASUVORK5CYII=
name="gmf_2.2.0_M5a.png"
filename="gmf_2.2.0_M5a.png"
iVBORw0KGgoAAAANSUhEUgAAAvsAAAIqCAYAAAC644XEAAAAIGNIUk0AAHom AACAhAAA+gAA
AAZiS0dEAP8A/wD/oL2nkwAAAAlwSFlzAAAOxAAADsQBlSsOGwAAIABJREFU eNrt3QmclWXZ
P/BbJSuzzFLTtCxBXHHBTHBBrNwVcQtBNglFDEENLFEzl8J8LXHDDTUEF8wS XChNzAVTA/8a
tCCBiqaIkKAMoqx/r+f1zDszzMDMMMtZvt/PZz4zc86cmTnXM8vvuZ/rvu/1 Vn0sAQAARWd9
JQAAAGEfAAAQ9gEAAGEfAAAQ9gEAAGEfAACEfSUAAABhHwAAEPYBAABhHwAA EPYBAABhHwAA
hH0lAAAAYR8AABD2AQAAYR8AABD2AQAAYR8AAIR9JQAAAGEfAAAQ9gEAAGEf itCMGTPSYYcd
lqZOnaoYAICwD8Xiww8/TLvuumt65JFH0vHHH68gAICwD8Uigv6yZcuyt2fO nJnGjRunKACA
sA+FrlOnTmnWrFmVbuvevXs22g8AIOxDgRo7dmx68MEHV7t98eLF6YILLlAg AEDYh0K0cOHC
1K1btxrvHzFihNF9AEDYh0K0/fbbp5UrV9Z4/5IlS1LXrl0VCgAQ9qGQdOjQ Ic2fP3+tHzd+
/Pg0e/ZsBQMAhH0oBNdee216+umna/Wxq1atSr169VI0AEDYh3w3efLkNGjQ oDo95qmnnkqT
Jk1SPABA2Id8FZNt99tvv2y0vi7i43v27KmAAICwD/lq5513Lt84q65effXV NHr0aEUEAIR9
yDfHHXdcFtjXxTnnnKOQAICwD/kk+vTvv//+df48sXrP4MGDFRQAEPYhH8TG We3atWuwz3f9
9dfbaAsAEPYhH7Rq1WqNG2fVVQT9AQMGKCwAIOxDczrwwAPTf//73wb/vLff fruNtgAAYR+a
S2ycFevjN4a4UmCjLQBA2IdmEBNyBw4c2KhfI04kpk6dqtgAgLAPTSUm5MbG WY0tNtrq0aOH
ggMAwj40lW9961v13jirrmJkf+zYsYoOAAj70NiGDBmSZs2a1aRfc9CgQQoP AAj70JgmTJiQ
rrzyyib/unPnzk0jR450AAAAYR8aQ/TpH3300c329c866ywbbQEAwj40hobe OKuuFi9ebKMt
AEDYh4bWWBtn1dUdd9xhdB8AEPahoQwbNqzRNs6qq1gBqGvXrg4KACDsw7qK jbOGDh2aV9/T
uHHjsu8LAEDYh3XQsWPHvPy++vbt6+AAAMI+1Neuu+6aPvjgg7z83mKjLaP7 AICwD/UQm1j9
4x//yOvvsTmXAQUAhH0oSLFx1jXXXJP332dstDV8+HAHDAAQ9qE2YlnLQhox v+iiixw0AEDY
h9rYbrvtmnXjrLp6//330+DBgx04AEDYhzU59NBD05w5cwru+46Wo2jpAQAQ 9qEa48ePT48+
+mhBfu+x0VaXLl0cRABA2IeqZs+enY499tiCfg6xw28sxwkAIOxDBTvvvHNa tWpVQT+H+P57
9OjhYAIAwj7kfPvb387bjbPqKkb2J02a5KACAMI+nHfeeUW3C23Pnj0dWABA 2Ke0xSj45Zdf
XnTP69VXX7XRFgAg7FO6YuOsvfbaq2if39ChQ7PnCAAg7FNyvvnNb6bly5cX 7fNbsmRJGjBg
gAMNAAj7lJZDDjkkvf3220X/PO+44w6j+wCAsE/puPfee9Of/vSnkniusdFW 165dHXQAQNin
+M2dOzeddNJJJfWcH3jggTRjxgwHHwAQ9ilu0adf6Btn1dXKlStTp06dHHwA QNineLVp0yab
tFqKXn755TRhwgQ/BACAsE/x6devX/r73/9e0jXo06ePHwQAQNinuMTGWTff fHPJ1yHmK4we
PdoPBAAg7FMcin3jrLoaOHCgIgAAwj7F4Wtf+1pRb5xVVwsXLhT4AQBhn8LX o0ePNH/+fIWo
4vrrr89aegAAhH0K0pgxY7IXVhdLcZ588skKAQAI+xSe2EAqRvWp2eOPP26j LQBA2Kfw7LHH
HoqwFrGxWPfu3RUCABD2KRzbb799yW6cVVeTJ09OY8eOVQgAEPYh/5133nlp 5syZClEH5557
riIAgLAP+S1GqS+//HKFqKPXX3/dRlsAIOxD/oqNs9q3b68Q9XTGGWdkNQQA hH3IOy1btkwr
VqxQiHoqKytLw4YNUwgAEPYhv7Rr1y699dZbCrGOfv7zn2e76wIAwj7khdtu uy09//zzCtEA
4srIKaecohAAIOxD84sNofr27asQDeiBBx5Ic+fOVQgAEPah+cRk0jZt2mQb Q9FwVq5cmbp0
6aIQACDsQ/PZZZdd0tKlSxWiETz55JNp0qRJCgEAwj40vd69e6dXXnlFIRqR 3n0AEPahycWI
86hRoxSikcUuxCNGjFAIABD2oWnEspAdO3ZUiCZy/vnnKwIACPvQNFq3bm3j rCY+ubrssssU
AgCEfWhcMaI/b948hWhil1xySbbyEQAg7EOjuPLKK7MVYmh6y5YtS3369FEI ABD2oeFNnjw5
DRkyRCGa0T333JNmz56tEAAg7EPD2n///RWhmcXGZb169VIIABD2oeF06NDB xll5wkZbACDs
Q4P5+c9/np5++mmFyCM22gIAYR/W2dSpU9MFF1ygEHkmNtoaN26cQgCAsA/1 E8s87rXXXgqR
p4zuA4CwD/W23XbbpeXLlytEnrLRFgAI+1Avhx56aJozZ45C5DkbbQGAsA91 Mnbs2PToo48q
RAGIjbYGDBigEAAg7MPazZ07N3Xt2lUhCsjtt99uoy0AEPZh7Vq1apVt3ETh WLlypY22AEDY
hzXbe++9U1lZmUIUIBttAYCwDzU655xz0pQpUxSigFmKEwCEfVhNbJx11VVX KUSBs9EWAAj7
UEks29i2bVuFKBJG9wFA2Idy22+/fVqxYoVCFAkbbQGAsA+ZE088Mf3nP/9R iCJjoy0AEPYp
cRMmTEj33XefQhQhG20BgLBPCZs8eXI66qijFKKI2WgLAIR9SlC0dxx44IE2 zipyNtoCAGGf
EvTtb387LVmyRCFKwFNPPZUtqwoACPuUgJ/85Cdp2rRpClEi4urN8ccfrxAA IOxT7CZOnJh+
