Home » Newcomers » Newcomers » eclipse 3.2.2 crashes using java 1.6
eclipse 3.2.2 crashes using java 1.6 [message #216389] |
Sun, 17 June 2007 12:09  |
Originally posted by: hicham.dev.menara.ma
--------------050004080506030904030903
hello
here is the error message :
# An unexpected error has been detected by Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x00002aaaaaab41bd, pid=3579, tid=1076017488
# Java VM: Java HotSpot(TM) 64-Bit Server VM (1.6.0_01-b06 mixed mode)
# Problematic frame:
# C [ld-linux-x86-64.so.2+0x91bd]
# An error report file with more information is saved as hs_err_pid3579.log
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
attached hs_err_pid3579.log
Content-Type: text/x-log;
name="hs_err_pid3847.log"
Content-Disposition: inline;
filename="hs_err_pid3847.log"
# SIGSEGV (0xb) at pc=0x00002aaaaaab41bd, pid=3847, tid=1076017488
--------------- T H R E A D ---------------
Current thread (0x0000000040112400): JavaThread "main" [_thread_in_native, id=3848]
siginfo:si_signo=11, si_errno=0, si_code=1, si_addr=0x0000000000000000
Registers:
RAX=0x0000000000000000, RBX=0x00002aaaaacc4bc0, RCX=0x00002aaac9738c5e, RDX=0x0000000000000000
RSP=0x0000000040228140, RBP=0x0000000040228280, RSI=0x0000000000000000, RDI=0x00002aaac9738c55
R8 =0x0000000000000000, R9 =0x0000000000000000, R10=0x0000000000000000, R11=0x00000000ffffffff
R12=0x00002aaaaacc54e8, R13=0x00000000b1b73c55, R14=0x0000000000000000, R15=0x0000000000000000
RIP=0x00002aaaaaab41bd, EFL=0x0000000000010246, CSGSFS=0x0000000000000033, ERR=0x0000000000000004
TRAPNO=0x000000000000000e
Top of Stack: (sp=0x0000000040228140)
0x0000000040228140: 00002aaabfba9a9e 0000000040228198
0x0000000040228150: 00002aaabfcbcdb0 0000000000000000
0x0000000040228160: 00002aaabfba9ac0 0000000000000000
0x0000000040228170: 0000000040228198 0000000040228200
0x0000000040228180: 00002aaaaca5632e 0000000000000000
0x0000000040228190: 0000000000000000 0000000040228330
0x00000000402281a0: 00002aaaaacc54e8 00002aaac9738c55
0x00000000402281b0: 00002aaaabd0d498 0000000000000001
0x00000000402281c0: 0000000040112400 00002aaaaca562a9
0x00000000402281d0: 0000000040228270 00002aaaaca562a9
0x00000000402281e0: 0000000040112400 0000000040228560
0x00000000402281f0: 0000000040228200 00002aaaab82f2d1
0x0000000040228200: 00000000402282f0 00002aaaab82fc32
0x0000000040228210: 0000000000000001 0000000040112400
0x0000000040228220: 0000000040228270 0000000040228568
0x0000000040228230: 0000000000000000 0000000000000000
0x0000000040228240: 0000000040112400 00000000ffffffff
0x0000000040228250: 00002aaacc009700 00002aaaaacc4bc0
0x0000000040228260: 00002aaaaacc54e8 00002aaac9738c55
0x0000000040228270: 0000000000000000 00000000402288c0
0x0000000040228280: 0000000040228370 00002aaaab2f443f
