Home » Archived » Test and Performance Tools Platform (TPTP) » Does this Work with JAVA 5?
Does this Work with JAVA 5? [message #21066] Thu, 30 June 2005 05:40 Go to next message
Originally posted by: n.metchev.teamphone.com
I have tried to profile a Java 5 application using TPTP version 4, but it
seems that it crashes.
# An unexpected error has been detected by HotSpot Virtual Machine:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x7c91142e, pid=3484,
tid=1516
# Java VM: Java HotSpot(TM) Client VM (1.5.0_04-b05 mixed mode, sharing)
# Problematic frame:
# C
--------------- T H R E A D ---------------
Current thread (0x076bbe18): JavaThread "ReaderThread"
siginfo: ExceptionCode=0xc0000005, reading address 0x000000ff
Registers:
EAX=0x80676582, EBX=0x00c20000, ECX=0x000000ff, EDX=0x00c29418
ESP=0x0787fa4c, EBP=0x0787fc6c, ESI=0x00c29410, EDI=0x00000083
EIP=0x7c91142e, EFLAGS=0x00010246
Top of Stack: (sp=0x0787fa4c)
0x0787fa4c: 076bbed4 00000410 076bbed4 00000000
0x0787fa5c: 00000001 00000000 00000000 00000000
0x0787fa6c: 00000000 00000000 076bdd88 00000000
0x0787fa7c: 00000000 00000000 00000000 00000000
0x0787fa8c: 00000000 00000000 00000008 00000000
0x0787fa9c: 00000000 00030290 00000000 076bdd90
0x0787faac: 00000000 00000004 00000000 00030290
0x0787fabc: 00000020 00000000 00030320 0787fafc
Instructions: (pc=0x7c91142e)
0x7c91141e: 02 89 85 94 fe ff ff 8b 4a 04 89 8d ec fe ff ff
0x7c91142e: 8b 39 3b 78 04 0f 85 47 2f 02 00 3b fa 0f 85 3f
Stack:
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
=>0x076bbe18 JavaThread "ReaderThread"
0x01133378 JavaThread "Low Memory Detector" daemon
0x011321d0 JavaThread "CompilerThread0" daemon
0x0113f1f0 JavaThread "Signal Dispatcher" daemon
0x0112c9d8 JavaThread "Finalizer" daemon
0x0003fd40 JavaThread "Reference Handler" daemon
0x0003b170 JavaThread "main"
Other Threads:
0x0112bca8 VMThread [id=1576]
0x01131770 WatcherThread [id=2312]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 576K, used 576K [0x22a80000, 0x22b20000,
0x22f60000)
eden space 512K, 100% used [0x22a80000, 0x22b00000, 0x22b00000)
from space 64K, 100% used [0x22b00000, 0x22b10000, 0x22b10000)
to space 64K, 0% used [0x22b10000, 0x22b10000, 0x22b20000)
tenured generation total 1408K, used 860K [0x22f60000, 0x230c0000,
0x26a80000)
the space 1408K, 61% used [0x22f60000, 0x23037050, 0x23037200,
0x230c0000)
compacting perm gen total 8192K, used 117K [0x26a80000, 0x27280000,
0x2aa80000)
the space 8192K, 1% used [0x26a80000, 0x26a9d638, 0x26a9d800,
0x27280000)
ro space 8192K, 62% used [0x2aa80000, 0x2af893f0, 0x2af89400,
0x2b280000)
rw space 12288K, 46% used [0x2b280000, 0x2b80fe20, 0x2b810000,
0x2be80000)
Dynamic libraries:
0x00400000 - 0x0040c000 C:\Program Files\Java\jre1.5.0_04\bin\java.exe
0x7c900000 - 0x7c9b0000 C:\WINDOWS\system32\ntdll.dll
0x7c800000 - 0x7c8f4000 C:\WINDOWS\system32\kernel32.dll
0x77dd0000 - 0x77e6b000 C:\WINDOWS\system32\ADVAPI32.dll
0x77e70000 - 0x77f01000 C:\WINDOWS\system32\RPCRT4.dll
0x77c10000 - 0x77c68000 C:\WINDOWS\system32\MSVCRT.dll
0x6d640000 - 0x6d7c9000 C:\Program
Files\Java\jre1.5.0_04\bin\client\jvm.dll
0x77d40000 - 0x77dd0000 C:\WINDOWS\system32\USER32.dll
0x77f10000 - 0x77f56000 C:\WINDOWS\system32\GDI32.dll
0x76b40000 - 0x76b6d000 C:\WINDOWS\system32\WINMM.dll
