Home » Modeling » Epsilon » Trouble accessing java objects
Trouble accessing java objects [message #21113] Mon, 29 June 2009 08:20 Go to next message
Hi!
I've got some trouble accessing a java object within evl/eol.
The given example works fine:
var frame := new Native('javax.swing.JFrame');
But when I try to call my own object like
var clazz := new Native('workflow.validation.TestClass');
I'm getting the following error message:
"Type 'workflow.validation.TestClass' not found"
Any suggestions?
Greetings
Re: Trouble accessing java objects [message #21129 is a reply to message #21113] Mon, 29 June 2009 08:25 Go to previous messageGo to next message
Hi Arian,
You need to make Epsilon aware of your class. If it's not already in the
classpath, you can do this by providing an extension to the
org.eclipse.epsilon.common.dt.tool extension point. See
https://dev.eclipse.org/svnroot/modeling/org.eclipse.gmt.eps ilon/trunk/plugins/org.eclipse.epsilon.eol.dt.tools/plugin.x ml
for some examples.
Dimitris
Arian Storch wrote:
> Hi!
> I've got some trouble accessing a java object within evl/eol. The given
> example works fine:
> Any suggestions?
> Greetings
Re: Trouble accessing java objects [message #21162 is a reply to message #21129] Mon, 29 June 2009 13:21 Go to previous messageGo to next message
Hi Dimitris,
thanks for your advise. It works great now!
Greetings
Arian
Dimitris Kolovos wrote:
> Hi Arian,
> for some examples.
> Cheers,
> Dimitris
Re: Trouble accessing java objects [message #479757 is a reply to message #21162] Wed, 12 August 2009 07:33 Go to previous messageGo to next message
Hi All
I tried to use some native Java class in EOL but I haven't success. Even I used Dimitrios's and Louis's document named "Epsilon Tools" even information from this thread - if I start attached "nt.eol" script from inside of Eclipse, I will get error is "Type 'nativetest.NativeTest' not found". But if I start it from "generated" Eclipse application, script work ok.
Probably I must be something overlooking ... can someone take a look to attached sources and help me?
Thanks in advance
Ivo(sh)
Versions:
Eclipse Galileo Modeling Suite / Epsilon 0.8.6 on Linux 64bit
plugin.xml:
<?eclipse version="3.4"?>
<plugin>
<extension point="org.eclipse.epsilon.common.dt.tool">
<tool class="nativetest.NativeTest" defaultName="nativetest"/>
</extension>
</plugin>
MANIFEST.MF:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Nativetest
Bundle-SymbolicName: nativetest;singleton:=true
Bundle-Version: 1.0.0.qualifier
Bundle-Activator: nativetest.Activator
Require-Bundle: org.eclipse.core.runtime, org.eclipse.epsilon.common.dt;bundle-version="0.8.6", org.eclipse.epsilon.eol.engine;bundle-version="0.8.6"
Bundle-RequiredExecutionEnvironment: JavaSE-1.6
NativeTest.java:
package nativetest;
public class NativeTest {
public String hello() {
return "HELLO FROM NATIVE TEST RUN";
nt.eol:
'START'.println();
var x := new Native('nativetest.NativeTest');
x.println();
x.hello().println();
Re: Trouble accessing java objects [message #479765 is a reply to message #479757] Wed, 12 August 2009 08:59 Go to previous messageGo to next message
Hi Ivosh,
This is the expected behaviour as Epsilon couldn't possibly know
anything about your plugin until it is activated (i.e. in a runtime
workbench).
Dimitris
Ivosh Musil wrote:
> Hi All
> work ok.
> Thanks in advance
> Ivo(sh)
> Versions:
> plugin.xml:
> <plugin>
> </extension>
> </plugin>
> MANIFEST.MF:
> NativeTest.java:
> package nativetest;
> nt.eol:
> 'START'.println();
> x.println();
Re: Trouble accessing java objects [message #479780 is a reply to message #479765] Wed, 12 August 2009 09:42 Go to previous message
Hi Dimitris
> workbench).
thank for your quick (and easy :-) ) answer. Surely I need more studying
and practice on Eclipse plug-ins.
Ivo(sh)
Re: Trouble accessing java objects [message #569838 is a reply to message #21113] Mon, 29 June 2009 08:25 Go to previous message
Hi Arian,
for some examples.
Dimitris
Arian Storch wrote:
> Hi!
> example works fine:
> Any suggestions?
> Greetings
Re: Trouble accessing java objects [message #569891 is a reply to message #21129] Mon, 29 June 2009 13:21 Go to previous message
Hi Dimitris,
Greetings
Arian
> Hi Arian,
> for some examples.
> Cheers,
> Dimitris
Re: Trouble accessing java objects [message #573779 is a reply to message #21162] Wed, 12 August 2009 07:33 Go to previous message
Hi All
Thanks in advance
Ivo(sh)
Versions:
plugin.xml:
<plugin>
</extension>
</plugin>
MANIFEST.MF:
NativeTest.java:
package nativetest;
nt.eol:
'START'.println();
x.println();
Re: Trouble accessing java objects [message #573819 is a reply to message #573779] Wed, 12 August 2009 08:59 Go to previous message
Hi Ivosh,
workbench).
Dimitris
Ivosh Musil wrote:
> Hi All
> work ok.
> Thanks in advance
> Ivo(sh)
> Versions:
> plugin.xml:
> <plugin>
> </extension>
> </plugin>
> MANIFEST.MF:
> NativeTest.java:
> package nativetest;
> nt.eol:
> 'START'.println();
> x.println();
Re: Trouble accessing java objects [message #573933 is a reply to message #479765] Wed, 12 August 2009 09:42 Go to previous message
Hi Dimitris
> workbench).
Ivo(sh)
Previous Topic:[EGL] CrossReferences
Next Topic:[EGL] CrossReferences
Current Time: Sat Jul 26 06:02:37 EDT 2025
Powered by FUDForum. Page generated in 0.04944 seconds