0x0000000040228290: 0000000000000003 0000000000000000
0x00000000402282a0: 0000000000000006 0000000000000008
0x00000000402282b0: 00000000860afcd9 00002aaaaaab3fb9
0x00000000402282c0: 00002aaa00001fa0 00000000402282f0
0x00000000402282d0: 00000000860afcd8 0000000040228460
0x00000000402282e0: 0000000040228478 00002aaaab540fe8
0x00000000402282f0: 0000000000000000 00002aaac915d558
0x0000000040228300: 000000004010a8c0 00002aaac97298a8
0x0000000040228310: 00002aaaab543970 00002aaac9728488
0x0000000040228320: 0000000500000000 00000001000000af
0x0000000040228330: 0000000000000000 000000004010a8c0
Instructions: (pc=0x00002aaaaaab41bd)
0x00002aaaaaab41ad: 2d 03 00 00 48 8b b5 10 ff ff ff 31 d2 45 31 d2
0x00002aaaaaab41bd: 48 8b 06 48 85 c0 0f 84 60 02 00 00 48 8b 9d 10
Stack: [0x000000004012b000,0x000000004022c000), sp=0x0000000040228140, free space=1012k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C [libc.so.6+0x10543f]
C [libdl.so.2+0x1104]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j java.lang.ClassLoader$NativeLibrary.load(Ljava/lang/String;) V+0
j java.lang.ClassLoader.loadLibrary0(Ljava/lang/Class;Ljava/io /File;)Z+300
j java.lang.ClassLoader.loadLibrary(Ljava/lang/Class;Ljava/lan g/String;Z)V+217
j java.lang.Runtime.loadLibrary0(Ljava/lang/Class;Ljava/lang/S tring;)V+54
j java.lang.System.loadLibrary(Ljava/lang/String;)V+7
j sun.security.action.LoadLibraryAction.run()Ljava/lang/Object ;+4
v ~StubRoutines::call_stub
j java.security.AccessController.doPrivileged(Ljava/security/P rivilegedAction;)Ljava/lang/Object;+0
j sun.nio.ch.Util.load()V+28
j sun.nio.ch.FileChannelImpl.<clinit>()V+29
j java.io.RandomAccessFile.getChannel()Ljava/nio/channels/File Channel;+22
j org.eclipse.core.runtime.internal.adaptor.Locker_JavaNio.loc k()Z+22
j org.eclipse.osgi.storagemanager.StorageManager.lock(Z)Z+53
j org.eclipse.osgi.storagemanager.StorageManager.open(Z)V+19
j org.eclipse.osgi.internal.baseadaptor.BaseStorage.initFileMa nager(Ljava/io/File;Ljava/lang/String;Z)Lorg/eclipse/osgi/st oragemanager/StorageManager;+23
j org.eclipse.osgi.internal.baseadaptor.BaseStorage.initialize (Lorg/eclipse/osgi/baseadaptor/BaseAdaptor;)V+131
j org.eclipse.osgi.baseadaptor.BaseAdaptor.initializeStorage() V+5
j org.eclipse.osgi.framework.internal.core.Framework.initializ e(Lorg/eclipse/osgi/framework/adaptor/FrameworkAdaptor;)V+10 7
j org.eclipse.osgi.framework.internal.core.Framework.<init>(Lorg/eclipse/osgi/framework/adaptor/FrameworkAdaptor;)V+49
j org.eclipse.osgi.framework.internal.core.OSGi.createFramewor k(Lorg/eclipse/osgi/framework/adaptor/FrameworkAdaptor;)Lorg /eclipse/osgi/framework/internal/core/Framework;+5
j org.eclipse.osgi.framework.internal.core.OSGi.<init>(Lorg/eclipse/osgi/framework/adaptor/FrameworkAdaptor;)V+7
