Home » Modeling » Epsilon » Executing ANT workflow with Epsilon tasks included: Tasks not found?
Executing ANT workflow with Epsilon tasks included: Tasks not found? [message #21025] Wed, 24 June 2009 09:42 Go to next message
--------------070300080409050002080606
Hi all,
This may be a very stupid question, but I seem to be missing something
here: I've written a simple ANT workflow that uses some of the Epsilon
tasks. The ANT editor in Eclipse finds the tasks and happily offers them
and their parameters to me as part of its autocompletion. So, somehow,
they seem to be registered correctly. However, once I trigger the build
script using Run As/Ant Build, the build fails and ANT complains about
not finding the task definitions. Here's what it says:
...\build.xml:12: Problem: failed to create task or type
epsilon.emf.loadModel
Cause: The name is undefined.
I am using Epsilon from SVN, that is, I have one Eclipse instance in
which I have some of the Epsilon projects open (...workflow among them)
and from this start a second Eclipse instance which contains my actual
workflow. If I look at the launch configuration for my ANT script, it
actually doesn't refer to the workflow.jar file created as part of the
workflow project. I might be able to add this manually, but I assumed
this should happen automatically?
Steffen
Dr. rer. nat. Steffen Zschaler
Senior Research Associate
Lancaster University
Lancaster, United Kingdom
Email szschaler@acm.org
Phone +44 (01524) 510354
WWW http://www.steffen-zschaler.de/
<html>
<head>
</head>
Hi all,<br>
<br>
them and their parameters to me as part of its autocompletion. So,
somehow, they seem to be registered correctly. However, once I trigger
the build script using Run As/Ant Build, the build fails and ANT
complains about not finding the task definitions. Here's what it says:<br>
<blockquote><tt>...\build.xml:12: Problem: failed to create task or
type epsilon.emf.loadModel<br>
Cause: The name is undefined.</tt><br>
</blockquote>
this should happen automatically?<br>
<br>
Cheers,<br>
<br>
Steffen<br>
<pre class="moz-signature" cols="72">--
Email <a class="moz-txt-link-abbreviated" href="mailto:szschaler@acm.org">szschaler@acm.org</a>
WWW <a class="moz-txt-link-freetext" href="http://www.steffen-zschaler.de/">http://www.steffen-zschaler.de/</a></pre>
</body>
</html>
--------------070300080409050002080606--
Re: Executing ANT workflow with Epsilon tasks included: Tasks not found? [message #21039 is a reply to message #21025] Wed, 24 June 2009 09:53 Go to previous messageGo to next message
As additional information: Checking the global Ant preferences and, in
particular, the 'Runtime' category, I find that workflow.jar is there
alright and all the Epsilon tasks are listed as well. I'm sure I'm doing
something wrong somewhere, but I have no idea where...
Any hints are appreciated!
Steffen
Steffen Zschaler wrote:
> Hi all,
> them) and from this start a second Eclipse instance which contains my
> actual workflow. If I look at the launch configuration for my ANT
> script, it actually doesn't refer to the workflow.jar file created as
> part of the workflow project. I might be able to add this manually,
> but I assumed this should happen automatically?
> Cheers,
> Steffen
Re: Executing ANT workflow with Epsilon tasks included: Tasks not found? [message #21053 is a reply to message #21039] Wed, 24 June 2009 10:03 Go to previous messageGo to next message
Mmh. It seems that this works OK when I tell it to run ANT in the same
VM as the IDE (which unfortunately is not the default). But why does it
not work when running in a separate VM?
Steffen
> doing something wrong somewhere, but I have no idea where...
> Steffen
>> Hi all,
>> something here: I've written a simple ANT workflow that uses some of
>> the Epsilon tasks. The ANT editor in Eclipse finds the tasks and
>> happily offers them and their parameters to me as part of its
>> autocompletion. So, somehow, they seem to be registered correctly.
>> However, once I trigger the build script using Run As/Ant Build, the
>> build fails and ANT complains about not finding the task definitions.
>> Cheers,
>> Steffen
Re: Executing ANT workflow with Epsilon tasks included: Tasks not found? [message #21083 is a reply to message #21053] Wed, 24 June 2009 10:45 Go to previous messageGo to next message
Hi Steffen,
I have to admit I'm not quite sure either. I suspect it has something to
do with the (non) visibility of org.eclipse.epsilon.workflow.jar to the
new VM. Could you please open a bug so that we can track any further
investigation on this?
Dimitris
> Steffen
>> Thanks,
>> Steffen
>>> Hi all,
>>> Cheers,
>>> Steffen
Re: Executing ANT workflow with Epsilon tasks included: Tasks not found? [message #21099 is a reply to message #21083] Wed, 24 June 2009 10:52 Go to previous message
Sure: https://bugs.eclipse.org/bugs/show_bug.cgi?id=281354
Steffen
Dimitris Kolovos wrote:
> Hi Steffen,
> to do with the (non) visibility of org.eclipse.epsilon.workflow.jar to
> the new VM. Could you please open a bug so that we can track any
> further investigation on this?
> Cheers,
> Dimitris
>> same VM as the IDE (which unfortunately is not the default). But why
>> does it not work when running in a separate VM?
>> Steffen
>>> in particular, the 'Runtime' category, I find that workflow.jar is
>>> there alright and all the Epsilon tasks are listed as well. I'm sure
>>> I'm doing something wrong somewhere, but I have no idea where...
>>> Thanks,
>>> Steffen
>>>> Hi all,
>>>> of the Epsilon tasks. The ANT editor in Eclipse finds the tasks and
>>>> the build fails and ANT complains about not finding the task
>>>> in which I have some of the Epsilon projects open (...workflow
>>>> among them) and from this start a second Eclipse instance which
>>>> contains my actual workflow. If I look at the launch configuration
>>>> for my ANT script, it actually doesn't refer to the workflow.jar
>>>> file created as part of the workflow project. I might be able to
>>>> add this manually, but I assumed this should happen automatically?
>>>> Cheers,
>>>> Steffen
Re: Executing ANT workflow with Epsilon tasks included: Tasks not found? [message #569687 is a reply to message #21025] Wed, 24 June 2009 09:53 Go to previous message
Steffen
> Hi all,
> Cheers,
> Steffen
Re: Executing ANT workflow with Epsilon tasks included: Tasks not found? [message #569718 is a reply to message #21039] Wed, 24 June 2009 10:03 Go to previous message
Steffen
> Steffen
>> Hi all,
>> Cheers,
>> Steffen
Re: Executing ANT workflow with Epsilon tasks included: Tasks not found? [message #569763 is a reply to message #21053] Wed, 24 June 2009 10:45 Go to previous message
Hi Steffen,
Dimitris
> Steffen
>> Thanks,
>> Steffen
>>> Hi all,
>>> Cheers,
>>> Steffen
Re: Executing ANT workflow with Epsilon tasks included: Tasks not found? [message #569781 is a reply to message #21083] Wed, 24 June 2009 10:52 Go to previous message
Steffen
> Hi Steffen,
> Cheers,
> Dimitris
>> Steffen
>>> Thanks,
>>> Steffen
>>>> Hi all,
>>>> Cheers,
>>>> Steffen
Previous Topic:Missing build.xml in org.eclipse.epsilon.workflow?
Next Topic:Trouble accessing java objects
Current Time: Wed Aug 13 15:06:12 EDT 2025
Powered by FUDForum. Page generated in 0.05279 seconds