+ctfKkSJsdEWAAj7FLlYe/2www5TiBJloy0AEPYpYi1btkzLly9XiBI+2bPR FgAI+xShzp07
p3fffVchSpyNtgBA2KfI3HbbbWn8+PEKQbbRVp8+fRQCAIR9ikEsudi3b1+F oNw999xjoy0A
EPYpBvvtt5+Ns6gkfh769eunEAAg7FPIdtlll1RWVqYQrOaRRx5JkydPVggA EPYpRGeeeWb6
5z//qRDUqHfv3ooAAMI+hSZGbK+77jqFYI3iZHD06NEKAQDCPoVi7ty5qX37 9gpBrZxzzjmK
AADCPoWiTZs2acWKFQpBrcyfPz8NHjxYIQBA2CffHX300WnevHkKQZ1cf/31 NtoCAGGffDZy
5Mj00EMPKQR1FkG/a9euCgEAwj75KCbknnbaaQpBvcWJ4sKFCxUCAIR98s1B Bx1k4yzWyfLl
y1Pnzp0VAgCEffLJnnvumRYvXqwQrLOnnnoqzZgxQyEAQNgnH5x66qnppZde UggaRFwdOvLI
IxUCAIR9mlv06cekXGhIM2fOTBMnTlQIABD2aS6xesq+++6rEDSKHj16KAIA CPs0l6222iqb
UAmNYc6cOWn48OEKAQDCPk3t2GOPtUQije6iiy5SBAAQ9mlKY8aMSePGjVMI Gt3777+fvv/9
7ysEAAj7NIXZs2frpaZJ/e53v0tz585VCAAQ9mlsu+yyiyLQpFauXJl69eql EAAg7NOYdtpp
Jxtn0SweeeSRbJlXAEDYpxGceeaZafr06QpBs+nbt68iAICwT0OLEdXrrrtO IWhWU6dOTWPH
jlUIABD2aSixvGb79u0VgrwwaNAgRQAAYZ+G0rJly7RixQqFIC/EqjwjR45U CAAQ9llX3bt3
T++++65CkFd++MMfpg8//FAhAEDYp76iN/rOO+9UCPLO0qVL04ABAxQCAIR9 6iNaJbp166YQ
5K1Ro0bZaAsAhH3qo1WrVtlGRpCvli9fnrp06aIQACDsUxd77rlnKisrUwjy 3lNPPZVmz56t
EAAg7FMbw4YNSy+99JJCUBBWrVqVjjjiCIUAAGGftZkwYUIaOnSoQlBQ/vnP f6aJEycqBAAI
+9QkNs46+uijFYKCdNJJJykCAAj71GT77bc3IZeCNX/+/DR8+HCFAABhn6qO O+64LCxBIbvw
wgsVAQCEfSqKjbPuv/9+haDgxQpSffv2VQgAEPYJU6dO1etMUbHRFgAI+3xi n332UQSKio22
AEDY52O77bZb+vDDDxWComOjLQAQ9ktabJw1bdo0haAo2WgLAIT9kmXjLEqB jbYAQNgvOTbO
opT06dNHEQBA2C8dNs6ilLz++us22gIAYb802DiLUmSjLQAQ9ote9OnbOItS ZKMtABD2i1ps
nHXUUUcpBCXrjjvusMwsAAj7xaldu3bZUoRQqpYtW5Y6d+6sEAAg7BeX2Dhr yZIlCkHJe/TR
R220BQDCfvGwcRb8HxttAYCwXzQmTZpk4yyowkZbACDsF7zYOKtjx44KAdWw 0RYACPsFLTbO
WrFihUJANWy0BQDCfsGycRasnY22AEDYLzg2zoLasdEWAAj7BcXGWVA3NtoC AGG/YNg4C+rG
RlsAIOwXBBtnQf3YaAsAhP28ZuMsqL+4GnbSSScpBAAI+/nHxlmw7p577jkb bQGAsJ9fbJwF
DcdGWwAg7OcVG2dBw7HRFgAI+3nj5JNPtnEWNDAtcQAg7De73/72t+muu+5S CGhgsaJV//79
FQIAhP3mMXfuXCuHQCMaOXKkjbYAQNhvHjvttFNauXKlQkAjWb58uZ2oAUDY b3odOnRICxYs
UAhoZI8//nh2FQ0AEPabxLXXXpuefvpphYAmEBttHX744QoBAMJ+45s6dWoa OHCgQkATevHF
F7NN6wAAYb/RxETBvfbaSyGgGfTs2VMRAEDYbzw77rhjNmEQaHqvvvpqGjFi hEIAgLDf8Hr0
6JFmz56tENCMLrzwQkUAAGG/YY0fPz6NGTNGIaCZvfvuu+mKK65QCAAQ9htG LPl37LHHKgTk
iZ/97Gc22gIAYb9h7LDDDtnSf0B+WLJkSTr77LMVAgBhXwnWzW677Zbee+89 hYA8M3LkSKP7
AAj7SlB/w4YNS9OmTVMIyEOxKtaJJ56oEAAI+9Td5MmT09ChQxUC8tjDDz9s hSwAhH3qJloD
9ttvP4WAPBdzaYzuAyDsUyetWrVKy5YtUwgoAHEVLl4AQNhnrbp27ZrefPNN hYAC0q1bN0UA
QNhnzSZOnJjuuecehYACM3PmzDR27FiFAEDYp3rRp3/IIYcoBBSo008/3VKc AAj7VO+rX/1q
WrlypUJAgVq4cGHq16+fQgAg7FNZ586d04IFCxQCCtyYMWPS3LlzFQIAYZ// dfnll6fx48cr
BBSBuDp38sknKwQAwj4p24znvPPOUwgoIo8//niaMWOGQgAg7JeymMjXunVr hYAiY6MtAIR9
0g477JCWLl2qEFCEpk6dmi2lCwDCfgk67bTT0uuvv64QUMR69+6tCAAI+6Um RvtuueUWhYAi
95///CeNHj1aIQAQ9ktFLMln4ywoHQMHDlQEAIT9UtGqVSsbZ0EJiY22rLgF gLBfAvbZZ59U
VlamEFBihg8fnq2+BQDCfpEaNmxY+utf/6oQUIIi6A8YMEAhABD2i1EswTd0 6FA/CVDCbr/9
9mwTPQAQ9otIjOjtvffefgqgxMVcnV69eikEAMJ+Mdlxxx1tnAVknnzyyTRp 0iSFAEDYLwb9
+/d32R6o5JRTTlEEAIT9QhcbZ914442OPlDJzJkz07hx4xQCAGG/UEWf/mGH HebIA9Uyug+A
sF/Atttuu7R8+XJHHqhWbLR12WWXKQQAwn6h2W233dKcOXMcdWCNLrnkEhtt ASDsF5If/ehH
adq0aY44sFbLli2z0RYAwn6hmDx5cvr1r3/taAO1ZqMtAIT9AhCX4vfbbz9H GqgTG20BIOwX
gJ133jm7JA9QV0899VSaOnWqQgAg7OejY489Nr366quOMlAvq1atSscff7xC ACDs55vYGMfm
OMC6stEWAMJ+npk7d67ROKDB2GgLAGE/j+y0007Z5DqAhhAbbQ0fPlwhABD2 m9uee+6ZFixY