j org.eclipse.core.runtime.adaptor.EclipseStarter.startup([Lja va/lang/String;Ljava/lang/Runnable;)Lorg/osgi/framework/Bund leContext;+107
j org.eclipse.core.runtime.adaptor.EclipseStarter.run([Ljava/l ang/String;Ljava/lang/Runnable;)Ljava/lang/Object;+34
j sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/refl ect/Method;Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/ Object;+0
j sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Objec t;[Ljava/lang/Object;)Ljava/lang/Object;+87
j sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/O bject;[Ljava/lang/Object;)Ljava/lang/Object;+6
j java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lan g/Object;)Ljava/lang/Object;+161
j org.eclipse.core.launcher.Main.invokeFramework([Ljava/lang/S tring;[Ljava/net/URL;)V+181
j org.eclipse.core.launcher.Main.basicRun([Ljava/lang/String;) V+107
j org.eclipse.core.launcher.Main.run([Ljava/lang/String;)I+4
j org.eclipse.core.launcher.Main.main([Ljava/lang/String;)V+10
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x00002aaac9129000 JavaThread "process reaper" daemon [_thread_in_native, id=3857]
0x00002aaac5156400 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=3855]
0x00002aaac5154800 JavaThread "CompilerThread1" daemon [_thread_blocked, id=3854]
0x00002aaac5152c00 JavaThread "CompilerThread0" daemon [_thread_blocked, id=3853]
0x00002aaac5151400 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=3852]
0x00002aaac512e400 JavaThread "Finalizer" daemon [_thread_blocked, id=3851]
0x00002aaac512d800 JavaThread "Reference Handler" daemon [_thread_blocked, id=3850]
=>0x0000000040112400 JavaThread "main" [_thread_in_native, id=3848]
Other Threads:
0x00002aaac5128c00 VMThread [id=3849]
0x00002aaac5158800 WatcherThread [id=3856]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 12288K, used 3140K [0x00002aaaafb20000, 0x00002aaab0870000, 0x00002aaab5070000)
eden space 10944K, 28% used [0x00002aaaafb20000, 0x00002aaaafe311e0, 0x00002aaab05d0000)
from space 1344K, 0% used [0x00002aaab05d0000, 0x00002aaab05d0000, 0x00002aaab0720000)
to space 1344K, 0% used [0x00002aaab0720000, 0x00002aaab0720000, 0x00002aaab0870000)
tenured generation total 27328K, used 0K [0x00002aaab5070000, 0x00002aaab6b20000, 0x00002aaabfb20000)
the space 27328K, 0% used [0x00002aaab5070000, 0x00002aaab5070000, 0x00002aaab5070200, 0x00002aaab6b20000)
compacting perm gen total 21248K, used 4417K [0x00002aaabfb20000, 0x00002aaac0fe0000, 0x00002aaac4f20000)
the space 21248K, 20% used [0x00002aaabfb20000, 0x00002aaabff70550, 0x00002aaabff70600, 0x00002aaac0fe0000)
No shared spaces configured.
Dynamic libraries:
40000000-40009000 r-xp 00000000 08:08 1541310 /home/hicham/java/jdk1.6.0_01/bin/java
