Home » Modeling » GMF (Graphical Modeling Framework) » How to use the provided edit.helpers?
How to use the provided edit.helpers? [message #218007] Mon, 09 February 2009 12:44 Go to next message
Originally posted by: cayla_sha.gmx.net
Hello!
There is a package called ...diagram.edit.helpers with empty classes for
every shape in the diagram.
I want special behaviour at the deletion of one of my shapes.
I thought, that I can implement my own actions in this EditHelpers when
one of my shapes is created, edited or deleted. Is that right?
But what do I have to do, that my methods are called?
I put in one of the XXXEditHelpers the method
getDestroyElementCommand(), but it`s never called.
The method XXXBaseEditHelper.getDestroyElementCommand() is always called.
Thanks in advance
Best wishes
Julia
Re: How to use the provided edit.helpers? [message #218080 is a reply to message #218007] Tue, 10 February 2009 05:39 Go to previous messageGo to next message
Hello Cayla,
See generated XXXBaseItemSemanticEditPolicy.getSemanticCommand() to see then
the EditHelpers are called.
If you just need to modify delete element behaviour why don't you change
corresponding ElementItemSemanticEditPolicy.getDestroyElementCommand()?
Alex Shatalin
Re: How to use the provided edit.helpers? [message #218118 is a reply to message #218080] Tue, 10 February 2009 08:31 Go to previous messageGo to next message
Alex Shatalin schrieb:
> Hello Cayla,
> then the EditHelpers are called.
I already debugged the call of the EditHelpers.
The problem is, that
XXXBaseItemSemanticEditPolicy.getSemanticCommand() calls (indirectly)
AbstractEditHelper.getEditCommand().
This calls XXXBaseEditHelper.getInsteadCommand().
This calls AbstractEditHelper.getInsteadCommand().
And this calls getDestroyElementCommand() - in XXXBaseEditHelper. But it
should call getDestroyElementCommand() in LocationEditHelper.
I don`t even understand, why it calls
XXXBaseEditHelper.getDestroyElementCommand() and not
AbstractEditHelper.getDestroyElementCommand(), because
AbstractEditHelper has its own method getDestroyElementCommand().
I already tried to out-comment the
XXXBaseEditHelper.getDestroyElementCommand(), because I hoped, that then
LocationEditHelper.getDestroyElementCommand() is called, but it didn`t work.
Perhaps I should call LocationEditHelper.getDestroyElementCommand() from
XXXBaseEditHelper.getDestroyElementCommand()? But I don`t know how I
should determine, that this call belongs to a Location and not to any
other class.
How do others use the edit-helpers? I already googled for edit helpers
but I didn`t find a lot. Only this page:
http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse. gmf.doc/tutorials/common/Extensible%20Type%20Registry/extens ibleTypeRegistryTutorial.html
But they don`t do anything else then writing the method in the empty
helper-class. I already checked my plugin.xml: the metamodelType with
the edithelper is there.
I think, thats not so good in my case, because I have one class called
"Location". This Location is represented by 6 different EditParts. I
want the special behaviour when the Location is deleted, no matter which
appearance it has at the moment.
There is one LocationEditHelper, but there are 6
ElementItemSemantivEditPolicies one for each EditPart. That means, I
would need to edit 6 classes instead of 1.
> Alex Shatalin
Re: How to use the provided edit.helpers? [message #218173 is a reply to message #218118] Tue, 10 February 2009 08:57 Go to previous messageGo to next message
Hello Cayla,
Isn't LocationEditHelper extends XXXBaseEditHelper?..
Alex Shatalin
Re: How to use the provided edit.helpers? [message #218181 is a reply to message #218118] Tue, 10 February 2009 08:58 Go to previous messageGo to next message
Problem solved :D
I did what I proposed in my former mail:
I call my LocationEditHelper.getDestroyElementCommand() in
XXXBaseEditHelper.getDestroyElementCommand():
* @generated NOT
protected ICommand getDestroyElementCommand(DestroyElementRequest req) {
if(req.getElementToDestroy().getClass().getSimpleName().
equals("LocationImpl"))
LocationEditHelper helper = new LocationEditHelper();
return helper.getDestroyElementCommand(req);
else
return null;
Re: How to use the provided edit.helpers? [message #218190 is a reply to message #218173] Tue, 10 February 2009 08:59 Go to previous messageGo to next message
> Hello Cayla,
Jupp, but how should this help?
> Alex Shatalin
Re: How to use the provided edit.helpers? [message #218197 is a reply to message #218173] Tue, 10 February 2009 09:00 Go to previous messageGo to next message
Hello Alex,
Well, this can be one of the other sublcasses of XXXBaseEditHelper (not only
LocationEditHelper).. Try placing a breakpoint into XXXBaseEditHelper.getDestroyElementCommand()
to see wich particular XXXEditHelper class will be called on deleting this
element (you can see a class of "this" variable in variables window of the
debugger.
Alex Shatalin
Re: How to use the provided edit.helpers? [message #218205 is a reply to message #218118] Tue, 10 February 2009 10:10 Go to previous message
Hello Julia,
I see you've already found a workaround for your issue, but in case you
need further information at a later date, I just wanted to point you to
the dev guide for the edit helpers:
http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse. gmf.doc/prog-guide/runtime/Developers%20Guide%20to%20the%20E xtensible%20Type%20Registry/Developers%20Guide%20to%20the%20 Extensible%20Type%20Registry.html
For deletion (and creation) the edit helper that corresponds to the
container of the element being deleted is the one that will be consulted.
Linda
>> Hello Cayla,
>> see then the EditHelpers are called.
> work.
> other class.
>> change corresponding
>> Alex Shatalin
Previous Topic:About BorderItemFigure like logic example
Next Topic:How GMF reuse EMF ?
Current Time: Fri Nov 21 15:31:44 EST 2025
Powered by FUDForum. Page generated in 0.04579 seconds