4MgCDeq8886z0RYAwn5zuvHGG9NLL73kqAINLoK+jbYAEPabSWx+c8YZZzii QKOx0RYAwn4z
iBG37bffPlsmD6Cx2GgLAGG/GbRp08bGWUCTsNEWAMJ+E+rdu3e2DjZAU7DR FgDCfhOZMGFC
GjVqlKMINCkbbQEg7Dey6NM/5phjHEGgWdhoCwBhvxFtscUWafny5Y4g0Cxs tAWAsN9IDjjg
gLRo0SJHD2hWNtoCQNhvYLFx1qRJkxw5oNnZaAsAYb8BTZw4MfXv399RA/JG LBIwd+5chQBA
2F9XRx55pCMG5JWYO9SlSxeFAEDYXxetW7dOH330kSMG5B0bbQEg7K+Dk046 Kf373/92tIC8
ZKMtAIT9eho7dmz2ApDPYqOtmFcEAMJ+LcWkt27dujlKQEGIq5CW4gRA2K+l nXbaKa1cudJR
AgrC/Pnz0wUXXKAQAAj7a3PwwQenBQsWOEJAQbnmmmuM7gMg7K/tn+Vjjz3m 6AAFZ9myZaln
z54KAYCwX50ZM2aks846y5EBCtbvfve7NHv2bIUAQNivKC5977rrrtkydgCF KuYaHXvssQoB
gLBf0be//e3sEjhAoXvxxRfThAkTFAIAYT8MGTIkTZs2zREBisagQYMUAQBh f/LkyenKK690
NICiEhttjRs3TiEAKN2wv3DhwtSuXTtHAihKp59+uiIAULphf4cddrBxFlC0 YifwK664QiEA
KL2wv//++6d33nnHUQCK2kUXXWSjLQBKK+yPGDEiPfPMM44AUPQi6Pfp00ch ACiNsB8bZ/3w
hz9UfaBkjB071kZbABR/2I8Rrt12203lgZISc5NOPPFEhQCguMN+mzZt0kcf faTyQMmJZYYn
TpyoEAAUZ9jv169ftu40QKnq0aOHIgBQfGE/Npa5+eabVRwoaXPmzEmTJk1S CACKJ+zHxlkn
nHCCagN8rGvXrooAQPGE/ZYtW6YVK1aoNsDH/vOf/2TLDwNAwYf9o48+Or37 7rsqDVDBueee
a6MtAAo77N90003poYceUmWAKhYvXpwtWgAABRn2Y/OY008/XYUBajBmzJg0 d+5chQCg8MK+
ESuANYuNtrp06aIQABRe2L/00kuznXI33HBDVQaowVNPPZVttgUAjWGDn32s MT7x1ltvnfr3
758uvPDCdOSRR6aysrL0/vvvZ69XrVql8gCfeOyxx9KgQYMUAoAG16Ipvsje e++d7rrrrvL3
R48ene699970l7/8xUo9QMl79dVXs4229t9/f8UAoEE12sj+muy+++6pW7du 6cc//nE2+r/J
Jptkvavz589Py5Ytc1SAkjNx4sR09tlnKwQAhR/2K9p4441Thw4dUu/evdPQ oUPTKaeckjbY
YIM0b968rO0nTgIAit17772Xttlmm9S2bVvFAKB4wn5VX/ziF9MhhxySBg4c mH7605+W9/v/
97//zdalBihWf/7zn9M555yTWrRooRgAFGfYryom+h5//PHpRz/6Udb2s9lm m2W7Ti5atCgt
WbLEEQSKxtKlS7OBjaOOOkoxAGgQBTV89JnPfCadddZZ2UuIzWh+/vOfZxPb ZsyYYeQfKHgj
R45MMQbzla98RTEAWGd5P7K/JtHvf/jhh2cbeEW/f7T8fPTRR9nIf/S/6vcH Ck383Zo+fXq2
iAEArKuiagyNJT5HjRpV/n6M+I8YMSL94Q9/SAsXLnS0gYLw8MMPp9mzZ6dt t91WMQBYJwU9
sr82X//617N+/5/85CdZ68+WW26ZjfpHT2z0xgLkqylTpqQ+ffooBADrpGSW fIhVfir2+8eo
/29+85v05JNPptdeey0tX77cTwOQN+JvlI22ABD26yn+gVb8Jxr/VC+77LL0 /PPPa/kB8sIx
xxyTXYkEgPoq6jaeuoiWn+7du2v5AfJGLC8ca+7HxoMAIOw3kFjis127duW7 +n7ve99L66+/
fra2v119gab03HPPZfuM2GgLgPrw36MWqrb8TJgwIV1xxRXpb3/7m5YfoFHF 6P6AAQOy9fcB
QNhvAkcccUT2EiLsx0TfcePGpWeffVbLD9DgYknh2EDQRlsA1JU2nnVUseXn wgsv1PIDNDgb
bQFQX0b2G5hVfoDGEO2DNtoCoK6M7Deymlb5ee+997LXALWxatWqbLJu3759 FQOAWjOy34Sq
buwVo3SXXnqpjb2AWomwP3ny5LT33nsrBgC1YmS/mcN/p06d0sCBA9NPf/rT 8n7/WNs/Rv4B
qnrooYeypTgBQNgvMNHyE+H/7LPP1vIDVKusrCxr6TnooIMUA4C10saTp6q2 /OSW+LzlllvS
jBkztPxACYt9Ps4777xsNTAAWBMj+wUit8TnD3/4w0otP5b4hNITJ/tvv/12 diUQANbEyH6B
sqsvlDYbbQFQG0b2i8T222+fbexVdYnPmOxrV18oPjbaAqA2jOwXoar9/rGx V/T7W+ITisvD
Dz9soy0AhP1Sp+UHilOsynPiiSemv/71r4oBgLDP/zriiCOyl5Bb5WfcuHHp 2Wef1fIDBSY2
2bLRFgA10bNf4nKr/ES//4UXXmiVHyhAf/7zn7PN+QCgKiP7VKLlBwrPzJkz 0/Dhw8vn6QCA
sE+tVNfyM3bs2DRlyhQTfSGPDB06NJ1++uk22gKgEm081Fqu5adv37429oI8 Y6MtAKpjZJ96
q9ryM3LkyDRmzBgtP9BMbLQFQFVG9mkwbdu2rbSx15e+9KVsY68I/h999JEC QSOz0RYAVRnZ
p1HExl7nnntu9hJi45/bbrstPfjgg2nq1KlpxYoVigSNIDbamjFjRmrdurVi AGBkn6YL/wcd
dFDq169fdgKwww47pHfffTe999572eg/0HD+9Kc/pQEDBigEAEb2aXox0bdH jx7ZS4g2n5tv
vjkb9X/xxRfT4sWLFQnWwcsvv5wmTZpUaU4NAKXJyD55Ef7322+/1KdPn2z5 wFNOOSV9+ctf
Tm+88UY28r9q1SpFgjp6+umnbbQFgLBP/omWnw4dOmRBpeISnxH+lyxZokBQ C9Emt8UWW6S9
995bMQCEfchfX//617O1w6PX/8c//nHW7x+j/e+8847wD2vwl7/8JVsdCwBh HwpCixYt0u67
755OOumkLPjnWn6WLVuW5s2bZ1dfqCAmv8cI/+GHH64YAMI+FJ5cy0/0+59/ /vl29YUqYtL7