40108000-4010a000 rwxp 00008000 08:08 1541310 /home/hicham/java/jdk1.6.0_01/bin/java
4010a000-4012b000 rwxp 4010a000 00:00 0 [heap]
4012b000-4012e000 ---p 4012b000 00:00 0
4012e000-4022c000 rwxp 4012e000 00:00 0
4022c000-4022d000 ---p 4022c000 00:00 0
4022d000-4032d000 rwxp 4022d000 00:00 0
4032d000-40330000 ---p 4032d000 00:00 0
40330000-4042e000 rwxp 40330000 00:00 0
4042e000-40431000 ---p 4042e000 00:00 0
40431000-4052f000 rwxp 40431000 00:00 0
4052f000-40532000 ---p 4052f000 00:00 0
40532000-40630000 rwxp 40532000 00:00 0
40630000-40633000 ---p 40630000 00:00 0
40633000-40731000 rwxp 40633000 00:00 0
40731000-40734000 ---p 40731000 00:00 0
40734000-40832000 rwxp 40734000 00:00 0
40832000-40835000 ---p 40832000 00:00 0
40835000-40933000 rwxp 40835000 00:00 0
40933000-40934000 ---p 40933000 00:00 0
40934000-40a34000 rwxp 40934000 00:00 0
40a34000-40a37000 ---p 40a34000 00:00 0
40a37000-40b35000 rwxp 40a37000 00:00 0
2aaaaaaab000-2aaaaaac5000 r-xp 00000000 08:07 1987141 /lib64/ld-2.6.so
2aaaaaac5000-2aaaaaac6000 rwxp 2aaaaaac5000 00:00 0
2aaaaaac6000-2aaaaaac7000 r-xp 2aaaaaac6000 00:00 0
2aaaaaac7000-2aaaaaac8000 rwxp 2aaaaaac7000 00:00 0
2aaaaaac8000-2aaaaaac9000 r-xs 00008000 08:08 688129 /home/hicham/java/eclipse/startup.jar
2aaaaaaf8000-2aaaaaaf9000 rwxp 2aaaaaaf8000 00:00 0
2aaaaaaf9000-2aaaaab00000 r-xp 00000000 08:08 1541849 /home/hicham/java/jdk1.6.0_01/jre/lib/amd64/native_threads/l ibhpi.so
2aaaaab00000-2aaaaac01000 ---p 00007000 08:08 1541849 /home/hicham/java/jdk1.6.0_01/jre/lib/amd64/native_threads/l ibhpi.so
2aaaaac01000-2aaaaac03000 rwxp 00008000 08:08 1541849 /home/hicham/java/jdk1.6.0_01/jre/lib/amd64/native_threads/l ibhpi.so
2aaaaac03000-2aaaaac04000 rwxp 2aaaaac03000 00:00 0
2aaaaac04000-2aaaaac0c000 rwxs 00000000 08:07 819968 /tmp/hsperfdata_hicham/3847
2aaaaacc4000-2aaaaacc5000 r-xp 00019000 08:07 1987141 /lib64/ld-2.6.so
2aaaaacc5000-2aaaaacc6000 rwxp 0001a000 08:07 1987141 /lib64/ld-2.6.so
2aaaaacc6000-2aaaaacdb000 r-xp 00000000 08:07 1987172 /lib64/libpthread-2.6.so
2aaaaacdb000-2aaaaaeda000 ---p 00015000 08:07 1987172 /lib64/libpthread-2.6.so
2aaaaaeda000-2aaaaaedb000 r-xp 00014000 08:07 1987172 /lib64/libpthread-2.6.so
2aaaaaedb000-2aaaaaedc000 rwxp 00015000 08:07 1987172 /lib64/libpthread-2.6.so
2aaaaaedc000-2aaaaaee0000 rwxp 2aaaaaedc000 00:00 0
2aaaaaee0000-2aaaaaee7000 r-xp 00000000 08:08 1541832 /home/hicham/java/jdk1.6.0_01/jre/lib/amd64/jli/libjli.so
2aaaaaee7000-2aaaaafe8000 ---p 00007000 08:08 1541832 /home/hicham/java/jdk1.6.0_01/jre/lib/amd64/jli/libjli.so
2aaaaafe8000-2aaaaafea000 rwxp 00008000 08:08 1541832 /home/hicham/java/jdk1.6.0_01/jre/lib/amd64/jli/libjli.so
2aaaaafea000-2aaaaafec000 r-xp 00000000 08:07 1987154 /lib64/libdl-2.6.so
