AJDT doesn't show advice markers in Maven projects [message #21074] |
Wed, 07 January 2009 04:38  |
Hi!
I use m2eclipse with the AJDT Integration with works great, except that
advice markers aren't shown. I'm not sure if this is a bug, a missing
feature or just a misconfiguration. As far as I understand AJDT needs
the woven class files to show advice markers, so it should work in theory...
Markus
Re: AJDT doesn't show advice markers in Maven projects [message #21092 is a reply to message #21074] |
Wed, 07 January 2009 10:43   |
Originally posted by: igor.ifedorenko.com
Markus,
Can you force full build of the project (Project->Clean...) and see if
this helps? I was told that AJDT only picks up changes to classpath
container during full build, so I wonder if this is the problem.
In any case, can you please submit a bugreport in JIRA [1] and provide
sample project that demonstrates the problem. Make sure to specify
details of your enviroment (at least Eclipse, AJDT and M2E versions).
Igor
Markus Knittig wrote:
> Hi!
> theory...
> Best regards,
> Markus
Re: AJDT doesn't show advice markers in Maven projects [message #21107 is a reply to message #21092] |
Wed, 07 January 2009 11:02  |
M2E JIRA URL http://jira.codehaus.org/browse/MNGECLIPSE
Igor Fedorenko wrote:
> Markus,
> Igor
>> Hi!
>> that advice markers aren't shown. I'm not sure if this is a bug, a
>> missing feature or just a misconfiguration. As far as I understand
>> AJDT needs the woven class files to show advice markers, so it should
>> work in theory...
>> Best regards,
>> Markus
FUDForum. Page generated in 0.05279 seconds
