Error launching debugger [message #216520] |
Mon, 26 May 2008 12:46 |
Originally posted by: trash.hotmail.com
I have a project that build executables outside the project directory
and when I try to debug my executable, I get a error:
An internal error occurred during: 'Launching liwidentify".
java.lang.NullPointerException.
Linux64 / Eclipse 3.3.2
Thank you for your help.
Re: Error launching debugger [message #216527 is a reply to message #216520] |
Mon, 26 May 2008 13:01 |
Originally posted by: nospam.net.net
exquisitus wrote:
> Hello,
This happens to me from time to time. All I have to do is to re-set the
breakpoints, and just continue with debugging. It may work for you too.
CDT 4.0.2, Eclipse 3.3.1.1, Linux32.
Martin
UNDERSCOREmmiATcentrumDOTcz to email me.
Re: Error launching debugger [message #216535 is a reply to message #216527] |
Mon, 26 May 2008 13:03 |
Good to know, but actually I don't have any breakpoints...
Re: Error launching debugger [message #216542 is a reply to message #216520] |
Mon, 26 May 2008 14:56 |
Originally posted by: jamesblackburn+eclipse.mac.com
exquisitus wrote:
> Hello,
Can you post a more details Excpetion back trace? It's impossible to
know what's going wrong without it. Have a look at the Error Log file:
under <workspace>/.metadata/.log. You also didn't say what version of
CDT you're using.
James
Re: Error launching debugger [message #216550 is a reply to message #216542] |
Mon, 26 May 2008 15:04 |
James Blackburn wrote:
> exquisitus wrote:
>> Hello,
> CDT you're using.
The CDT I use is 4.0.3, and here is the log :
java.lang.NullPointerException at
org.eclipse.cdt.launch.AbstractCLaunchDelegate.setBuildConfi guration(AbstractCLaunchDelegate.java:565)
org.eclipse.cdt.launch.AbstractCLaunchDelegate.buildForLaunc h(AbstractCLaunchDelegate.java:541)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:727)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:608)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:899)
org.eclipse.debug.internal.ui.DebugUIPlugin$7.run(DebugUIPlu gin.java:1102)
Furthermore, I can tell you that I have 4 projects in my workspace :
- a stand alone project, which works fine
- 2 static lib projects
- a applications project depending on the 2 static lib projects. Here I
can't debug the executables.
- Guillaume -
Re: Error launching debugger [message #216559 is a reply to message #216550] |
Mon, 26 May 2008 15:15 |
By the way, it might be useful for you to know that I do not have
automatic Makefile, but my owns. Also I removed 'Release' and 'Debug'
for each of my projects configurations and created a 'Default'
configuration instead.
G.
Re: Error launching debugger [message #216575 is a reply to message #216550] |
Mon, 26 May 2008 20:47 |
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
For some reason the Launch configuration you're trying to run has a
build configuration ID set on it that doesn't/no longer exists in the
project... You could try a couple things:
1) create a new launch configuration (not by copying the old one) for
the executable.
2) Disabling building before launch: Window > Preferences > Launching >
Build (if required) before launch.
You should probably also file a bug against CDT, as it looks like this
bug still exists in CDT 5
James
Re: Error launching debugger [message #216614 is a reply to message #216575] |
Tue, 27 May 2008 08:50 |
> the executable.
FYI, I have found a workaround: in order to create a debug
configuration, I first build my executables, then I right-click on it in
the 'Binaries' folder in the C/C++ view, I then select 'Properties' and
then with the 'Run/Debug Setting' panel, I was able to create a valid
configuration.
It seems that there is a bug when creating a debug configuration from
the Menu->Run->Open Debug Dialog.
Anyway, could you tell me where to fill a bug against CDT?
Thank you.
Re: Error launching debugger [message #216618 is a reply to message #216614] |
Tue, 27 May 2008 15:28 |
Originally posted by: elaskavaia.qnx.com
I think this is bug when you copy launch configuration and it is fixed already
>> the executable.
> configuration.
> Thank you.
Re: Error launching debugger [message #216757 is a reply to message #216618] |
Thu, 29 May 2008 08:17 |
> already
Woops, it seems you did indeed fix this :). It seems my HEAD checkout
is somewhat behind...
Thanks Alena!
James
FUDForum. Page generated in 0.03435 seconds