2aaaaafec000-2aaaab1ec000 ---p 00002000 08:07 1987154 /lib64/libdl-2.6.so
2aaaab1ec000-2aaaab1ed000 r-xp 00002000 08:07 1987154 /lib64/libdl-2.6.so
2aaaab1ed000-2aaaab1ee000 rwxp 00003000 08:07 1987154 /lib64/libdl-2.6.so
2aaaab1ee000-2aaaab1ef000 rwxp 2aaaab1ee000 00:00 0
2aaaab1ef000-2aaaab336000 r-xp 00000000 08:07 1987148 /lib64/libc-2.6.so
2aaaab336000-2aaaab535000 ---p 00147000 08:07 1987148 /lib64/libc-2.6.so
2aaaab535000-2aaaab539000 r-xp 00146000 08:07 1987148 /lib64/libc-2.6.so
2aaaab539000-2aaaab53a000 rwxp 0014a000 08:07 1987148 /lib64/libc-2.6.so
2aaaab53a000-2aaaab540000 rwxp 2aaaab53a000 00:00 0
2aaaab540000-2aaaabbbb000 r-xp 00000000 08:08 1541866 /home/hicham/java/jdk1.6.0_01/jre/lib/amd64/server/libjvm.so
2aaaabbbb000-2aaaabcbc000 ---p 0067b000 08:08 1541866 /home/hicham/java/jdk1.6.0_01/jre/lib/amd64/server/libjvm.so
2aaaabcbc000-2aaaabde8000 rwxp 0067c000 08:08 1541866 /home/hicham/java/jdk1.6.0_01/jre/lib/amd64/server/libjvm.so
2aaaabde8000-2aaaabe23000 rwxp 2aaaabde8000 00:00 0
2aaaabe55000-2aaaabed7000 r-xp 00000000 08:07 1987156 /lib64/libm-2.6.so
2aaaabed7000-2aaaac0d6000 ---p 00082000 08:07 1987156 /lib64/libm-2.6.so
2aaaac0d6000-2aaaac0d7000 r-xp 00081000 08:07 1987156 /lib64/libm-2.6.so
2aaaac0d7000-2aaaac0d8000 rwxp 00082000 08:07 1987156 /lib64/libm-2.6.so
2aaaac0d8000-2aaaac0df000 r-xp 00000000 08:07 1987176 /lib64/librt-2.6.so
2aaaac0df000-2aaaac2df000 ---p 00007000 08:07 1987176 /lib64/librt-2.6.so
2aaaac2df000-2aaaac2e0000 r-xp 00007000 08:07 1987176 /lib64/librt-2.6.so
2aaaac2e0000-2aaaac2e1000 rwxp 00008000 08:07 1987176 /lib64/librt-2.6.so
2aaaac2e1000-2aaaac2f6000 r-xp 00000000 08:07 1987158 /lib64/libnsl-2.6.so
2aaaac2f6000-2aaaac4f5000 ---p 00015000 08:07 1987158 /lib64/libnsl-2.6.so
2aaaac4f5000-2aaaac4f6000 r-xp 00014000 08:07 1987158 /lib64/libnsl-2.6.so
2aaaac4f6000-2aaaac4f7000 rwxp 00015000 08:07 1987158 /lib64/libnsl-2.6.so
2aaaac4f7000-2aaaac4f9000 rwxp 2aaaac4f7000 00:00 0
2aaaac4f9000-2aaaac503000 r-xp 00000000 08:07 1987164 /lib64/libnss_files-2.6.so
2aaaac503000-2aaaac702000 ---p 0000a000 08:07 1987164 /lib64/libnss_files-2.6.so
2aaaac702000-2aaaac703000 r-xp 00009000 08:07 1987164 /lib64/libnss_files-2.6.so
2aaaac703000-2aaaac704000 rwxp 0000a000 08:07 1987164 /lib64/libnss_files-2.6.so
2aaaac704000-2aaaac711000 r-xp 00000000 08:08 1541842 /home/hicham/java/jdk1.6.0_01/jre/lib/amd64/libverify.so
2aaaac711000-2aaaac810000 ---p 0000d000 08:08 1541842 /home/hicham/java/jdk1.6.0_01/jre/lib/amd64/libverify.so
2aaaac810000-2aaaac813000 rwxp 0000c000 08:08 1541842 /home/hicham/java/jdk1.6.0_01/jre/lib/amd64/libverify.so
2aaaac813000-2aaaac83b000 r-xp 00000000 08:08 1541860 /home/hicham/java/jdk1.6.0_01/jre/lib/amd64/libjava.so
