latest code = NPE [message #20969] |
Mon, 06 October 2008 16:34  |
I have the latest Ganymede release of eclipse and installed latest MTJ.
When I try to get the devices from latest WTK, MTJ throws an NPE
org.eclipse.mtj.core.importer.JavadocDetector$GenericLocalFS Search.searchForLibraryDoc(Unknown
Source)
org.eclipse.mtj.core.importer.JavadocDetector$GenericLocalFS Search.searchForJavaDoc(Unknown
Source)
at org.eclipse.mtj.core.importer.JavadocDetector.detectJavadoc( Unknown
Source)
org.eclipse.mtj.core.importer.LibraryImporter.createLibraryF or(Unknown
Source)
org.eclipse.mtj.toolkit.uei.UEIDeviceImporter.getDeviceClass path(Unknown
Source)
at org.eclipse.mtj.toolkit.uei.UEIDeviceImporter.createDevice(U nknown
Source)
at org.eclipse.mtj.toolkit.uei.UEIDeviceImporter.addUEIDevices( Unknown
Source)
org.eclipse.mtj.toolkit.uei.UEIDeviceImporter.getMatchingDev ices(Unknown
Source)
at org.eclipse.mtj.core.model.device.DeviceFactory.addDevices(U nknown
Source)
Source)
at org.eclipse.mtj.core.model.device.DeviceFactory.findDevices( Unknown
Source)
org.eclipse.mtj.ui.internal.devices.DeviceImportWizardPage$9 .run(Unknown
Source)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:121)
Re: latest code = NPE [message #567266 is a reply to message #20969] |
Mon, 06 October 2008 20:29  |
hi,
can you send us some additional information? it will help to analyze the
problem.
which OS are you using? did you MTJ RC1 or some other nightly build? did
the NPE always happens or it works sometimes? which wtk version are you
using?
thanks
gustavo
Re: latest code = NPE [message #567284 is a reply to message #20969] |
Tue, 07 October 2008 09:38  |
i saw two scenarios where this issue might happen.
on windows, the firewall is blocking the execution of the wtk emulator.
you need to go to windows firewall and add the emulator as as exception.
on linux, wtk emulator is without execution permission.
can you please double check if this solves the issue?
Re: latest code = NPE [message #567337 is a reply to message #20974] |
Thu, 09 October 2008 15:37  |
Gustavo de Paula wrote:
> hi,
> problem.
> using?
> thanks
> gustavo
Thge problem is with the device management when I try to add WTK to my
list of SDKs. I am on windows XP SP3 and I am using the latest stable
version of java, eclipse and mtj. The NPE occurs everytime I try to
import the WTK or the Sprint WTK. Every other SDK works fine.
Re: latest code = NPE [message #567353 is a reply to message #20988] |
Thu, 09 October 2008 15:54  |
>> hi,
>> the problem.
>> did the NPE always happens or it works sometimes? which wtk version
>> are you using?
>> thanks
>> gustavo
Correction, sprint was detected just fine along with every other SDK. So
the problem is only with wtk.
Re: latest code = NPE [message #567374 is a reply to message #20992] |
Thu, 09 October 2008 16:54  |
i never used the sprint sdk. i will download it to give a try
i assume that it is UEI SDK. can you check if there is a emulator file
inside the emulator's bin folder? if there is is this file blocked by
windows firewall or there is an exception to it? you can check that in
"control panel" -> windows firewall
thanks
gustavo
Re: latest code = NPE [message #567404 is a reply to message #20995] |
Sat, 11 October 2008 06:20  |
> thanks
> gustavo
as I said Sprint work OK. There is no firewall, I have switched it
off. Its just the WTK that doesn't work. I have just now tried the
version 3 early access and that too throws an NPE
FUDForum. Page generated in 0.04863 seconds
