Home » Language IDEs » C / C++ IDE (CDT) » Does CDT indexer use absolute or relative path?
| Does CDT indexer use absolute or relative path? [message #218326] |
Tue, 01 July 2008 19:49  |
Originally posted by: maggie.eclipse.gmail.com
I built index for one project and exported it. The project source is
then moved to a different directory. When I tried to import the project
from the new location, the indexer started indexing again.
Does this mean that the indexer uses absolute path? And in order to
import a previously exported index, we should not move the project
source after exporting?
Maggie
| Re: Does CDT indexer use absolute or relative path? [message #218395 is a reply to message #218368] |
Wed, 02 July 2008 11:31   |
Hi Anton,
Thanks for the pointer. But it still doesn't answer my question. We did
build PDOM file and export the project. After exporting, we got the
..setting/cdt_index.zip under ${project_loc}.
If the ${project_loc} is /foo/bar/project_root, then importing the
project from this location, everything works fine. However, if the
project is moved from /foo/bar/project_root to /foo/bar/OLD/project_root
(as what usually happens with a nightly script), importing the project
from this location would trigger indexer.
Thus the assumption that the indexer uses /foo/bar/project_root and
treats resource under /foo/bar/OLD/project_root as unindexed sources.
Is this assumption true?
Maggie
Anton Leherbauer wrote:
> Maggie wrote:
>> project from the new location, the indexer started indexing again.
>> Thanks
>> Maggie
> Please read the following thread on cdt-dev:
> http://dev.eclipse.org/mhonarc/lists/cdt-dev/msg10527.html
> HTH
| Re: Does CDT indexer use absolute or relative path? [message #218898 is a reply to message #218440] |
Tue, 08 July 2008 11:03   |
> Note that the indexer does check each file whether it seems to have
> changed wrt the exported index.
> This is done based on a checksum of the file contents.
This could be the case as the indexer finished much quicker than
indexing freshly.
Another 2 follow up questions:
1. In the scenario of a index was built and exported nightly, do users
have to import the project everyday to get the latest indexing information?
It appears that the PDOM file stays at the old time stamp. So I think
the answer is YES? Is there any good idea on how to make this importing
an automatic task?
2. After importing the project, the PDOM file was generated under the
new workspace pretty quick, but Eclipse spends a lot of time in
"Refreshing workspace". Especially if the workspace already has a couple
of big projects in it. And it seems the period is even longer if the
other projects were imported a few days back hence most of their
resources have newer time stamps now.
How can I make Eclipse just refresh the newly imported project instead
of the entire workspace?
Maggie
> Maggie wrote:
>> Hi Anton,
>> did build PDOM file and export the project. After exporting, we got
>> the .setting/cdt_index.zip under ${project_loc}.
>> /foo/bar/OLD/project_root (as what usually happens with a nightly
>> script), importing the project from this location would trigger indexer.
> The feature would be quite useless if it used absolute paths.
> I tried exactly that same scenario and it works for me.
> Not a single file got reindexed.
> HTH
| Re: Does CDT indexer use absolute or relative path? [message #219033 is a reply to message #218978] |
Wed, 09 July 2008 14:02   |
>> information?
>> importing an automatic task?
> The imported PDOM is used as a normal index, ie. it gets updated with
> changed files, etc as usual. There is no need to import it every day.
In my experiment, when the resource is changed, I only see a dialog
asking "The file has been changed on the file system. Do you want to
load the changes?". After I click "Yes" the new file is loaded but no
indexer activity and the time stamp on the PDOM file stays the same.
In Windows->Preferences->C/C++->Indexer setting, both "Automatically
update the index" and "Update index immediately after every file-change"
are checked.
However, if I check "Index all file (files neither built not included,
also)" which was not checked by default, the indexer started. But it
took the indexer 40 mins to complete after a simple change like adding a
new function in 3 files (definition in .h, declaration in one .c and
calling it in another .c). Note that the indexing from ground zero for
the same project took 1 - 1.5 hour. Is this expected or I may have
missed something?
Another thing is that we disabled the builders for the project. Could
this make the indexer less efficient?
>> couple of big projects in it. And it seems the period is even longer
>> if the other projects were imported a few days back hence most of
>> their resources have newer time stamps now.
> When a project is imported only this project gets refreshed, although
> the progress message says "Refreshing workspace".
Thanks for the confirmation. But what could be cause of time variation
we see when importing the same project to different workspace. The
importing/refreshing could take 5 minutes to over 20 for the same
project in different workspace. That doesn't sounds normal to me.
Maggie
> Toni
| Re: Does CDT indexer use absolute or relative path? [message #219119 is a reply to message #219033] |
Thu, 10 July 2008 04:07   |
>>> users have to import the project everyday to get the latest indexing
>>> information?
It is normal that the timestamp of the PDOM file does not change,
because the timestamp is only updated when the file is closed.
At least this is the case on Windows.
> are checked.
> missed something?
This would indicate that many files were not indexed before enabling
"index all files". I don't think a small change alone would make the
indexer run for 40 minutes.
BTW, you can check whether a file is indexed or not by enabling the
label decorator "C/C++ Indexed Files" in the Preferences.
This decorator marks indexed files in the Project Explorer by adding a
tiny dot on the file icon.
No.
>>> instead of the entire workspace?
That's hard to tell without knowing the details.
In general, a larger workspace is slower, esp. when the Java heap size
gets at its limit.
Anton Leherbauer
Wind River CDT Team, Austria
| Re: Does CDT indexer use absolute or relative path? [message #219251 is a reply to message #219119] |
Thu, 10 July 2008 20:33   |
Thanks for the tip. But it seems this is new in Ganymede unless I looked
at the wrong place in Europa.
Maggie
>>>> information?
>>>> think the answer is YES? Is there any good idea on how to make this
>> file-change" are checked.
>> a new function in 3 files (definition in .h, declaration in one .c and
>> missed something?
> No.
>>>> the new workspace pretty quick, but Eclipse spends a lot of time in
> gets at its limit.
| Re: Does CDT indexer use absolute or relative path? [message #219303 is a reply to message #219251] |
Fri, 11 July 2008 04:49  |
>>> a tiny dot on the file icon.
That's right. It is new in Ganymede.
Current Time: Sun Nov 09 05:38:17 EST 2025
Powered by FUDForum. Page generated in 0.05831 seconds
