Re: some problems about CBE&GLA [message #24589 is a reply to message #21183] |
Tue, 02 August 2005 21:52 |
Originally posted by: nobody.nobody.com
Try specifying a Start Pattern that will match the timestamp. For example:
You do not require an End Pattern in this case. If no End Pattern is
specified, the Extractor will determine the end of the record as the
character before the next Start Pattern match.
"wangxq" <xqwang@cn.ibm.com> wrote in message
news:dafoe1$7s4$1@news.eclipse.org...
> Hi,all
> I want to know how can I deal with the problem descripted following by
> using Generic Log Adaptor.
> As you know GLA uses sensor to read the log content for processing.then
the
> extractor takes a collection of input lines provided by the sensor and
> separate these into message boundaries.In this stage ,we should define
Start
> Pattern and End Pattern to get a whole record item which may span several
> lines and at the same time the format of this record is not
regular.Follwing
> is the demo format:
> 18cc2ec4 WC_INVENTORY d
> 5Ymw7jS%2fFk%2fizLNiz5nTIiCJ8W4%3d%0a
> com.ibm.commerce.fulfillment.commands.ATPParameters.init ihsBackorder =
> {6001=com.ibm.commerce.order.objects.OrderItemAccessBean@6095eee5}
> com.ibm.commerce.fulfillment.commands.ATPParameters.init ihsReverse = {}
> com.ibm.commerce.fulfillment.commands.ATPParameters.display
> Order Items Lists
> Merge : [] Remerge : [] Check : Allocate: Backorder :
> Reverse : []
> [5/30/05 17:49:11:984 GMT+08:00] 18cc2ec4 WC_ORDER >
> com.ibm.commerce.order.commands.OrderItemBaseCmdImpl.updateR esourceList
> Entry
> [5/30/05 17:49:11:984 GMT+08:00] 18cc2ec4 WC_ORDER d
Add
> orderAB resource, id=1501
> [5/30/05 17:49:11:984 GMT+08:00] 18cc2ec4 WC_ORDER <
Exit
> here is the comments:each record item is starting with
> "[5/30/05..........",so some of the items span several line.I find it is
> hard for me to catch a whole item which spans several lines.
FUDForum. Page generated in 0.02398 seconds