2aaaac83b000-2aaaac93b000 ---p 00028000 08:08 1541860 /home/hicham/java/jdk1.6.0_01/jre/lib/amd64/libjava.so
2aaaac93b000-2aaaac942000 rwxp 00028000 08:08 1541860 /home/hicham/java/jdk1.6.0_01/jre/lib/amd64/libjava.so
2aaaac942000-2aaaac950000 r-xp 00000000 08:08 1541847 /home/hicham/java/jdk1.6.0_01/jre/lib/amd64/libzip.so
2aaaac950000-2aaaaca52000 ---p 0000e000 08:08 1541847 /home/hicham/java/jdk1.6.0_01/jre/lib/amd64/libzip.so
2aaaaca52000-2aaaaca55000 rwxp 00010000 08:08 1541847 /home/hicham/java/jdk1.6.0_01/jre/lib/amd64/libzip.so
2aaaaca55000-2aaaaccc6000 rwxp 2aaaaca55000 00:00 0
2aaaaccc6000-2aaaafa56000 rwxp 2aaaaccc6000 00:00 0
2aaaafa56000-2aaaafa60000 rwxp 2aaaafa56000 00:00 0
2aaaafa60000-2aaaafb16000 rwxp 2aaaafa60000 00:00 0
2aaaafb20000-2aaab0870000 rwxp 2aaaafb20000 00:00 0
2aaab0870000-2aaab5070000 rwxp 2aaab0870000 00:00 0
2aaab5070000-2aaab6b20000 rwxp 2aaab5070000 00:00 0
2aaab6b20000-2aaabfb20000 rwxp 2aaab6b20000 00:00 0
2aaabfb20000-2aaac0fe0000 rwxp 2aaabfb20000 00:00 0
2aaac0fe0000-2aaac4f20000 rwxp 2aaac0fe0000 00:00 0
2aaac4f20000-2aaac4f27000 rwxp 2aaac4f20000 00:00 0
2aaac4f27000-2aaac4f4a000 rwxp 2aaac4f27000 00:00 0
2aaac4f4a000-2aaac4f58000 rwxp 2aaac4f4a000 00:00 0
2aaac4f58000-2aaac4fa0000 rwxp 2aaac4f58000 00:00 0
2aaac4fa0000-2aaac4fab000 rwxp 2aaac4fa0000 00:00 0
2aaac4fab000-2aaac4fca000 rwxp 2aaac4fab000 00:00 0
2aaac4fca000-2aaac4fd9000 rwxp 2aaac4fca000 00:00 0
2aaac4fd9000-2aaac5021000 rwxp 2aaac4fd9000 00:00 0
2aaac5021000-2aaac502c000 rwxp 2aaac5021000 00:00 0
2aaac502c000-2aaac504c000 rwxp 2aaac502c000 00:00 0
2aaac504c000-2aaac5174000 rwxp 2aaac504c000 00:00 0
2aaac5174000-2aaac52ef000 r-xs 02c75000 08:08 1541040 /home/hicham/java/jdk1.6.0_01/jre/lib/rt.jar
2aaac52ef000-2aaac9119000 r-xp 00000000 08:07 4628967 /usr/lib/locale/locale-archive
2aaac9119000-2aaac9719000 rwxp 2aaac9119000 00:00 0
2aaac9719000-2aaac9727000 r-xs 000c8000 08:08 720944 /home/hicham/java/eclipse/plugins/org.eclipse.osgi_3.2.2.R32 x_v20070118.jar
2aaac9727000-2aaac973a000 r-xp 00000000 08:08 1541836 /home/hicham/java/jdk1.6.0_01/jre/lib/amd64/libnet.so
2aaac973a000-2aaac983b000 ---p 00013000 08:08 1541836 /home/hicham/java/jdk1.6.0_01/jre/lib/amd64/libnet.so
2aaac983b000-2aaac983e000 rwxp 00014000 08:08 1541836 /home/hicham/java/jdk1.6.0_01/jre/lib/amd64/libnet.so
2aaacc000000-2aaacc112000 rwxp 2aaacc000000 00:00 0
2aaacc112000-2aaad0000000 ---p 2aaacc112000 00:00 0
7fff94c4b000-7fff94c82000 rwxp 7fff94c4b000 00:00 0 [stack]
ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vdso]
VM Arguments:
jvm_args: -Xms40m -Xmx256m
