Home » Archived » XML Schema Definition (XSD) » A Test with http://www.w3.org/2001/XMLSchema.xsd
A Test with http://www.w3.org/2001/XMLSchema.xsd [message #21189] Mon, 05 May 2003 06:38 Go to next message
Originally posted by: paechoi.earthlink.net
I have tested [1]the metaschema with my sample code(XSD v1.0.2
+ EMF v1.0.2). And it gets 15 diagnostics messages.
Any comments?
Pae
P.S.: XSD v1.1.0 is not working for me at present. So I am stuck with
v1.0.2 for now. :-(
[1] meataschema: http://www.w3.org/2001/XMLSchema.xsd
// ############## Diagnostic Messages #########
0: At line #94(18), XSD: The location 'http://www.w3.org/2001/xml.xsd' has
not been resolved; Node = [xs:import]
1: At line #182(47), XSD: The enumeration facet is not permitted in a type
based on 'http://www.w3.org/2001/XMLSchema#string'; Node = [xs:enumeration]
2: At line #183(39), XSD: The enumeration facet is not permitted in a type
3: At line #232(44), XSD: Attribute reference
'http://www.w3.org/XML/1998/namespace#lang' is unresolved; Node =
[xs:attribute]
4: At line #833(59), XSD: The enumeration facet is not permitted in a type
based on 'http://www.w3.org/2001/XMLSchema#decimal'; Node = [xs:enumeration]
5: At line #834(42), XSD: The enumeration facet is not permitted in a type
6: At line #830(26), XSD: The value '1' of attribute 'default' must be one
of 0, 1 as constrained by
'http://www.w3.org/2001/XMLSchema#minOccurs_._type'; Node = [default]
7: At line #841(47), XSD: The enumeration facet is not permitted in a type
based on 'http://www.w3.org/2001/XMLSchema#allNNI'; Node = [xs:enumeration]
8: At line #842(42), XSD: The enumeration facet is not permitted in a type
9: At line #838(27), XSD: The value '1' of attribute 'default' must be one
'http://www.w3.org/2001/XMLSchema#maxOccurs_._type'; Node = [default]
10: At line #1248(51), XSD: Attribute reference
[xs:attribute]
11: At line #2146(37), XSD: The enumeration facet is not permitted in a type
12: At line #2147(42), XSD: The enumeration facet is not permitted in a type
13: At line #2148(39), XSD: The enumeration facet is not permitted in a type
14: At line #2149(41), XSD: The enumeration facet is not permitted in a type
15: At line #2150(34), XSD: The enumeration facet is not permitted in a type
// ############# Code Snippet ###############
* EclipseXSDDemo2.java
* Created on May 2, 2003, 11:13 PM
package org.paechoi.xsd.test;
// W3C/DOM
import javax.xml.parsers.DocumentBuilderFactory;
import javax.xml.parsers.DocumentBuilder;
import org.w3c.dom.Document;
import org.w3c.dom.Element;
// Eclipse/XSD
import org.eclipse.xsd.util.XSDParser;
import org.eclipse.xsd.XSDFactory;
import org.eclipse.xsd.XSDSchema;
import org.eclipse.xsd.impl.XSDSchemaImpl;
import org.eclipse.xsd.util.XSDResourceImpl;
import org.eclipse.xsd.util.XSDResourceFactoryImpl;
import org.eclipse.xsd.XSDDiagnostic;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.common.util.EList;
import java.io.File;
import java.io.FileOutputStream;
import java.io.PrintStream;
import java.io.FileNotFoundException;
* @author pae
public class EclipseXSDDemo2 {
// private Document xmlDOM = null;
private XSDParser xsdParser = null;
// instance initializer
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "xsd", new
XSDResourceFactoryImpl());
/** Creates a new instance of EclipseXSDDemo2 */
public EclipseXSDDemo2() {
super();
// Redirect the System.err
try {
System.setErr(new PrintStream(new
FileOutputStream("errors.log", true)));
