Home » Eclipse Projects » Eclipse Platform » cannot start 3.0 M8 GTK
cannot start 3.0 M8 GTK [message #218214] Tue, 30 March 2004 09:41 Go to next message
Originally posted by: veith.pixel.de
hi there,
I've just downloaded the GTK version of eclipse 3.0 M8.
It crashes on SuSE Linux 8.2. See log below:
!SESSION Mrz 30, 2004 16:34:39.838
java.version=1.4.2_02
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=de_DE
!ENTRY org.eclipse.osgi Mrz 30, 2004 16:34:39.840
!MESSAGE Startup error
!STACK 1
org.eclipse.osgi.framework.util.Headers.parseManifest(Header s.java:305)
org.eclipse.osgi.framework.adaptor.core.SystemBundleData.cre ateManifest(SystemBundleData.java:215)
org.eclipse.osgi.framework.adaptor.core.SystemBundleData.<init >(SystemBundleData.java:44)
org.eclipse.osgi.framework.adaptor.core.AbstractFrameworkAda ptor.createSystemBundleData(AbstractFrameworkAdaptor.j
ava:327)
org.eclipse.osgi.framework.internal.core.SystemBundle.<init >(SystemBundle.java:41)
org.eclipse.osgi.framework.internal.core.Framework.createSys temBundle(Framework.java:181)
org.eclipse.osgi.framework.internal.core.Framework.initializ e(Framework.java:134)
org.eclipse.osgi.framework.internal.core.Framework.<init>(Framework.java:80)
org.eclipse.osgi.framework.internal.core.OSGi.createFramewor k(OSGi.java:90)
org.eclipse.osgi.framework.internal.core.OSGi.<init>(OSGi.java:31)
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:201)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:115)
at org.eclipse.core.launcher.Main.basicRun(Main.java:267)
at org.eclipse.core.launcher.Main.run(Main.java:692)
at org.eclipse.core.launcher.Main.main(Main.java:676)
Any ideas ?
Gernot
BTW: the motif version runs without any problems (nice look and feel :-) )
Re: cannot start 3.0 M8 GTK [message #218599 is a reply to message #218214] Tue, 30 March 2004 15:37 Go to previous messageGo to next message
i run on suse 9.0 with gtk. you might try a new version of java from
java.sun.com, like 1.4.2_04
norwood sisson
Gernoth Veith wrote:
> hi there,
Re: cannot start 3.0 M8 GTK [message #218666 is a reply to message #218214] Tue, 30 March 2004 17:00 Go to previous message
Originally posted by: chaves.nospam.inf.ufsc.br
This looks like a corrupted install. Have you extracted Eclipse install on
top of an existing install? That is not supported.
If that is not the case, please enter a bug report against Equinox/General.
Rafael
> hi there,
> !STACK 1
> java.lang.NullPointerException
> at
> at
> at
> at
> ava:327)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Any ideas ?
> Gernot
Previous Topic:required plugins - unbound classpath container
Next Topic:M8 plugin requires default constructor although org.eclipse.core.runtime.compatibility is already im
Current Time: Sat Jul 26 10:09:03 EDT 2025
Powered by FUDForum. Page generated in 0.05281 seconds
