Home » Eclipse Projects » Nebula » CompositeTable download is live
CompositeTable download is live [message #21062] Thu, 14 December 2006 16:26 Go to next message
The Nebula CompositeTable web site is now live.
http://www.eclipse.org/nebula/widgets/compositetable/composi tetable.php
For the impatient, there is a 30-second introductory screencast:
http://www.eclipse.org/nebula/widgets/compositetable/screenc asts/30sec.html
The control, source code, current snippets, and JavaDoc may be
downloaded there via the Coconut Palm Software mirror and through
Eclipse.org and its mirrors as soon as Chris gets the zip uploaded there
too.
David Orme
Senior Consultant
Coconut Palm Software, Inc.
http://www.coconut-palm-software.com
Re: CompositeTable download is live [message #21080 is a reply to message #21062] Fri, 15 December 2006 04:05 Go to previous messageGo to next message
Hi David,
good work. One question you stated in another thread that you started
working on TableViewer-API.
Can JFace provide something take makes this easier to you? I think you
saw our new AbstractTableViewer.
I also submitted you a small bug when running in none EN-Locales ;-)
https://bugs.eclipse.org/bugs/show_bug.cgi?id=168175
Tom
> too.
> Best regards,
> David Orme
> Senior Consultant
Re: CompositeTable download is live [message #21097 is a reply to message #21080] Fri, 15 December 2006 04:27 Go to previous messageGo to next message
Hi David,
I'm having more issues with CompositeTable-Snippets and the current
CVS-Version. Maybe I'm doing something wrong:
Snippet 1:
I. Issue
On WinXP:
1. Entering text in First Name and Last Name in Row 1
2. Scrolling down to the bottom (the first line reoccurs at certain
positions)
3. Scrolling up the first line is empty and my text occurs in 2nd line
4. Scrolling down to bottom (the first line reoccurs at certain positions)
5. Scrolling up the first 6 lines are empty and my text occurs in the
7th line
II. Issue
On Gtk2:
positions)
3. Scrolling up the first line empty and my text occurs in 2nd line
5. Scrolling up the first line empty and my text occurs in 2nd line
III. Issue
On Gtk2+WinXP: Scrolling fast throws an exception
> Exception in thread "main" java.lang.IndexOutOfBoundsException: Request for a nonexistent row
> at org.eclipse.swt.nebula.widgets.compositetable.InternalCompos iteTable.getControl(InternalCompositeTable.java:2059)
> at org.eclipse.swt.nebula.widgets.compositetable.InternalCompos iteTable.resetFocus(InternalCompositeTable.java:783)
> at org.eclipse.swt.nebula.widgets.compositetable.InternalCompos iteTable.refreshAllRows(InternalCompositeTable.java:758)
> at org.eclipse.swt.nebula.widgets.compositetable.InternalCompos iteTable.updateVisibleRows(InternalCompositeTable.java:607)
> at org.eclipse.swt.nebula.widgets.compositetable.InternalCompos iteTable.setTopRow(InternalCompositeTable.java:951)
> at org.eclipse.swt.nebula.widgets.compositetable.InternalCompos iteTable$3.widgetSelected(InternalCompositeTable.java:1472)
> at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1085)
> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3164)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2840)
> at org.eclipse.swt.nebula.snippets.compositetable.CompositeTabl eSnippet0.main(CompositeTableSnippet0.java:59)
IV. Issue
On Gtk2+WinXP: Scrolling by clicking in Empty space in scrollbar throws
an exception
The exception is the same as the one above.
Issue III and IV are reproduceable in other snippets if you resize them
so that the scrolling gets faster.
Tom
Tom Schindl schrieb:
> Hi David,
> Tom
>> too.
>> Best regards,
>> David Orme
>> Senior Consultant
Re: CompositeTable download is live [message #21128 is a reply to message #21080] Fri, 15 December 2006 09:00 Go to previous messageGo to next message
Tom Schindl wrote:
> Hi David,
Thanks!
Dave
Re: CompositeTable download is live [message #21144 is a reply to message #21097] Fri, 15 December 2006 09:05 Go to previous messageGo to next message
Tom Schindl wrote:
> Hi David,
> Snippet 1:
> I. Issue
> On WinXP:
> positions)
> 7th line
Hmmm. I'll look at this. There was an issue with entering text into
row 1. I've never seen the other ones though. Thanks for the detailed
instructions.