catch (FileNotFoundException fileNotFoundException) {
/** Open a XML DOM */
private Document openXMLDOM(String uri) {
// Create a factory object for creating DOM parsers
DocumentBuilderFactory factory =
DocumentBuilderFactory.newInstance();
DocumentBuilder builder = null;
Document xmlDoc = null;
// Build a new DOM
try {
// Now use the factory to create a DOM parser (a.k.a. a
DocumentBuilder)
factory.setNamespaceAware(true);
builder = factory.newDocumentBuilder();
xmlDoc = builder.parse(uri);
catch (Exception ex) {
ex.printStackTrace();
return null;
return xmlDoc;
/** Open a XML DOM using XSDParser */
private Document openXMLDOMUsingXSDParser(String uri) {
// Build a new DOM
try {
xsdParser = new XSDParser();
xsdParser.parse(uri);
xmlDoc = xsdParser.getDocument();
return null;
return xmlDoc;
/** doIt */
private void doIt() {
try {
// Document xmlDOM =
openXMLDOMUsingXSDParser("http://schemas.xmlsoap.org/wsdl/");
// Document xmlDOM = openXMLDOMUsingXSDParser("./wsdl.xsd");
Document xmlDOM =
openXMLDOMUsingXSDParser("http://www.w3.org/2001/XMLSchema.xsd");
Element rootElement = xmlDOM.getDocumentElement();
XSDSchema xsdSchema = XSDFactory.eINSTANCE.createXSDSchema();
xsdSchema.setDocument(xmlDOM);
xsdSchema.setElement(rootElement);
xsdSchema.updateElement();
System.out.println("\n\n");
XSDResourceImpl.serialize(System.out, xsdSchema.getElement());
System.out.println(">>>>>>>>>>>>>>>>>>>>>> VALIDATION
xsdSchema.validate();
//EList eList = xsdMainSchema.getDiagnostics();
EList eList = xsdSchema.getAllDiagnostics();
for (int i = 0; i < eList.size(); i++) {
XSDDiagnostic xsdDiagnostic = (XSDDiagnostic)eList.get(i);
System.out.println(i + ": At line #" +
xsdDiagnostic.getLine() + "(" + xsdDiagnostic.getColumn() + "), " +
xsdDiagnostic.getMessage() + "; Node = [" +
xsdDiagnostic.getNode().getNodeName() + "]");
System.out.println("<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< <<<<<<<<<<<<<<<<
/** main - the main entry */
EclipseXSDDemo2 app = new EclipseXSDDemo2();
app.doIt();
Re: A Test with http://www.w3.org/2001/XMLSchema.xsd [message #21303 is a reply to message #21189] Mon, 05 May 2003 08:12 Go to previous messageGo to next message
I have rerunned the test Eclipse/XSD v1.1.0 + EMF v1.1.0 with Xerces-J
v2.0.2,
and the diagnostic message came out as follows:
// ############## Diagnostic Messages #################
[xs:attribute]
[xs:attribute]
Any comments?
Pae
"Pae Choi" <paechoi@earthlink.net> wrote in message
news:b95eu0$376$1@rogue.oti.com...
> Any comments?
> Pae
> v1.0.2 for now. :-(
[xs:enumeration]
[xs:enumeration]
> [xs:attribute]
[xs:enumeration]
[xs:enumeration]
[xs:enumeration]
[xs:enumeration]
> [xs:attribute]
type
[xs:enumeration]
type
[xs:enumeration]
type
[xs:enumeration]
type
[xs:enumeration]
type
[xs:enumeration]
> // W3C/DOM
> // Eclipse/XSD
> * @author pae
new
> super();
> try {
> // Build a new DOM
> try {
> DocumentBuilder)
> return null;
> return xmlDoc;
> // Build a new DOM
> try {
> return null;
> return xmlDoc;
> /** doIt */
> try {
> Document xmlDOM =
> public static void main(String[] args) {
> app.doIt();
Re: A Test with http://www.w3.org/2001/XMLSchema.xsd [message #21312 is a reply to message #21303] Mon, 05 May 2003 11:41 Go to previous messageGo to next message
Pae,
This version of XMLSchema.xsd is different from the cached version in
plugins/org.eclipse.xsd/cache/www.w3.org/2001/XMLSchema.xsd, which doesn't have
these problems. I'm upgrading the cached version to this newer version, which
contains errata changes.
