Home » Newcomers » Newcomers » Accessing the Oracle source for BIRT Report Design.
Accessing the Oracle source for BIRT Report Design. [message #216696] Tue, 19 June 2007 10:01 Go to next message
Originally posted by: senthil_gugan.yahoo.co.in
I have this problem:
I am using Eclipse BIRT 2.1.0 for report design and like to use the
Oracle 10g DB source for my report design project. I am using the Linux
suse OS.
Now I would like to know that how can I connect the BIRT report to the
Oracle Database.
Any suggestion or help is most welcome.
Senthil.
Re: Accessing the Oracle source for BIRT Report Design. [message #216842 is a reply to message #216696] Tue, 19 June 2007 16:54 Go to previous messageGo to next message
Senthil wrote:
> suse OS.
> Oracle Database.
> Senthil.
Hi. You probably should post this question in the eclipse.birt. Hope
this helps. Mark Dexter
Re: Accessing the Oracle source for BIRT Report Design. [message #216969 is a reply to message #216696] Wed, 20 June 2007 05:39 Go to previous messageGo to next message
Originally posted by: r.rishikesh.gmail.com
Hi Senthil,
You would need to set up data source for the report. This would be a jdbc
connection to your Oracle database.
Are you looking for exact steps to do the same?
Rishikesh R.
Re: Accessing the Oracle source for BIRT Report Design. [message #216985 is a reply to message #216969] Wed, 20 June 2007 07:54 Go to previous message
Hi Rishikesh,
Thanks for your reply.
Yes, I looking for the same.
It would be very much helpful for me if I get the solution.
Senthil.
Previous Topic:treeview with different classes
Next Topic:Logging and reporting errors
Current Time: Wed Oct 22 23:35:20 EDT 2025
Powered by FUDForum. Page generated in 0.05905 seconds