java_command: /home/hicham/java/eclipse/startup.jar -os linux -ws gtk -arch x86_64 -launcher /home/hicham/java/eclipse/eclipse -name Eclipse -showsplash 600 -exitdata 158009 -vm /home/hicham/java/jdk1.6.0_01/bin/java -vmargs -Xms40m -Xmx256m -jar /home/hicham/java/eclipse/startup.jar
Launcher Type: SUN_STANDARD
Environment Variables:
JAVA_HOME=/home/hicham/java/jdk1.6.0_01
PATH=/usr/lib64/qt-3.3/bin:/usr/kerberos/bin:/home/hicham/ja va/jdk1.6.0_01/bin:/usr/lib64/ccache:/usr/local/bin:/usr/bin :/bin:/home/hicham/bin
USERNAME=hicham
LD_LIBRARY_PATH=/home/hicham/java/jdk1.6.0_01/jre/lib/amd64/ server:/home/hicham/java/jdk1.6.0_01/jre/lib/amd64:/home/hic ham/java/jdk1.6.0_01/jre/../lib/amd64:/usr/lib64/firefox-2.0 .0.4
SHELL=/bin/bash
DISPLAY=:0
Signal Handlers:
SIGSEGV: [libjvm.so+0x5f49c0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGBUS: [libjvm.so+0x5f49c0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGFPE: [libjvm.so+0x4b2fa0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGPIPE: [libjvm.so+0x4b2fa0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGILL: [libjvm.so+0x4b2fa0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGUSR1: SIG_DFL, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGUSR2: [libjvm.so+0x4b51a0], sa_mask[0]=0x00000000, sa_flags=0x10000004
SIGHUP: [libjvm.so+0x4b4ae0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGINT: [libjvm.so+0x4b4ae0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGQUIT: [libjvm.so+0x4b4ae0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGTERM: [libjvm.so+0x4b4ae0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
--------------- S Y S T E M ---------------
OS:Fedora release 7 (Moonshine)
uname:Linux 2.6.21-1.3228.fc7 #1 SMP Tue Jun 12 14:56:37 EDT 2007 x86_64
libc:glibc 2.6 NPTL 2.6
rlimit: STACK 10240k, CORE 0k, NPROC 8188, NOFILE 1024, AS infinity
load average:1.69 1.17 0.68
CPU:total 2 em64t ht
Memory: 4k page, physical 1026668k(171704k free), swap 0k(0k free)
vm_info: Java HotSpot(TM) 64-Bit Server VM (1.6.0_01-b06) for linux-amd64, built on Mar 14 2007 01:18:38 by "java_re" with gcc 3.2.2 (SuSE Linux)
--------------050004080506030904030903--
Re: eclipse 3.2.2 crashes using java 1.6 [message #217908 is a reply to message #216389] |
Mon, 25 June 2007 16:42  |
Originally posted by: wharley.bea.com
"hicham" <hicham.dev@menara.ma> wrote in message
news:f53m83$s7b$1@build.eclipse.org...
> hello
> [etc.]
Is there anything in the Eclipse error log?
When does it crash (on startup, on some action, ...)?
What version of Eclipse are you using (I see that it's 3.2.2, but are you
sure it's a 64-bit Linux build)?
Did it used to work? If so, did you change anything before it started
crashing?
Does it crash all the time, or only sometimes?
Current Time: Fri Jul 18 16:44:59 EDT 2025
Powered by FUDForum. Page generated in 0.09124 seconds