This newer version revealed a bug I hadn't noticed before and fixing it
eliminates the diagnostics below except for 1, 3, 10. These three remaining
diagnostics are caused by failure to resolve the XMLSchema.dtd in the DOCTYPE
tag in the xml.xsd, so I fixed the XSDParser to resolve the XMLSchema.dtd. With
these changes, the file validates without any diagnostics.
It may be a week or two before we drop a version 1.1.0 build with these fixes...
> v2.0.2,
> [xs:attribute]
> [xs:attribute]
> Any comments?
> Pae
> > Any comments?
> > Pae
> > v1.0.2 for now. :-(
> [xs:enumeration]
> [xs:enumeration]
> > [xs:attribute]
> [xs:enumeration]
> [xs:enumeration]
> [xs:enumeration]
> [xs:enumeration]
> > [xs:attribute]
> type
> [xs:enumeration]
> type
> [xs:enumeration]
> type
> [xs:enumeration]
> type
> [xs:enumeration]
> type
> [xs:enumeration]
> > // W3C/DOM
> > // Eclipse/XSD
> > * @author pae
> new
> > super();
> > try {
> > // Build a new DOM
> > try {
> > DocumentBuilder)
> > return null;
> > return xmlDoc;
> > // Build a new DOM
> > try {
> > return null;
> > return xmlDoc;
> > /** doIt */
> > try {
> > Document xmlDOM =
> > app.doIt();
Re: A Test with http://www.w3.org/2001/XMLSchema.xsd [message #21314 is a reply to message #21312] Mon, 05 May 2003 17:17 Go to previous message
Ed,
Thank you for letting me know in detail. I'll look forward to seeing
your next quality work.
Pae
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:3EB68637.F18DADB9@ca.ibm.com...
> Pae,
have
which
remaining
DOCTYPE
With
fixes...
> > v2.0.2,
has
type
[xs:enumeration]
type
[xs:enumeration]
> > [xs:attribute]
type
[xs:enumeration]
type
[xs:enumeration]
one
type
[xs:enumeration]
type
[xs:enumeration]
one
> > [xs:attribute]
type
[xs:enumeration]
type
[xs:enumeration]
type
[xs:enumeration]
type
[xs:enumeration]
type
[xs:enumeration]
> > Any comments?
> > Pae
> > > Any comments?
> > > Pae
> > > v1.0.2 for now. :-(
has
type
> > [xs:enumeration]
type
> > [xs:enumeration]
> > > [xs:attribute]
type
> > [xs:enumeration]
type
> > [xs:enumeration]
one
type
> > [xs:enumeration]
type
> > [xs:enumeration]
one
> > > [xs:attribute]
a
> > type
> > [xs:enumeration]
a
> > type
> > [xs:enumeration]
a
> > type
> > [xs:enumeration]
a
> > type
> > [xs:enumeration]
a
> > type
> > [xs:enumeration]
> > > // W3C/DOM
> > > // Eclipse/XSD
> > > * @author pae
> > new
> > > super();
> > > try {
> > > // Build a new DOM
> > > try {
> > > DocumentBuilder)
> > > return null;
> > > return xmlDoc;
> > > // Build a new DOM
> > > try {
> > > return null;
> > > return xmlDoc;
> > > /** doIt */
> > > try {
> > > Document xmlDOM =
> > > app.doIt();
Re: A Test with http://www.w3.org/2001/XMLSchema.xsd [message #570501 is a reply to message #21189] Mon, 05 May 2003 08:12 Go to previous message
v2.0.2,
[xs:attribute]
[xs:attribute]
Any comments?