kCFDshNlAEqPv/4Ulaq7+k6YMCFdccUVdvWlZMVVrzgZvuuuuxQDQNiH4nLE EUdkLyHC/m9+
85s0duzYNGXKFC0/lIx77rknDRs2LG277baKAVBitPFQMmKJz3bt2qW+fftW WuVHyw+l4Lnn
nst+9gEoLUb2KVlVW35GjhyZxowZo+WHog37EydOTN/97ncVA6CEGNmHT7Rt 2zb17t07W6rw
rLPOSltuuWW2qdfbb79t1J+iEEtx2mgLQNiHkremlh+7+lKobLQFUHq08UAt VGz5ibXLb7zx
xjRu3DgtPxScWKL2jDPOUAiAEmFkH+p6htyiRTbqX7Xl54033kgLFizQ8kNe i5PV+BmO/SkA
KIHcogSwbmJjrwj88RImTZqULfH55JNPptdee80Sn+SdSy65JA0ePDhrVwOg uBnZhwb29a9/
PXXq1CmbCBn9/ttss022tGf0+seoKjS3uPr0yiuvpOOPP14xAIqckX1oZDHJ N7e+eW5jr+j3
f+GFF1JZWZkC0SxstAU0lvnz5ytCE4kFQzbffHNhH/KFlh/y6R9Er1690hNP PKEYQIPbbLPN
FCFPTqyEfWhGVTf2ivA/YsSI9Ic//MEqPzS6OMmMn7mKP4MAFBdhH/I0/Fds +bHEJ43llFNO
Sf/+978VAqBImaALeSq3sVfFJT4/+OCDbGOkmPBbdYnP9dZbT9GoMxttAQ0t /ldttNFGCpEn
tTayT52YdNO8YnWfeAnPP/98NsnymWeeSa+//npasWKFAlEvQ4cOTd///vcV Ik/VZgIe5LV1
GIx64bTT0l433aSG60DYp85MuskPRx55ZPYS7OrLuohlYePn54ILLlCMPGSQ hWIQob2u9rr5
ZoUT9oEQLT8VV/nJ9fuPHTs2TZkyxSo/rJWNtoDGsiheli5NHW+/vW6P+zjs x+MQ9oEqKi7x
OXv27NSyZcuszWeDDTbI7tfyQ1XLli1Lffr0SXfddZdiAI2m4vyyN998M331 q19VFGGfQvbW
W2+liz7pMa/o4ksu8QveRDp06JCF+/XXXz/985//zHb41fJDdWy0BTSG2D6y 4gh9LuRH8K/6
9tZbb13++q0qj6t6wvDpT3867b777um8885LnTt3btTnsMcee6SXXnqpyR4n 7FNQQf+WkSNX
u+/Uvn2rvZ2GFTv3xuTd7ATr4otT69ats7era/m55ZZb0owZM7T8lDAbbQHN pWrQj9cfv7HG
v1exKt2jjz6aLSEcLYiHHXZYo31/tQ3sVcN9cwd9YZ8GDfa5X87ciH11QT9C fozq0/iuvvrq
dOutt2Zv77nnnjVOvlzTrr6vvvqqlp8SY6MtoKFFz35ZhRH6rT8J8RUzQ7yO AJ8L8mFGlcdV
FVesI+D/+te/TsOHD2/UsF9bccU836zvR5CGkPvF3brCWXhNI/dxEiDwN65Y nefss8/O3o7L
nY8//nitHxshb+THxy42WiorK0tXXXVVOvDAA7OTAkpDjJIBNKaG7Nc//vjj 01NPPVX+/iuv
vJJ23HHH9IUvfCE98MAD5bf//ve/T1/72tfSV77ylfLbFixYkLUAxZWBrbba qvz2+N8Zj80t
WlBxrkG8HQtgxOf/5je/mV544YVKHxOvK76dM2fOnPTd7343bbjhhqlt27bZ 91nxc0Z7bXxv
8RJvC/vk3S9txddrU10fPw3noIMOKh8ZOf/88+s2fnQzAAAgAElEQVQd1HOr /ERbR/xBjJdL
L700tWrVKrVo4cJgsZo5c2aD/qMBSlu2Gs9HH1XKDFlP/ltvVQq78X7F11Uf V5MIzxVbUAcO
HJhGjRqVpk2bls4999zy27t165amTp2a5s6dW35b3N+mTZtsc6oI4xW9/fbb 2eBZTbkn2mB/
9KMflV8Zr3hlIvd2RYMGDcoG1JYuXZq6d++eTj311Er3x/cb30NcqcgN2DUE /61pEBUvv4Vc
W0/VX4w19ekffPDB6U9/+lP5+9GLF2EzfjHjDD0nJg9GD9ymm25a6+8v/mhU 94s3YcKE1K9f
vzRv3rzsF7qmj1tXuTP7WA0nnssNN9yQDjjggEY5FiNGjEjPPfdc9nbXrl2z cN5Q4qQh2oFy
LUEVW35mzZrVKLWjecTofmNPeANKKOxXaceJ/xcVJ+hW17M/4+PXtVl6M3aV r5gJHnvssfTw
ww+X/9/NmThxYja636VLl7Txxhtnt40ePToL+tESVFWsUFaTCPjxmDPOOCOd c845tapDXCnI
rXgWj6/aXhuDc/E54393zJ8S9slr8YtaNfitLUgfeuih6c9//nM2Kh2effbZ bPT4xRdfLA/7
sVvs3nvvXaegvyY/+MEP0h/+8IdsQk1jyz33uPQXZ/SxJGZDi8+ZG2GIy5G3 3XZboz6nGKHI
9XbnJvrGiPA//vEPGwEVuDiel112mY22gAYJ+2VrCe3V9ey/UIvHhTvuuGO1 wYlYTrjqFej9
9tsv+994+OGHp6effrr89hhcrC7sr+kKdu7j44pCXFmoreq+TtX74nVDzpfT xkPeOPHEE9OY
MWPK3588eXI64ogjspn2Ob/97W/TafXYha8mcYmuKYJ+1ef53//+t1E+dyyz GX/g4g9FtN40
5QZJuYm+8XXjSkm0/Pz0pz9N7dq1S5/73Of8gBeg2GirpkvYALWVLb35STtO BPlcr37Ft9f2
uOpESI8BtP/5n/9JQ4cOLb+9ffv22TLC1dliiy3Ke+zDd77znWxDwfhcdRFX 0UOsdHf00UeX
3x7LgVbsxa+oY8eO6aKLLsrejgnFkXGagrBPg4i2nVhpJ17qK9pzYpnI3C9c tIj07Nmz0i9l
3HbIIYdkb69tokvFiTU5cQZ+1FFHpWuuuabaiTQV1fT5d9ttt/K+vui7i/vj KkSIpSvXdPIQ
zy3aai5phAnKNS2z2Vwi/Mf3EbWJib4vv/xydiVl5513tktrgYgTxwEDBigE sE4q9t5X15tf
9XW4eS09+/FxG220Ubr77ruzFuCK+4NEq2zcHiPz8f87J7oOYpPJuD8nVq2L DoL4v1SX/5u5
Ef1oGbryyivLb4+5AtGhEJN3q4olruPj43Hjx49P1157bZPUXxsPDRL0qy6z Gb12VQN0bSbv
