Re: Project-specific preferences [message #217857 is a reply to message #217729] |
Mon, 25 June 2007 15:04 |
Originally posted by: wegener.cboenospam.com
"VK" <veerukrishnan@hotmail.com> wrote in message
news:f5nis7$hvq$1@build.eclipse.org...
> I noticed that not all preferences in Window -> Preferences have an option
> for "Project-specific settings". When trying to standardize all developers
> on a common set of preferences across multiple types of preferences, how
can
> I get around the limitation of only a few preference groups having this
> option?
> For example, the Java -> Compiler settings have this option, but Java ->
> Editor -> Mark Occurrences and Content Assist do not.
Do you really feel the need to force all developers to have the same Mark
Occurences and Content assist preference settings. These are settings that
only effect how a given developer interacts with the IDE. They don't result
in changes to source code or project related files that affect how others
see a given project.
Compiler settings make sense at a project level since they determine how an
application is built and how the source code is formatted/organized. This
allows the resulting .settings directory to be checked into your source
control system.
> How do you get around this issue?
> Unfortunately, many plugins also don't have this function built into their
> plugins. Will I have to dig through the generated metadata files and
extract
> the relevant settings into another file manually?
FUDForum. Page generated in 0.07497 seconds
