Home » Archived » Corona » Problem with the demo setup script
Problem with the demo setup script [message #1785] Fri, 09 February 2007 17:16 Go to next message
The demo script does not work properly on OS X. The problem is with
the os conditionals. On OS X, both <os family="mac"> and <os
family="unix"> evaluate to true. The result is that WTP for linux is
downloaded instead of WTP for OS X. I worked around the problem by
deleting the condition <os family="unix">.
Bryan
Re: Problem with the demo setup script [message #1792 is a reply to message #1785] Fri, 09 February 2007 17:35 Go to previous messageGo to next message
I just found a second problem ... in the <target
name="load.mac.properties" ...> unpack.eclipse.task.prefix is set to
"untar.eclipse" which should be "untar"
Bryan
> Bryan
Re: Problem with the demo setup script [message #1798 is a reply to message #1792] Fri, 09 February 2007 18:09 Go to previous messageGo to next message
And here is the next problem. The setupCorona.*.plutins.txt is not
compatible with OS X. Whe the files get untar'd, the Eclipse.app
directory is not fully populated on the server install, and the eclipse
link in the root directory (on both the client and server install) does
not point to the binary inside the Eclipse.app directory.
Here is the workadound:
cd install_client/eclipse
rm eclipse
ln -s Eclipse.app/Contents/MacOS/eclipse .
cd ../install_server/eclipse
rmdir Eclipse.app
rm eclipse
cp -R ../../install_client/eclipse/Eclipse.app .
Bryan
> Bryan
>> Bryan
Re: Problem with the demo setup script [message #1818 is a reply to message #1798] Mon, 12 February 2007 06:59 Go to previous messageGo to next message
Bryan,
Thanks for identifying this problem and posting a workaround. I have
created a Bugzilla item (#173852) to have the the scripted updated.
-Dennis
Re: Problem with the demo setup script [message #1834 is a reply to message #1798] Mon, 26 February 2007 11:47 Go to previous messageGo to next message
On Friday (Feb 23), we have released next milestone. We probably won't
support the setup script any more but use the Europa (Eclipse 3.3)
update site.
http://www.eclipse.org/projects/europa.php
Note, it may mean that Corona no longer works on Eclipse 3.2, but I
think it still should.
Marcin Okraszewski
> rm eclipse
> rmdir Eclipse.app
> rm eclipse
> Bryan
>> Bryan
>>> Bryan
Re: Problem with the demo setup script [message #1837 is a reply to message #1798] Mon, 26 February 2007 11:51 Go to previous message
BTW. We do not have any Mac OS X for testing. We put the script for Mac
OS as we expected it should work...
Marcin Okraszewski
> rm eclipse
> rmdir Eclipse.app
> rm eclipse
> Bryan
>> Bryan
>>> Bryan
Previous Topic:Problems with the demo instructioins
Next Topic:Thoughts on corona
Current Time: Sun Jul 13 20:17:44 EDT 2025
Powered by FUDForum. Page generated in 0.04918 seconds