xtnxQw89lDp16pT9Qtx7771Z4I9QHSP93/ve98o/NjfRJXrwYjJLTHSJt3Oq TqyJoN2jR4/s
ykB8/pjAs6bWopo+f8z6j1/S008/Pd1///3ZspbR+x8jCfH6mGOOqfEPU4iR 7oae/FjbZTab
U/wRHVnhZyRqGSMbf/nLX7KrAPr981P84/r5z39eafUKgDqH/U/acarrza/6 +lef/L98oU2b
GFVb7fOt7f9FtP7GJpJVVZdDoq0n5p2t7WtUfT8yRLxUFfMB4qW6x8VKQLnB wbp+PWGfZlXd
evpVJ+zWVrS4xOW07bbbLu2www5ZO0pcYotWngj/MREmZ20TXapOrIlR5Ril jJ692qjp88cv
8Q9/+MMs7Edoj8Aa78eI/R//+MdKZ/hVf3HjhCN2rz3hhBMq9Quui3VZZrM5 xVWTeMmJSVIR
LCP8L1myxC9WnojRqzgJ/+tf/6oYQL1EO84O06aliz8J8T/7+OWWj4N9Ta/D lI8zQAT9B6dP
V0Bhn3yU2zyrYi9exRV6alpfN86w4+Oi9y7aPUKMCMfkm+hzr3qJbU0TXapO rIn3o5e8Lqr7
/DFiEG088bli84wY0f/85z+f3njjjazVZ9ddd13j54sTltwk2obQUMtsNre4 6hIvIZZFi8ud
MUfjX//6V9ZOQvOJq2rxEpPjAerqiW9+s+4P+jjo/7mG3vfmFn35wj4lJUJ9 hPuKo/vxdsXA
nwv6uVBacbmtqmLkvH///lnAD9/+9rfTL3/5y0o9diE30SVG1Gsz0SXC43HH HZf1ytVmUsya
Pn+08sTlu9xufdG6E20/8fnXJEb2r7vuuqzVpiE05jKbzSlaRiou8RktP/fd d1/WJhUnVVp+
mudkbLoRNqAe8jW011ehLVwg7LPOIrDnAn9VuRafXNDP9a3n3q4utEXYj3ab 3HKbe+21V/rU
pz6VLVdZNbx///vfz04EYnT9nnvuWev3Gh9z5JFHZqP8uYm+azo5qOnzxxJf ++yzT/m+ADEH
IDbWyAXv6sTzjfV+o40oguu6auplNptTxZaf+CMbzzUmX0VP5rvvvrtanZ0M NLyYYB2tVrmr
LwAUhvVW+a9IHcTa6ZttttlaPy43aTc3sp8LYLUJ+9RObvWiaA2KVpfmXn2n ueTWg4/9EuIE
aPHixcJ/I4krLjHxnfz8uwt+ZtW6Ohv87GNKRW3FLnOx1NXanHP22ZV69mMF nFiGKkJX/Mjl
2nii1526i2U2Yz37EMt4HnvssSVbi1guLa7SxCTpmOsRV26iXWrRokXpvffe q/PaydQsTqRi
TkisKEX+/d2FUvmZjZbOWLwj/uavy+pzkUViwCjXklvx9vrE4/o+LpYHjU0p +9Zj+fLa1Fob
D41ibavzGGmtv+jTz/dlNptTTCLNTSSNlp9Y/ShWTYrJ1PFHnXUT/1xjJSp7 JQDNJVbXi6u5
67opZrQIx1La0Z4YLcPNIZbijCv0m266abavUGN8H8I+FJjcur6FtMxmc4lA GvMacnMbIuzH
BOlY4vO1117LlpWkbmJZ1JhTM7LKCT1AU4l2wnUN+iFWeouNreLk4aWXXmqW 5xIDUrFU+O67
7579f7r99tuFfShl0Zu+YsWK7O3Y6KhQl9lsLlGviqv8xI7Mcek0NlSZNWuW K061FCtlxT8l
o/tAU8vN/as4BzCWw45FPGL/mlj+OhbBiP16ch8Xo/ex4EZ1q+gcddRR6c47 78z2yIl9fqpa
0+eO+2LBjmnTpqULL7yw0uNiKe5YxS/mMI4ZMyZbyKOqWMI7lpiOE45odY6T jrht8803F/Zp
Ps8884wiNJPol7744ouzt6N9J/YhiD9grJvYMCpeor5xpeT5559Pr7766moT ffk/MRq27777
ZkvT0vh22WUXkx3hE9Ut8FHTjvc5cSVgTctlxmNime9Ywjq3H1BtPnfcF3vd RCtOrFZWUVyF
j6vIW265ZTr00EOrDfs333xztgJhBP1w8sknZ6vN/fjHPxb2aT5xVtuyZUuF aAax/Ge0ncRo
auwya1S14XXr1q38bS0/a/biiy9mc3FstNX44qoTULOadrzPiTaZNYnlq2NT yn79+qWHHnqo
1p877nv//feznvtevXql3r17l9/32GOPpYcffjh7O5bdrioWj4iwH6P+OT17 9kwdOnQQ9qEU
xQTT3Br+w4YNE/SbQE0tP7G3Qix5yv+uChUTnwGaW3U73peH3RZrj7ux8ECM zsf/29p+7gjs
uc9d3cpvcRW0pq8dJxXxvyTCfXX3RXuRsA8l5JRTTsleR+tObrIpTSsu48ZL iFH/CP6lvsrP
1KlT0+TJk43uA81qTTve10WsdHfwwQdnq/TU5nPHFfcYgDvzzDPTkCFDKn2u 3H1Ve/lzrr76
6vSrX/0qnXPOOZVuj2VF4/aGDPvr+xGB/BatJREmY2Qh/gjQ/GLUP066Yq+D BQsWZC/xx75V
q1a1GkEqJsccc4wfCKBZxY730Taz4YYbZnPZYsJrfey4445Zy0+MyNfmc99w ww1Zj/0222yz
2gh93Bc7vcf/hFhHv6KZM2dmC0NEj35VcTIR+xDNmDGjwepjB13qJHpH9ew3 nUceeaR8s48I
k9dcc42iFIBSW+Xn+uuvT2eccYYD7+8uZOygm1+11sYDeSpWDojdYENM7hH0 C0eptfzExDZh
HyA/CfuQp9q0aVO+pn5sukFhyrX8VNzYK8L/2LFj05QpU4pilZ94TtHTmlsa FgBhH1iDmBAU
PX2xlnDMyq/vZCPyP/xXbPkp5CU+YyLaeeedZ6UoAGEfWJNYzjCCX4gNPAT9 4lax5SfEJOwr
rrii4Fp+YkJbrFEd+xIAIOwD1YiQF0t/hZiQa5nN0hMnd7kTvELr94/NYX70 ox+l3XbbzYEE
yBMb/OxjykBtxRKDX/rSlxSiEUQPd//+/bO3Y2vtO++8U1FKXLTEtGvXLtuV 8Sc/+Uk2YTs2
blm0aFG2a2N1m7g0p1h1KHZ3zv0c4+8upemDDz5IG220kULkSa2N7EMeiI2J unfvnoWl2Djr
j3/8o6Kwmti8quIGVvm4q6+NtoBCMn369Gx9/WIm7EMzi5HQ6NmOoP+Vr3wl vfDCC4pCrdS0
xOeLL76Yjfw3l9gI7t///rcDBCUs1n8vBC+//HJB7wlQm31chH1oRrGWfuy6 F7+ssfJO9GVb
