Problem with figures in draw2d! [message #218430] |
Wed, 27 June 2007 15:52 |
Originally posted by: martin.lindblad.gmail.com
Hi!
I'm trying to use gradients on my figures, using draw2d. But I have some
trouble with that. In the paint method of the root figure, I use the
setBackgroundPattern, and to make it visible I call the method
fillRectangle. But that make all my other childfigures disappear because
of the fillRectangle method.
Is there a way to make gradients on figures instead of using the Graphic
object? Or how can I otherwise solve th problem?
Many thanks
Martin
Re: Problem with figures in draw2d! [message #218472 is a reply to message #218458] |
Wed, 27 June 2007 16:35 |
Mark/Martin,
Probably the GEF newsgroup is even more specific:
news://news.eclipse.org/eclipse.tools.gef
Mark Dexter wrote:
> Martin wrote:
>> Hi!
>> some trouble with that. In the paint method of the root figure, I use
>> the setBackgroundPattern, and to make it visible I call the method
>> because of the fillRectangle method.
>> Graphic object? Or how can I otherwise solve th problem?
>> Many thanks
>> Martin
> Hi. You might have better luck on the eclipse.platform.swt newsgroup.
> Hope this helps. Mark Dexter
Re: Problem with figures in draw2d! [message #218486 is a reply to message #218472] |
Wed, 27 June 2007 17:23 |
Ok, I will try there instead.
/Martin
Ed Merks skrev:
> Mark/Martin,
> Mark Dexter wrote:
>> Martin wrote:
>>> Hi!
>>> Many thanks
>>> Martin
FUDForum. Page generated in 0.08882 seconds
