Building eclipse Error [message #217748] |
Mon, 25 June 2007 05:40 |
Originally posted by: alexsy.integra-s.com
I`am have problem with building eclipse from sources
the my system enveromrnt:
PATH=/usr/local/jdk1.5.0_08/bin:/usr/local/ant-1.6.5/bin:/us r/bin:/bin:/usr/bin:
JAVA_HOME=/usr/local/jdk1.5.0_08
ANT_HOME=/usr/local/ant-1.6.5
The disk free space 24Gb
the eclipse sources 9efd9705c1dd4c22e2830a05d3cd291c00d844e9
/eclipse-sourceBuild-srcIncluded-3.2.2.zip
The last string after error:
[javac] The field IconExe.ImageData.TYPE_INDEX_1_LSB is never read
locally
[javac] ----------
[javac] 45. WARNING in
/mnt/lfs/home/eclipse/plugins/org.eclipse.pde.build/src/org/ eclipse/swt/tools/internal/IconExe.java
(at line 2984)
[javac] int xPelsPerMeter = (infoHeader[24] & 0xFF) |
((infoHeader[25] & 0xFF) << 8) | ((infoHeader[26] & 0xFF) << 16) |
((infoHeader[27] & 0xFF) << 24);
[javac] ^^^^^^^^^^^^^
[javac] The local variable xPelsPerMeter is never read
[javac] ----------
[javac] 46. WARNING in
(at line 2985)
[javac] int yPelsPerMeter = (infoHeader[28] & 0xFF) |
((infoHeader[29] & 0xFF) << 8) | ((infoHeader[30] & 0xFF) << 16) |
((infoHeader[31] & 0xFF) << 24);
[javac] The local variable yPelsPerMeter is never read
[javac] ----------
[javac] 46 problems (3 errors, 43 warnings)
BUILD FAILED
/mnt/lfs/home/eclipse/build.xml:60: The following error occurred while
executing this line:
/mnt/lfs/home/eclipse/build.xml:8: The following error occurred while
/mnt/lfs/home/eclipse/features/org.eclipse.sdk/build.xml:35: The following
error occurred while executing this line:
/mnt/lfs/home/eclipse/features/org.eclipse.sdk/build.xml:21: The following
/mnt/lfs/home/eclipse/features/org.eclipse.pde/build.xml:59: The following
/mnt/lfs/home/eclipse/features/org.eclipse.pde/build.xml:20: The following
/mnt/lfs/home/eclipse/plugins/org.eclipse.pde.build/build.xm l:192: The
following error occurred while executing this line:
/mnt/lfs/home/eclipse/plugins/org.eclipse.pde.build/build.xm l:103: Compile
failed; see the compiler error output for details.
Total time: 26 minutes 25 seconds
[javac] [writing
org/eclipse/jdt/internal/compiler/util/SimpleLookupTable.cla ss - #351]
[javac] [completed
/mnt/lfs/home/eclipse/jdtcoresrc/src/org/eclipse/jdt/interna l/compiler/util/SimpleLookupTable.java
- #318/322]
[javac] [analyzing
/mnt/lfs/home/eclipse/jdtcoresrc/src/org/eclipse/jdt/interna l/compiler/util/SimpleNameVector.java
- #319/322]
[javac] [writing
org/eclipse/jdt/internal/compiler/util/SimpleNameVector.clas s - #352]
[javac] [completed
- #319/322]
[javac] [analyzing
/mnt/lfs/home/eclipse/jdtcoresrc/src/org/eclipse/jdt/interna l/compiler/util/SimpleSet.java
- #320/322]
[javac] [writing
org/eclipse/jdt/internal/compiler/util/SimpleSet.class - #353]
[javac] [completed
- #320/322]
[javac] [analyzing
/mnt/lfs/home/eclipse/jdtcoresrc/src/org/eclipse/jdt/interna l/compiler/util/SuffixConstants.java
- #321/322]
[javac] [writing
org/eclipse/jdt/internal/compiler/util/SuffixConstants.class - #354]
[javac] [completed
- #321/322]
[javac] [analyzing
/mnt/lfs/home/eclipse/jdtcoresrc/src/org/eclipse/jdt/interna l/compiler/util/Util.java
- #322/322]
[javac] [reading java/io/FileInputStream.class]
[javac] [writing
org/eclipse/jdt/internal/compiler/util/Util$1.class - #355]
[javac] [writing
org/eclipse/jdt/internal/compiler/util/Util$Displayable.clas s - #356]
[javac] [writing org/eclipse/jdt/internal/compiler/util/Util.class
- #357]
[javac] [completed
- #322/322]
[javac] [322 units compiled]
[javac] [357 .class files generated]
at org.apache.tools.ant.Project.executeTargets(Project.java:106 8)
at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:382)
at org.apache.tools.ant.taskdefs.CallTarget.execute(CallTarget. java:107)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:275)
at org.apache.tools.ant.Task.perform(Task.java:364)
at org.apache.tools.ant.Target.execute(Target.java:341)
at org.apache.tools.ant.Target.performTasks(Target.java:369)
at org.apache.tools.ant.Project.executeSortedTargets(Project.ja va:1216)
at org.apache.tools.ant.Project.executeTarget(Project.java:1185 )
org.apache.tools.ant.helper.DefaultExecutor.executeTargets(D efaultExecutor.java:40)
at org.apache.tools.ant.Main.runBuild(Main.java:668)
at org.apache.tools.ant.Main.startAnt(Main.java:187)
at org.apache.tools.ant.launch.Launcher.run(Launcher.java:246)
at org.apache.tools.ant.launch.Launcher.main(Launcher.java:67)
FUDForum. Page generated in 0.09933 seconds
