Wrong project configuration build after Debug/Run Launch [message #217332] |
Thu, 12 June 2008 08:55 |
I have problems with the Run/Debug Launch configuration. My c project
contains about 500 source files with 100000 LOC. I'm working with several
project configurations (Application, Test, Profile). When I have changes
in source code and want to start a specific Run/Debug Launch configuration
the corresponding project configuration is even not built when I select
the correct configuration via the Build Configurations Toolbar before.
After the starting the Launch configuration the wrong one again is
selected. I already deletet the project and importet it again. The problem
remains the same.
I created a small test project. There this problem does not occur.
Does someone have the same problem, or knows about it?! How can I solve
this error?
My system configuration:
OS: Windows XP Professional
Eclipse build: Version: 3.3.2 - Build id: M20080221-1800
CDT version: 4.0.1.200709241202
Hardware: 2,4GHz Quad Core; 3,25 GB RAM
FUDForum. Page generated in 0.03549 seconds