zYT6qLrKz9y5c1N0ab700kvZz9WSJUua7HuJlaRGjBhh7X0oUYUUnjfZZJOi 3wBM2IdmVHEt
/dtvvz0b2YeGED9LsV17TrT8xMZs8fqdd94p/7lrLLHuvrAP5LMYcCv2Fh5h H5qRtfRpSlWX
+Ix2n+uuuy7rr2+Mlp+4hH/ZZZelCy64QPGBvBRX0rfcckthH2h41tKnuXXu 3Dl7CdHyM3z4
8PTEE080aMvP5ZdfngYPHqw1DUDYh9JhLX3yTbT8xA64OTHaf9VVV2Xhf11a fhYvXpx69uyZ
7r33XkUG8s6zzz6b2rdvL+wDDSfW0o/10kOspR891JBvYtnMu+66q/z92NU3 flbjH2NdW35+
97vfZVcOzEcB8s1HH31UEs9T2IcmYi19ClXFXX0juEeAv/vuu7NlYtfW8hMb fx1//PHZxGAA
hH0oSo8++mg67LDDrKVPwYuf31hlJ7fSzuzZs9Oll16ajf7HiUB1u/o+88wz adSoUalXr14K
COSNUpicK+xDE4gdRQ8//HBr6ZOX5s2bl/1c1tfnPve5bCJuvISbbropO7md Nm1aWrBgQfnH
9evXLx155JF59/zj5GSLLbbwgwAlqBSW3RT2oQmC/r777ls+2hlLHepdJp9E 0G/IDWXOP//8
7CXMmDEjXX/99emWW25Jd9xxR15uXFMou3wCDW/69OnW2QfqL4JOTHRcunRp Wn/99dODDz5o
iU1KSuvWrdPVV1+dvQDkm7KyspJ4nus71NDwoo85dscV9AEgP8XVxuXLlwv7 QN2Dfoxo5oJ+
LGEo6ANAftlmm23SwoULi/55auOBBhStOxVH9H/zm9+kLl26KAwA5FsIbtEi L+cSCfuQp2Iy
bsUe/RjRF/QpZLVdpSdWmgIoRKUwSVfYhwYK+u3atTOiT1EF/dqG+Lp8LEA+ efvtt4s+7OvZ
h3X0yCOPpD333DPbSTQ3GbdHjx4KQ0kE/ZDbQwKA/GNkH9bBuHHj0nHHHVce jKy6A5VPGsKn
PvWp1L59+zRmzJj0ta99ba2P22OPPdJLL73UIF97gw02yEbtbrjhhnTAAQc4 KEAlpbCLrpF9
qKeBAweWB/0Y0b/qqqsEfagifj8+/PDDLOz36dOnVo+pbdCPk4K1fe1YVu/C Cy9M3bt3dzCA
1ZTCplrCPtRDjBBee+21WZiIFp7//ve/6ayzzlIYqO4fzccnw5dddll6+umn G/Tz/u1vf6vV
x5144onZ7yiwZqXYjhcTdIV9oFysob/55punSZMmZe+ffvrp6f/9v/+XvvjF LyoOrCXwxzJ3
OXPmzEnf/e5304Ybbpjatm2bXnnllWoDR7wd7XJf+cpXspd4u+LHxOs1BZSV K1emSy+9NF1y
ySUOAkVlbVe2qJ2YoCvsA5kIGdtvv32aP39+1gd8yy23ZH3AwJpF4B4+fHjq 3bt3+W2DBg1K
+++/f7aCVbTYnHrqqTU+ftq0adnJwa9//et09tlnZ7fl5snE65omE8dJQPyu /vGPf0wnn3yy
A0GTe//991OvXr3qff+a1PbKVkOLBSji+67v/flm1113TX//+9+L+ufQBF2o hejPv+6667JQ
EaP4jz76aLamPrBmEbg//elPp65du2atbzkPPPBAthdFiBa4Cy64oMbPcf75 52dXBuJz1CUY
xe9rnGjceOON6YQTTmjwNiJYkyeffDL1798/+/9R2/vjClfM/XrrrbeyCe2d OnVKAwYMyPrK
4/Vjjz2WRowYke6///7y36/cz3p1j819THx8v379svdvuumm1Llz5+ztOImO t+OEOua2VPT7
3/8+OymPE/K5c+eW377ffvtlS03HYNeBBx642vNa2/35JjbVKisrE/ahlEV/ fq5tJ/rzH3/8
cW07UIfAXZMI8LWR+7h4vWLFijp9/XjMGWecYU4NTSbC8dChQ9MzzzyTndS2 atWq1vdH8B81
alS2Qsyhhx6aBfbLL788uwrWs2fPrCXt3nvvzYJ41SVyq3tsTu7q2N13351d HcuF/QjzBx10
UHr22WfT6NGjK32f3bp1yx6z6aabVro92lcPOeSQbAQ/Jt7/4he/yNrxant/ PopFBIqZNh6o
gf58Sjmg12WiXn021erYsWO66KKLsrejxac+K1nFFYOKvf7ViZH9a665JjtR h6YQc1DmzZuX
BeiqQX9t98fIfYyKf+Mb30gzZ87Mbtt4442zCe4R+OP/UMxdqU51j82peHXs jTfeKL89TjZi
PkvcV/Wq2cSJE7OTiupGvbfbbrvsZCUmvsfzqev9+abY+/aN7EMNYmQk158f bQB9+/ZVFAT+
Gj62rmLOy/e///30y1/+Mhv9u+eee+r8OWIUM0YlFyxYUG2PcK5nP9oK7rvv PgeVJhEtNPH/
YvDgwemnP/1p+sIXvlCn+5ctW1ZpMnvYZJNN0qJFi9LnPve5NX7t6h4baro6 FifDuY+PtyuK
35utttoqHX744au1wMUJwM9+9rPsikGuHa8u9+ebXN9+vBb2oYTEzrgRJGJi 7m677aYglGTg
b6zHx+ZaMbK5tsdV/RwV3+/SpUv20hjfO9RXrJIzZcqU7IrVt771rXTxxRdn I+q1uT9OfIcN
G1apfz5OZM8999z03HPPZYNQEcK//OUvl1/ZilH0mh67NrnHnHnmmWnIkCGr 3b/FFlukF154
odJtd955Z/Y9R3tcPI+q1nZ/Pir2vn1tPFCDbbfdNvtDKugDUFcxTyQm4Uar TG3vj0mt0Vcf
o+259pcI4jE5N9p3fvzjH5dP6M1d2cpdGajusWsTj7ntttvSNttskzp06FDp vq233jq1bNly
tVXnYrJvfN81zYNZ2/35qpj79tdbZfiDOpg1a1b2yw8Uh2hVi1Etz9/fXShl TzzxRDaXqBhp
46FkLV68OOvj/de//pWWL1+e9THmehk/9alPZb2+n/3sZ7NVBeKyKQBQnIq5 b1/Yp+T86U9/
ys7gY1JfTSL8h+jhi/5DYR8Ailcx9+0L+5SMmGT0u9/9Li1cuFAx4BOxPF6p 23fffbNldoHS
Vqx9+8I+JWHs2LHZhCGgsrhkXcr94NGzDxBivf3YrVjYhwIS7TixGck777yj GABAybH0JkVN
0AcAauODDz4Q9qGQxHrDgj4AUBsbbbSRsA+F4vnnn19te28AgJrklt8U9qEA xPr5AAC1Fctv