0x6d280000 - 0x6d288000 C:\Program Files\Java\jre1.5.0_04\bin\hpi.dll
0x76bf0000 - 0x76bfb000 C:\WINDOWS\system32\PSAPI.DLL
0x10000000 - 0x10095000 C:\hyades\bin\piAgent.dll
0x71ab0000 - 0x71ac7000 C:\WINDOWS\system32\WS2_32.dll
0x71aa0000 - 0x71aa8000 C:\WINDOWS\system32\WS2HELP.dll
0x003b0000 - 0x003bb000 C:\hyades\bin\hcclco.dll
0x003c0000 - 0x003c8000 C:\hyades\bin\hccldt.dll
0x003d0000 - 0x003e1000 C:\hyades\bin\hcclsm.dll
0x003f0000 - 0x003fd000 C:\hyades\bin\hccls.dll
0x008a0000 - 0x008ab000 C:\hyades\bin\hcbnd.dll
0x6d610000 - 0x6d61c000 C:\Program Files\Java\jre1.5.0_04\bin\verify.dll
0x6d300000 - 0x6d31d000 C:\Program Files\Java\jre1.5.0_04\bin\java.dll
0x6d630000 - 0x6d63f000 C:\Program Files\Java\jre1.5.0_04\bin\zip.dll
0x71a50000 - 0x71a8f000 C:\WINDOWS\System32\mswsock.dll
0x76f20000 - 0x76f47000 C:\WINDOWS\system32\DNSAPI.dll
0x76fb0000 - 0x76fb8000 C:\WINDOWS\System32\winrnr.dll
0x76f60000 - 0x76f8c000 C:\WINDOWS\system32\WLDAP32.dll
0x76fc0000 - 0x76fc6000 C:\WINDOWS\system32\rasadhlp.dll
0x6d4c0000 - 0x6d4d3000 C:\Program Files\Java\jre1.5.0_04\bin\net.dll
0x662b0000 - 0x66308000 C:\WINDOWS\system32\hnetcfg.dll
0x71a90000 - 0x71a98000 C:\WINDOWS\System32\wshtcpip.dll
VM Arguments:
jvm_args: -XrunpiAgent:server=controlled
java_command:
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner -version 3 -port
1177 -test
com.teamphone.common.util.logging.analysis.TestReadXMLLog:te stReadXMLLog
Environment Variables:
CLASSPATH=C:\Source\Work\Proj\GCL\Libs\Java\TestCommon\stand ard\Binaries\Java2\Eclipse\TestCommon;C:\Source\Work\Proj\GC L\Libs\Java\Common\standard\Binaries\Java2\Eclipse\Common;C: \Source\Work\SDK\Redist\Java\JOI\v1.5\joi.jar;C:\Source\Work \SDK\Redist\Java\JNDI_LDAP_BOOSTER_PACK\v1.0\ldapbp.jar;C:\S ource\Work\SDK\Redist\Java\JakartaCommonsCollections\v3.0\co mmons-collections-3.0.jar;C:\Source\Work\SDK\Redist\Java\Tom cat\v4.1.24-LE-jdk14\servlet.jar;C:\Source\Work\SDK\Redist\J ava\JakartaCommonsPrimitives\v1.0\commons-primitives-1.0.jar ;C:\Source\Work\SDK\Redist\Java\JakartaCommonsCLI\v1.0\commo ns-cli-1.0.jar;C:\Source\Work\SDK\Redist\Java\JUnit\v3.8.1\j unit.jar;C:\Source\Work\SDK\Redist\Java\Xalan\v2.6.0\xalan.j ar;C:\Source\Work\SDK\Redist\Java\Axis\v1.2RC2\axis.jar;C:\S ource\Work\SDK\Redist\Java\Antlr\v2.7.2\antlr.jar;C:\Source\ Work\SDK\Redist\Java\StringTemplate\v2.1\stringtemplate.jar; C:\Source\Work\SDK\Redist\Java\JGoodiesLooks\v1.3\looks-1.3. jar;C:\Source\Work\SDK\Redist\Java\DOM4J\v1.6.1\dom4j-1.6.1. jar;C:\Source\Work\SDK\Redist\Java\Jaxen\v1.1beta6\jaxen-1.1 -beta-6.jar;C:\Source\Work\SDK\Redist\Java\Javassist\v3.0\ja vassist.jar;C:\Source\Work\SDK\Redist\Java\JakartaCommonsLan g\v2.1\commons-lang-2.1.jar;C:\Source\Work\SDK\Redist\Java\J Unit\v3.8.1\junit.jar;C:\Source\Work\SDK\Redist\Java\Jakarta CommonsLang\v2.0\commons-lang-2.0.jar;/c:/eclipse/plugins/or g.eclipse.jdt.junit_3.1.0/junitsupport.jar;/c:/eclipse/plugi ns/org.eclipse.jdt.junit.runtime_3.1.0/junitruntime.jar;C:\h yades\plugins\org.eclipse.tptp.platform.collection.framework _4.0.0\hcframe.jar;C:\hyades\plugins\org.eclipse.hyades.exec ution_4.0.0\hexr.jar;C:\hyades\plugins\org.eclipse.hyades.ex ecution_4.0.0\hexl.jar;C:\hyades\plugins\org.eclipse.hyades. execution_4.0.0\hexcore.jar;;C:\hyades\plugins\org.eclipse.c ore.runtime_3.1.0.jar
