Out of memory error while building a project in the Run bench [message #216911] |
Wed, 20 June 2007 05:20 |
Originally posted by: rashmidonthi.gmail.com
I launch a run bench with argument -Xmx512m. Workspace has around 2000
files and during the build i get OutOfMemoryError. I tried launching the
dev bench with vm arguments -mx256m as well as -mx512m. Is ther any other
arguments i should use and any other options to be set?
Thank you in advance,
Rashmi Donthi
Re: Out of memory error while building a project in the Run bench [message #217043 is a reply to message #216911] |
Wed, 20 June 2007 19:59 |
Originally posted by: csae7511.uibk.ac.at
perhaps you are running out of permgen space (I sometimes experienced
problems with it) - try:
-vmargs -XX:MaxPermSize=128M
Furthermore it is possible that the arguments are actually not passed to
eclipse (e.g. due to using a shortcut in Windows). You can check the
arguments you passed in Help --> About Eclipse SDK --> Configuration
Details.
HTH,
Stefan
Rashmi schrieb:
> other arguments i should use and any other options to be set?
> Rashmi Donthi
Re: Out of memory error while building a project in the Run bench [message #217368 is a reply to message #217043] |
Fri, 22 June 2007 10:05 |
Thank you it worked.
"Stefan Zugal" <csae7511@uibk.ac.at> wrote in message
news:f5c0vj$m0f$1@build.eclipse.org...
> Details.
> HTH,
> Stefan
> Rashmi schrieb:
> > Hi,
> > Rashmi Donthi
Re: Out of memory error while building a project in the Run bench [message #217994 is a reply to message #217368] |
Tue, 26 June 2007 09:29 |
Increasing the permgen size works only when one builder is turned on at a
time. But with all the builders on it goes out of memory.
I tried increasing the permgen size to 256 and also tried using -mx640m. It
did not help:(
Is there any other solution?
"Rashmi" <rashmidonthi@gmail.com> wrote in message
news:f5g789$l14$1@build.eclipse.org...
> > Hi,
> > Details.
> > HTH,
> > Stefan
> > Rashmi schrieb:
> > > Hi,
2000
the
> > > Rashmi Donthi
Re: Out of memory error while building a project in the Run bench [message #218089 is a reply to message #217994] |
Tue, 26 June 2007 15:36 |
> did not help:(
You need to use -Xmx, not -mx.
Here is an example of the eclipse.ini that I use and it never has memory
problems even with huge workspaces and dozens of plugins:
-vm
D:\Java\JDK\5.0\bin\javaw.exe
-vmargs
-Xms128m
-Xmx512m
-XX:MaxPermSize=128m
Hope this helps,
Eric
Re: Out of memory error while building a project in the Run bench [message #218578 is a reply to message #218089] |
Thu, 28 June 2007 05:14 |
Thanks but it did not help. I had to use -Xmx1024m to overcome the out of
memory error.
"Eric Rizzo" <eclipse5@rizzoweb.com> wrote in message
news:f5rbq1$ejs$4@build.eclipse.org...
a
It
> > did not help:(
> -vm
> -vmargs
> -Xms128m
> -Xmx512m
> Hope this helps,
> Eric
FUDForum. Page generated in 0.09106 seconds