brzxxsI+5LtHHnkk2zALAKAuinH5TWGfohMbZgEA1FUsvynsQx6LNbPfe+89 hQAAEPYpNvff
f78iAAD1UozLbwr7FJWZM2cqAgBQL1tssUXRPSc76FJUYsdcoG6i/a1URdvf F77wBT8EQPrP
f/6TLb8p7IOwD0Vjk002yZabK2Wl/vyB/zVnzpy0zTbbFN3z0saDsA8AlLxi XbZb2Ke4fqDX
9yMNANRNLLm55ZZbCvuQ7zbYYANFAADqJDbT2nHHHYV9yHctWpiGAgDUPewX K2GforLhhhsq
AgBQJ2VlZUX73AyDUlR+8YtfKAI0sPXWWy+tWrWq0T7/HnvskV566aW1fq2K HwfNbeHChenv
f/97ev/999NGG22U9XsXaxtIsSvWJTeFfQDyQm0DvKBPc4qR34033jh7+7XX XsvCfrt27apt
H50+fXo24TMsWrQoff7zn3cykMfefffdolxyU9gHAFiD2HDu2WefTZ/97Gez K0u5sP+Nb3xj
jY+LUL+mYF/xZGDp0qXZrq0xsmzeWdOL4/ClL32pqJ/jBj/7mENNbS1YsKDo fymglHzwwQdZ
C0JFsbHM9773vTRo0KBsOduJEyem3L+KV155JbVv3z4NHTo07bLLLmmHHXbI bv/973+fDjnk
kPTLX/4yDRkypPzvRdeuXVPv3r3T9ddfnwYPHpzdHq06bdu2Tbvvvnu64IIL svdzn//iiy9O
O+20U9p3333TzTffnA444ID01a9+tfxxuY+LtyN8HXjggenKK69M22+/fXm4 evPNN9PBBx+c
ff+f/vSn03777Zdq+ldX3fP3d5fYs2XGjBnZiG/8jG233XYN+nMSG7nFCUO8 tGzZMjuJmDJl
Svr617+u+E0sTryK/YqLU0gAKomQfNBBB2UjmqNHj65038CBA9OoUaOyloRD Dz00derUKbu9
W7du2UnCpptuWv6x5557bmrTpk12IlB1D4wYTatp9YsI69EiMWLEiHTWWWel p59+utqPmzZt
WvY177777nT22Wenzp07Z7fHSUXu+x85cqQDSt3DUYsWTRoAI+zvv//+5e/H z3/0kcfJQO5q
Ao2jVatWRf8crcYDQCUPPPBAuuSSS7KA3qtXr0r3PfbYY1mfcoSQmTNnlt8e o/8R6iuuaBEn
CjFSX91md3369Knx60fAj8ecccYZ6fnnn6/x484///zs4+LqwRtvvFF++/jx 48u//9NOO80B
pVbiBDRfVmT54he/mLX1xATgRx99tLzlh4YTV28mTZqU1broT14dbgAqWrly ZXnvcLxd1bJl
y1brLY5Wma222iodfvjhlUbi4/HVhf019SbnPj7+Ga9pOd3cx8XrFStWVPon vqbvH6qG/BhF
j5H8fBtFjxPr3PcYbT5xAvCZz3zGQVtHceVk3LhxqXv37iXxfI3sA1BJ9OQP GzYsW1Kwf//+
1d5XnZhk+MILL5S//53vfCdrqalr4I72nRBXBY4++ug6f//77LNP9j1Gr3u/ fv0cUNYoWtK+
9a1v5XW7TO57FPQbLuzHXKJSmRAt7ANQyQ033JBuu+22bCm6Dh06rHZf9MjH P8mYZJuz9dZb
ZxMN4/6cW2+9Nb344otZQGndunWtv36sThIj+tEyFJNv6+raa6/Nvv9tt902 dezYMW2wwQYO
KuXiyk8s41rIO6bGKkHR4lOxlY7aW9tqSsVmvVWNuVMKRWfWrFnZP3SgOERo iJVBilVcnYiT
lnhdqM/f392Gk1sfv1iWuYz2o3hOMfJfChNN10WcGEXIL8XlTfXsA1C0rrrq qpLpy2Xtim1E
N05k4yVG+SP0l9qIdW1FfaJOpbqPgbAPQFGJ9fdjjfRoBTrmmGPS8OHDFaVE RQCO0e+Ky1oW
o7hSkRNtSlnAs0FXJq7eRdAvhVV3hH0ASkL0Y1PaIvDed9992aTWYg/61Xno oYeytp6KJwGl
+DPw3HPPleTxr8oEXQCgqELejTfemI466qiS7GOPEf3YYC76+GP/i1Jcoz/m ZYwZM6Z86VJh
HwCgSPzxj3/MllUs9Z1nY+L5d7/73eztWKO/kFcfqk/YL6WlNYV9AJrMeuut pwg0qxjRL/Wg
X1EprtFvorKwDwAUmZiIy9oV6xr98Xxyk5MR9gGAIhLhtZRXW6mLaO+Jibsx 0j9p0qQ0ffr0
ojj+8by07VRPVQCoswULFqRTTjkl64/edNNN05w5c8rvGzduXOrfv382ynbT TTel4447Lru9
ffv26W9/+1u2JGbsctujR4/s9mj9uf/++1O/fv2y9+MxMcEwvPnmm9njp02b li655JI0ZMiQ
lNsL8pVXXklHHHFEeuutt7LJeJ06dXJgSlBMQI22Ha07dZNboz/qF/38hdrm Y2lNYR+ARnDu
ueemNm3apN///vdp/fUrXySOYB4hfezYsenMM88sD/vPPvts9jpGEg888MDy sJ97TJww3H33
3enss88uD/uDBw9OBx10UPbYkSNHVvo6AwcOTKNGjcp6kg899FBhv0TF8adh 6hcTW6MdZscd
d8z7k6fcSYr+/LXTxgNAnY0ePTpdfPHFqwX9cP7552e3d+3aNc2dO7f89gjs J5xwQtp3333T
O++8U+Nj3njjjfLbx48fn43ox32nnXZapcc89thj2dJ68c++2PqPqR19+g0r RsdjMm/UNZbt
jD0r8q0PvqysrLw/X9CvHSP7ANTLypUrqw37FW9bsWJF+dsnnXRS+sUvfpHu uuuu9OlPf7ra
x8Trio+Jf+i5Ptz4elUtW7ZMn26Jij5tYa9xxMh+vESwzpeNqXJ/C+KKQynu n7AujOwDUGff
+c53shab6gJ4TWKUPx4Xff61tc8++6Rhw4ZlcwRyPf05MQcg7qP06NNvGlHf ikE/2nziJCtO
Apoq4Efb32uvveakXtgHoCndeuut6cUXX8wm9bVu3bpWj4n++j322KNOLTcx kfe2225L2267
berYsWPaYIMNyu+74YYbsh7/CAFt27Z1UEpI9Jkb1W960eYTK/lE4H/wwQfT E0880eCr+cQJ
RW6VoHg7rjA41utmvVW5ZQ2gFmbNmpVatmypEFAkYiWLWLKuELz//vvZqhvx upSev7+7lUUI