PATH=C:\hyades\bin;C:\Perl\bin\;C:\WINDOWS\system32;C:\WINDO WS;C:\WINDOWS\System32\Wbem;C:\Program
Files\StarTeam SDK 4.2\Lib;C:\Program Files\InstallShield\InstallShield 5.5
Professional Edition\Program;C:\MSSQL7\BINN;C:\Program
Files\doxygen\bin;C:\PROGRA~1\ATT\Graphviz\bin;C:\PROGRA~1\A TT\Graphviz\bin\tools;C:\Program
Files\Starbase\StarGate SDK\Lib;c:\Program
Files\SlickEdit\win\;C:\hyades\bin
USERNAME=n.metchev
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 15 Model 3 Stepping 4, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows XP Build 2600 Service Pack 2
CPU:total 2 family 15, cmov, cx8, fxsr, mmx, sse, sse2, ht
Memory: 4k page, physical 2095188k(1141012k free), swap 4035500k(3123660k
free)
vm_info: Java HotSpot(TM) Client VM (1.5.0_04-b05) for windows-x86, built on
Jun 3 2005 02:10:41 by "java_re" with MS VC++ 6.0
Re: Does this Work with JAVA 5? [message #21085 is a reply to message #21066] Thu, 30 June 2005 11:14 Go to previous messageGo to next message
At the moment TPTP4.0 supports Java runtime 1.4 as outlined in the
requirements section of the download page.
Thanks.
"Nikolay" <n.metchev@teamphone.com> wrote in message
news:da0eme$1au$1@news.eclipse.org...
> tid=1516
> # C
> Registers:
> Stack:
> Other Threads:
> Heap
> 0x22f60000)
> 0x26a80000)
> 0x230c0000)
> 0x2aa80000)
> 0x27280000)
> 0x2b280000)
> 0x2be80000)
> Dynamic libraries:
> VM Arguments:
> java_command:
> 1177 -test
> 5.5 Professional Edition\Program;C:\MSSQL7\BINN;C:\Program
> USERNAME=n.metchev
> OS=Windows_NT
> free)
> on Jun 3 2005 02:10:41 by "java_re" with MS VC++ 6.0
Re: Does this Work with JAVA 5? [message #21573 is a reply to message #21085] Mon, 11 July 2005 12:24 Go to previous messageGo to next message
Any plans for supporting Java 5?
"news.eclipse.org" <amehrega@ca.ibm.com> wrote in message
news:da1298$sq0$1@news.eclipse.org...
> Thanks.
>> tid=1516
>> # C
>> Registers:
>> Stack:
>> Other Threads:
>> Heap
>> 0x22f60000)
>> 0x26a80000)
>> 0x230c0000)
>> 0x2aa80000)
>> 0x27280000)
>> 0x2b280000)
>> 0x2be80000)
>> Dynamic libraries:
>> VM Arguments:
>> java_command:
>> 1177 -test
>> USERNAME=n.metchev
>> OS=Windows_NT
>> free)
Re: Does this Work with JAVA 5? [message #30001 is a reply to message #21573] Sun, 04 September 2005 13:57 Go to previous messageGo to next message
I would also like to know when java 1.5 will be supported.
Re: Does this Work with JAVA 5? [message #31145 is a reply to message #30001] Wed, 14 September 2005 08:41 Go to previous message
Hi Calvin,
There is no planned feature for adding support (e.g. testing) for Java
1.5 in TPTP. Please feel free to open a feature request
( http://www.eclipse.org/tptp/home/documents/process/developme nt/booking_feat
ures.html) if you or your organization require support Java 1.5.
Alternatively, please feel free to open defects for problems/issues you
experience problems running on Java 1.5.
Paul
"Calvin" <supercalbu@yahoo.com> wrote in message
news:692392631b2d13a6c70787158494831f$1@www.eclipse.org...
> Thanks
Previous Topic:Web services testing.
Next Topic:Websphere does not start up with piAgent
Current Time: Sat Jul 26 01:48:38 EDT 2025
Powered by FUDForum. Page generated in 0.06902 seconds