Pae
> Any comments?
> Pae
> v1.0.2 for now. :-(
[xs:enumeration]
[xs:enumeration]
> [xs:attribute]
[xs:enumeration]
[xs:enumeration]
[xs:enumeration]
[xs:enumeration]
> [xs:attribute]
type
[xs:enumeration]
type
[xs:enumeration]
type
[xs:enumeration]
type
[xs:enumeration]
type
[xs:enumeration]
> // W3C/DOM
> // Eclipse/XSD
> * @author pae
new
> super();
> try {
> // Build a new DOM
> try {
> DocumentBuilder)
> return null;
> return xmlDoc;
> // Build a new DOM
> try {
> return null;
> return xmlDoc;
> /** doIt */
> try {
> Document xmlDOM =
> app.doIt();
Re: A Test with http://www.w3.org/2001/XMLSchema.xsd [message #570553 is a reply to message #21303] Mon, 05 May 2003 11:41 Go to previous message
Pae,
> v2.0.2,
> [xs:attribute]
> [xs:attribute]
> Any comments?
> Pae
> > Any comments?
> > Pae
> > v1.0.2 for now. :-(
> [xs:enumeration]
> [xs:enumeration]
> > [xs:attribute]
> [xs:enumeration]
> [xs:enumeration]
> [xs:enumeration]
> [xs:enumeration]
> > [xs:attribute]
> type
> [xs:enumeration]
> type
> [xs:enumeration]
> type
> [xs:enumeration]
> type
> [xs:enumeration]
> type
> [xs:enumeration]
> > // W3C/DOM
> > // Eclipse/XSD
> > * @author pae
> new
> > super();
> > try {
> > // Build a new DOM
> > try {
> > DocumentBuilder)
> > return null;
> > return xmlDoc;
> > // Build a new DOM
> > try {
> > return null;
> > return xmlDoc;
> > /** doIt */
> > try {
> > Document xmlDOM =
> > app.doIt();
Re: A Test with http://www.w3.org/2001/XMLSchema.xsd [message #570659 is a reply to message #21312] Mon, 05 May 2003 17:17 Go to previous message
Ed,
Pae
> Pae,
have
which
remaining
DOCTYPE
With
fixes...
> > v2.0.2,
has
type
[xs:enumeration]
type
[xs:enumeration]
> > [xs:attribute]
type
[xs:enumeration]
type
[xs:enumeration]
one
type
[xs:enumeration]
type
[xs:enumeration]
one
> > [xs:attribute]
type
[xs:enumeration]
type
[xs:enumeration]
type
[xs:enumeration]
type
[xs:enumeration]
type
[xs:enumeration]
> > Any comments?
> > Pae
> > > Any comments?
> > > Pae
> > > v1.0.2 for now. :-(
has
type
> > [xs:enumeration]
type
> > [xs:enumeration]
> > > [xs:attribute]
type
> > [xs:enumeration]
type
> > [xs:enumeration]
one
type
> > [xs:enumeration]
type
> > [xs:enumeration]
one
> > > [xs:attribute]
a
> > type
> > [xs:enumeration]
a
> > type
> > [xs:enumeration]
a
> > type
> > [xs:enumeration]
a
> > type
> > [xs:enumeration]
a
> > type
> > [xs:enumeration]
> > > // W3C/DOM
> > > // Eclipse/XSD
> > > * @author pae
> > new
> > > super();
> > > try {
> > > // Build a new DOM
> > > try {
> > > DocumentBuilder)
> > > return null;
> > > return xmlDoc;
> > > // Build a new DOM
> > > try {
> > > return null;
> > > return xmlDoc;
> > > /** doIt */
> > > try {
> > > Document xmlDOM =
> > > app.doIt();
Previous Topic:Cannot run XSDFindTypesMissingFacets in V1.1.0
Next Topic:Old Xerces Version
Current Time: Sun Aug 31 00:04:52 EDT 2025
Powered by FUDForum. Page generated in 0.05677 seconds
