Home » Eclipse Projects » GEF » Heop with the IGoToMarker
Heop with the IGoToMarker [message #218107] Mon, 19 June 2006 15:31 Go to next message
Hello
I have a editor which extends the
org.eclipse.gef.ui.parts.GraphicalEditor, to generate graphical view a
model. I am able to use the createMarker() function to display problems
in the problems view. Selecting the problem , and using the GO TO
context menu, or double clicking on it, should select the particular
edit part.
Some search on the news group says to override the getAdapter(Object
class) class. But looks like this methods is not called where the value
of the class parameter is "IGoToMarker".
Is there anyway to implement this functionality
thanks
- Ani
Re: Heop with the IGoToMarker [message #724005 is a reply to message #218107] Sat, 10 September 2011 06:15 Go to previous messageGo to next message
I am also facing the same problem, if you find any solution to it, kindly share
Re: Heop with the IGoToMarker [message #724434 is a reply to message #724005] Mon, 12 September 2011 07:10 Go to previous message
The Problem is solved.
Previous Topic:placing child and parent to same dimension and simultaneously placing childrens on both layers
Next Topic:Direct Edit In Gef
Current Time: Tue Jul 22 12:07:14 EDT 2025
Powered by FUDForum. Page generated in 0.05287 seconds