> II. Issue
> On Gtk2:
> positions)
This is probably the same as the first.
> III. Issue
This was found and fixed last night (CST). It's actually a patch on top
of a patch that works around a win32 bug. :) (For the interested,
search for the comment "FEATURE IN WINDOWS" in InternalCompositeTable.)
> IV. Issue
> an exception
Same as previous.
Thanks much for the feedback!
Dave Orme
Re: CompositeTable download is live [message #21178 is a reply to message #21097] Fri, 15 December 2006 09:30 Go to previous messageGo to next message
Bug 168205 has been added to the database
Tom Schindl wrote:
> Hi David,
> Snippet 1:
> I. Issue
> On WinXP:
> positions)
> 7th line
> II. Issue
> On Gtk2:
> positions)
> III. Issue
> IV. Issue
> an exception
> Tom
>> Hi David,
>> Tom
>>> too.
>>> Best regards,
>>> David Orme
>>> Senior Consultant
Re: CompositeTable download is live [message #21192 is a reply to message #21097] Fri, 15 December 2006 13:49 Go to previous message
I found and fixed the IndexOutOfBoundsException, and have tested Snippet
1 on both Windows XP and on Linux/GTK. Everything works fine for me
here both using the keyboard and scroll bar. The fix is in HEAD and
I'll upload a new build tonight.
Note that Snippet 1 doesn't hook up any editing features, so the things
you reported related to editing are related to that.
This should get you up and running again. Please let me know if you
still have any issues.
Dave Orme
Tom Schindl wrote:
> Hi David,
> Snippet 1:
> I. Issue
> On WinXP:
> positions)
> 7th line
> II. Issue
> On Gtk2:
> positions)
> III. Issue
> IV. Issue
> an exception
> Tom
>> Hi David,
>> Tom
>>> too.
>>> Best regards,
>>> David Orme
>>> Senior Consultant
Re: CompositeTable download is live [message #572813 is a reply to message #21062] Fri, 15 December 2006 04:05 Go to previous message
Hi David,
Tom
> too.
> Best regards,
> David Orme
> Senior Consultant
Re: CompositeTable download is live [message #572844 is a reply to message #21080] Fri, 15 December 2006 04:27 Go to previous message
Hi David,
Snippet 1:
I. Issue
On WinXP:
positions)
7th line
II. Issue
On Gtk2:
positions)
III. Issue
IV. Issue
an exception
Tom
> Hi David,
> Tom
>> too.
>> Best regards,
>> David Orme
>> Senior Consultant
Re: CompositeTable download is live [message #572912 is a reply to message #21080] Fri, 15 December 2006 09:00 Go to previous message
Tom Schindl wrote:
> Hi David,
Thanks!
Dave
Re: CompositeTable download is live [message #572941 is a reply to message #21097] Fri, 15 December 2006 09:05 Go to previous message
Tom Schindl wrote:
> Hi David,
> Snippet 1:
> I. Issue
> On WinXP:
> positions)
> 7th line
instructions.
> II. Issue
> On Gtk2:
> positions)
> III. Issue
> IV. Issue
> an exception
Same as previous.
Dave Orme
Re: CompositeTable download is live [message #572993 is a reply to message #21097] Fri, 15 December 2006 09:30 Go to previous message
Tom Schindl wrote:
> Hi David,
> Snippet 1:
> I. Issue
> On WinXP:
> positions)
> 7th line
> II. Issue
> On Gtk2:
> positions)
> III. Issue
> IV. Issue
> an exception
> Tom
>> Hi David,
>> Tom
>>> too.
>>> Best regards,
>>> David Orme
>>> Senior Consultant
Re: CompositeTable download is live [message #573024 is a reply to message #21097] Fri, 15 December 2006 13:49 Go to previous message
Dave Orme
Tom Schindl wrote:
> Hi David,
> Snippet 1:
> I. Issue
> On WinXP:
> positions)
> 7th line
> II. Issue
> On Gtk2:
> positions)
> III. Issue
> IV. Issue
> an exception
> Tom
>> Hi David,
>> Tom
>>> too.
>>> Best regards,
>>> David Orme
>>> Senior Consultant
Previous Topic:CompositeTable download is live
Next Topic:java.lang.NoClassDefFoundError: org/eclipse/swt/widgets/Canvas
Current Time: Mon Sep 01 01:10:26 EDT 2025
Powered by FUDForum. Page generated in 0.07903 seconds
