Home » Modeling » Epsilon » Making EVL files known to Eclipse
Making EVL files known to Eclipse [message #21145] |
Mon, 29 June 2009 12:43  |
I may have a wrong intuition about this, but here is what I try to do
and cannot quite figure out how to do:
I am building an editor based on TEF and am trying to add some
validation to it. It seems, that TEF by default links into the standard
Eclipse Validation Framework for this, so I thought why not use EVL to
write my constraints? I have written a simple EVL file, which I hope
expresses my constraints, but now I am struggling to figure out how to
register this with the validation framework so that it will be evaluated
for all models that comply to some given metamodel?
The Epsilonbook does not really tell me anything about this, as
unfortunately it is generally a bit silent about how to use an
individual language in practice. Is what I want to do possible at all?
If so, what do I need to do?
Many thanks in advance,
Steffen
Re: Making EVL files known to Eclipse [message #21177 is a reply to message #21145] |
Mon, 29 June 2009 13:21   |
Hi Steffen,
There is a relevant tutorial available in
http://epsilonlabs.wiki.sourceforge.net/EVL-GMF+Integration and a
screencast in
http://www.eclipse.org/gmt/epsilon/cinema/#EVLGMFValidation (both
resources are accessible under the EVL documentation section:
http://www.eclipse.org/gmt/epsilon/doc/evl/)
Looking forward to hearing how it goes!
Dimitris
Steffen Zschaler wrote:
> Steffen
Re: Making EVL files known to Eclipse [message #21238 is a reply to message #21177] |
Tue, 30 June 2009 05:42   |
--------------010102020708050306080909
Hi Dimitris,
Thanks for the information, this was really helpful. Unfortunately, it
doesn't work yet :-(
As I don't know enough about the validation framework or EVL, maybe I am
just misinterpreting something here. Here's what I think I know:
1. EVL constraints, once bound using the extension point are somehow
registered with the validation framework.
2. TEF by default uses the validation framework to evaluate any
constraints that may exist for some model element. In particular,
it uses the code excerpted below to do this.
3. Thus, I believe a correctly registered EVL constraint should be
picked up by TEF automatically.
Here's the code (slightly adjusted to fit in a few lines):
IBatchValidator validator =
(IBatchValidator) ModelValidationService.getInstance()
.newValidator(EvaluationMode.BATCH);
validator.setIncludeLiveConstraints(false);
final IStatus status = validator.validate(value); // Where value is some EObject from the model
if (!status.isOK()) {
// Add status message to context as an error/warning
// Errors and warnings from the context will later be placed in the problems listing
I'm sure, somewhere in the above thinking there is a fault, but I don't
know where. Can you give me a pointer?
Many thanks,
Steffen
Dimitris Kolovos wrote:
> Hi Steffen,
> screencast in
> Cheers,
> Dimitris
>> standard Eclipse Validation Framework for this, so I thought why not
>> use EVL to write my constraints? I have written a simple EVL file,
>> which I hope expresses my constraints, but now I am struggling to
>> figure out how to register this with the validation framework so that
>> it will be evaluated for all models that comply to some given metamodel?
>> all? If so, what do I need to do?
>> Steffen
<html>
<head>
</head>
Hi Dimitris,<br>
<br>
doesn't work yet :-(<br>
<br>
am just misinterpreting something here. Here's what I think I know:<br>
<ol>
<li>EVL constraints, once bound using the extension point are somehow
registered with the validation framework.</li>
<li>TEF by default uses the validation framework to evaluate any
constraints that may exist for some model element. In particular, it
uses the code excerpted below to do this.</li>
<li>Thus, I believe a correctly registered EVL constraint should be
picked up by TEF automatically.</li>
</ol>
Here's the code (slightly adjusted to fit in a few lines):<br>
<blockquote>
<pre>IBatchValidator validator =
</pre>
</blockquote>
know where. Can you give me a pointer?<br>
<br>
Many thanks,<br>
<br>
Steffen<br>
<br>
<blockquote cite="mid:h2at6u$fto$1@build.eclipse.org" type="cite">Hi
Steffen,
<br>
<br>
<a class="moz-txt-link-freetext" href="http://epsilonlabs.wiki.sourceforge.net/EVL-GMF+Integration">http://epsilonlabs.wiki.sourceforge.net/EVL-GMF+Integration</a> and a
screencast in
<a class="moz-txt-link-freetext" href="http://www.eclipse.org/gmt/epsilon/cinema/#EVLGMFValidation">http://www.eclipse.org/gmt/epsilon/cinema/#EVLGMFValidation</a> (both
<a class="moz-txt-link-freetext" href="http://www.eclipse.org/gmt/epsilon/doc/evl/">http://www.eclipse.org/gmt/epsilon/doc/evl/</a>)
<br>
<br>
<br>
<br>
<br>
Dimitris
<br>
<br>
<br>
<blockquote type="cite">Hi,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Steffen
<br>
</blockquote>
</blockquote>
</body>
</html>
--------------010102020708050306080909--
Re: Making EVL files known to Eclipse [message #21254 is a reply to message #21238] |
Tue, 30 June 2009 05:59  |
Hi Steffen,
1. is right but I'll have to check TEF/BatchValidator to see how they
actually work.
Dimitris
> Hi Dimitris,
> IBatchValidator validator = (IBatchValidator)
> problems listing
> Many thanks,
> Steffen
>> Hi Steffen,
>> screencast in
>> Cheers,
>> Dimitris
>>> Hi,
>>> Steffen
Re: Making EVL files known to Eclipse [message #569905 is a reply to message #21145] |
Hi Steffen,
screencast in
Dimitris
> Steffen
Re: Making EVL files known to Eclipse [message #570060 is a reply to message #21177] |
Hi Dimitris,
Many thanks,
Steffen
> Hi Steffen,
> screencast in
> Cheers,
> Dimitris
>> Steffen
<html>
<head>
</head>
Hi Dimitris,<br>
<br>
<br>
<ol>
</ol>
<blockquote>
</pre>
</blockquote>
<br>
Many thanks,<br>
<br>
Steffen<br>
<br>
Steffen,
<br>
<br>
screencast in
<br>
<br>
<br>
<br>
<br>
Dimitris
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Steffen
<br>
</blockquote>
</blockquote>
</body>
</html>
Re: Making EVL files known to Eclipse [message #570080 is a reply to message #21238] |
Hi Steffen,
actually work.
Dimitris
> Hi Dimitris,
> problems listing
> Many thanks,
> Steffen
>> Hi Steffen,
>> screencast in
>> Cheers,
>> Dimitris
>>> Hi,
>>> Steffen
Current Time: Sun Aug 31 11:20:12 EDT 2025
Powered by FUDForum. Page generated in 0.04262 seconds