jABIfh6buOoSFi1alD7/+c9nJ2ZrOl5xlSB3hSZG8CPgxwmFkfyGo5IAFISr rroqde/eXSFK
XIRJYT8/5Xr9a3MyEKE+Qn5c7cuFfSP4wovcYWYAAAaJSURBVD4AJSaCwIwZ M7K1+Y855pg0
fPhwRSnxoG+pzeI9GUDYB6DExNJ/kBPrqguLUDcm6AIABRP2gboxsg9QwmKN hpikWsrPn8LR
VEs+grAPQFHYfPPNFYGCELu6xiotQN1o4wEA8t6cOXOyfR0AYR8AKDLrrbee IoCwDwAUGy08
IOwDAEVKCw8I+wBAkVq8eLEigLAPAAAI+wBAwdhyyy0VAYR9AABA2AcACsbb b7+tCCDsAwDF
KJbd/Pvf/64QIOwDAMVms802SxtvvLFCgLAPABSjDz/8UBFA2AcAipG+fRD2 AQAAYR8AKCQf
fPCBIoCwDwAUo4022kgRQNgHAIqR5TdB2AcAipTlN0HYBwCKmOU3QdgHAIqU 5TdB2AcAipS+
fRD2AYAipW8fhH0AoIjp2wdhHwAoUvr2QdgHAACEfQCgkGy55ZaKAMI+AFCM dtxxR0UAYR8A
KEbTp09XBBD2AYBiVFZWpggg7AMAxSjW2l++fLlCgLAPABSbbbbZJi1cuFAh QNgHAIpNixYt
stF9QNgHAIqQSbog7AMARcouuiDsAwCAsK8EAEAhsYsuCPsAQJGyiy4I+wBA kTJBF4R9AKBI
maALwj4AAAj7SgAAFBITdEHYBwCKlAm6IOwDAICwrwQAQKGYP39+Wr58uUKA sA8AFJuysrLU
okULhQBhHwAAhH0AgILwxS9+URFA2AcAhH1A0xsAUKOYEJtPNt988+z1vHnz mvxrr1q1qvzr
g7APABSFzTbbLG++lwjcTnyg9rTxAACAsA8AABQSbTwAQK2tt0v9H3va0S+k my7fSxFB2AcA
8tLKRem0Y2bU+WE3j2+tdiDsAwD5bulHi9L1lx9Qx7D/QfY4oGnp2QcAam9l WdM+DhD2AYCm
U98ReiP7IOwDAPls5aIGfdx6662XzjrrrGpvr4/6Pq5t27apffv2ji/CPgBQ 2pZ+VNZgj/vU
pz6Vxo8fn1544YVmez7PPvtsWn/99dOmm27arN8HCPsAQPNq4JH9ZcuWpWuv vTb94Ac/aLan
dOONN6Y+ffqk888/P1133XWOMUXFajwAQJ189OGiBn3cUUcdle6888505ZVX psGDB692/5w5
c1L37t3T008/nXbdddd03333pe222678vs6dO6dp06alCy+8sNLjXnnllXTE EUekt956K40Z
MyZ16tRptc89b9689Nvf/jY74fjCF76QnXTEbZtvvrkDTVEwsg8A1F4Dj+zn /PrXv05XX311
evPNN1e7b9CgQWn//fdPS5cuzUL/qaeeWum+gw46KJWVlaWvfvWrlR43cODA NGrUqOxE4Nxz
z6326958882pS5cuWdAPJ598crrtttscZ4R9AKAErVhUv1V11vK4rbbaKmuj 6dev32r3PfDA
A+Wj9jGZN3rsK953ySWXZD33vXr1qvS4xx57LLVr1y594xvfSDNnzlz9/GPl yizsRwtPTs+e
PdOIESMcZ4qGNh4AoPZWltVvgm4tHnf66aen0aNHp3Hjxq12X4T5aj/tx4G9 RYsW5W9XFXMC
cvdX9dBDD6XXX389dejQodr7or0IhH0AoITC/qL0/sK3Gu1xt956azr44IOz VXpyOnbsmC66
6KJ06aWXpuHDh2d9+DmxXOawYcPSmWeemYYMGVLpc+Xuq9rLnxNtQ7/61a/S OeecU+n2CRMm
ZLcL+xQDbTwAQJ1C+9L6TNCt5eN23HHHrK0mRuRzbrnllqwlZ8MNN8yW6YzJ tDk33HBD1mO/
zTbbrDZCH/fdfffd2ch+rKNfUbT1PPnkk1mPflVxMhFzB2bMmOF4U/DWW/Ux ZaC2Zs2alVq2
bKkQACXyd3f+/Plps802+7/gsMXF9f5cO2w5JU2f+mDBHouqtYBCoI0HAKi1 b276RL0fu/Qj
9QNhHwDIW6+8/GdFgAKiZx8AAIR9AACgkGjjAQBq9MwzzyjCJ3bZZRcTdBH2 AYDiseuuu1qF
7ROxMhIUGm08AAAg7AMAAMI+AAAg7AMAAMI+AAAg7AMAAMI+AAAI+wAAgLAP AAAI+wAAgLAP
AAAI+wAAgLAPAADCPgAAIOwDAADCPgAA0DhaKAEAsCazZs1ShI+tWrVKERD2 AYDi0bJlS0WA
AqaNBwAAhH0AAEDYBwAAhH0AAEDYBwAAhH0AAMDSm9SZ9ZYBmo613QFhnyZj vWUAgMKhjQcA
AIR9AABA2AcAAIR9AABA2AcAAIR9AABA2AcAgCL1/wHbu1V16VFHEAAAAABJ RU5ErkJggg==
--------------000108010402010600020105--
Re: 2.0.2 to 2.2.0m5 migration, I lost the connection end decoration - other issues with GMF 2.2.0 M [message #219196 is a reply to message #219126] |
Wed, 18 February 2009 17:50  |
Brian Jakubik Messages: 140 Registered: July 2009 |
Thanks for the reply, I just moved to m5a (and m5a dependencies) and I
have my connection decoration arrows back now.
I would suggest a bugzilla on the other issues, they will close if it is
a duplicate of a know issue...
> construction"?
> TIA & regards
> Thomas
>> GEF I suppose...
>> method createTargetDecoration() is called its sets it in the figure,
>> but I'm not seeing it in my diagram... I see the connection, just no
>> directional decoration...
>> Thanks
>> Brian Jakubik
FUDForum. Page generated in 0.01490 seconds
