Home » Eclipse Projects » GEF » Moving an Edit Part
Moving an Edit Part [message #21063] Thu, 26 September 2002 07:55 Go to next message
Originally posted by: g.wagenknecht.intershop.de
Hi!
I've have some trouble with source & target feedback when moving a graphical
edit part. This has worked befor so I think there is a problem in my
implementations of LayoutEditPolicy and NonResizableEditPolicy because I
reimplemeted these from ground up to fit it to my GridLayout.
Problem:
The ChangeBoundsRequest seems to have different coordinates.
Look at this debug string:
mouse: 123, 181
mouse: 118, 176
mouse: 122, 181
mouse: 117, 176
mouse: 121, 181
mouse: 116, 176
This string is generated by
MyLayoutEditPolicy#getConstraintFor(ChangeBoundsRequest, GraphicalEditPart)
with the following code.
Point mouseLocation = request.getLocation();
getLayoutContainer().translateToRelative(mouseLocation);
System.out.print("mouse: " + mouseLocation.x + ", " + mouseLocation.y);
As you can see, the method gets called twice. First time is from
MyLayoutEditPolicy#showDragTargetFeedback(Request) and the second time must
be from
ConstraintLayoutEditPolicy#getResizeChildrenCommand(ChangeBo undsRequest
request).
The difference is excatly 5,5 until the layout container is scrolled then it
is more. 5 could be because of the MarginBorder of the LayoutContainer but
I'm not sure.
Where does the different come from?
Cu, Gunnar
Re: Moving an Edit Part [message #21081 is a reply to message #21063] Thu, 26 September 2002 08:58 Go to previous messageGo to next message
Hi!
Problem solved!
wrong:
You must ensure that you always use copies of the original request / host
figure bounds, locations, deltas.
Cu, Gunnar
Re: Moving an Edit Part [message #21110 is a reply to message #21081] Thu, 26 September 2002 09:44 Go to previous message
Originally posted by: hudsonr.us.eye-bee-em.com
"Gunnar Wagenknecht" <g.wagenknecht@intershop.de> wrote in message
news:amuv57$po5$1@rogue.oti.com...
> Hi!
> Problem solved!
> wrong:
That is correct. You can use
Point.SINGLETON.setLocation(request.getLocation()) if you want to avoid
newing objects. But only do that if your paranoid about the expense of
newing objects, like me.
> Cu, Gunnar
Previous Topic:Drawing Connection in Logic Editor example
Next Topic:Drag and Drop behaviour in Logic Editor Example
Current Time: Sun Jul 27 12:36:39 EDT 2025
Powered by FUDForum. Page generated in 0.03835 seconds
