Home » Eclipse Projects » GEF » Automatically Select All
Automatically Select All [message #216012] Fri, 12 May 2006 05:32 Go to next message
i'm writing a plugin with an editor using GEF. I also added an Entry to
the Eclipse menubar which is visible when my editor is active. The menu
should contain an entry called "Delete All" which should (as the name
implies ;) ) delete the whole content of the editor. My question is: How
can i automatically select the whole content that the editor displays and
how can i invoke the right edit policies afterwards?
Or is there an easier way to achieve this?
Thanks in advance for your help.
regards,
Thomas
Re: Automatically Select All [message #216349 is a reply to message #216012] Wed, 17 May 2006 06:26 Go to previous messageGo to next message
*bump*
does anybody have a solution for it?
Thomas Buchmann wrote:
> Hello,
> and how can i invoke the right edit policies afterwards?
> regards,
> Thomas
Re: Automatically Select All [message #216600 is a reply to message #216349] Mon, 22 May 2006 10:02 Go to previous message
Originally posted by: marguu.libero.it
you can use the default SelectAllAction. I don't have my code here, but if
you have other problems with it write me!
BYE
Previous Topic:copy&paste
Next Topic:matisse style layout
Current Time: Mon Jul 21 21:22:00 EDT 2025
Powered by FUDForum. Page generated in 0.24464 seconds
