Error in detection of the JVM version [message #217019] |
Wed, 20 June 2007 19:21 |
Originally posted by: michelefanelli.gmail.com
I am not able to install the most recent version of eclipse, because it
seems to detect a version of the JVM that does not correspond to the one
that i have installed on my PC
Eclipse version
eclipse-SDK-3.2.2-win32
Java SDK version
j2sdk-1_4_2_14-windows-i586-p.exe
I always receive the message Version 1.3.1_01 of the JVM is not suitable
for this product. Version 1.4.1 or greater is required. Does anyone of you
how can I solve this problem? I tried uninstalling the previous version
and reinstalled everything but.. the message didn't change
Thank you very much
Michele
Re: Error in detection of the JVM version [message #217035 is a reply to message #217019] |
Wed, 20 June 2007 19:54 |
Originally posted by: csae7511.uibk.ac.at
have you checked your environment variables, especially "PATH"?
If the path to your java installation dir is not added, it may uses the
java implementation of Windows.
HTH,
Stefan
> Eclipse version
> Java SDK version
> you how can I solve this problem? I tried uninstalling the previous
> version and reinstalled everything but.. the message didn't change
> Thank you very much
> Michele
Re: Error in detection of the JVM version [message #217182 is a reply to message #217019] |
Thu, 21 June 2007 14:23 |
This is a FAQ - please search the archives before posting questions.
If you don't explicitly specify a JRE to use, Eclipse looks in various
places to find one. In your case, it is finding 1.3, probably because it
is installed on your system binary path.
Use the -vm option to specify to Eclipse exactly what JVM you want it to
use. Note it is also recommended to tweak the JVM memory settings from
their defaults using -vmargs.
A Google or Eclipse.org search will yield all the details on using those
options in eclipse.ini
Hope this helps,
Eric
FUDForum. Page generated in 0.08232 seconds
