Preliminary EAR support [message #20937] |
Wed, 24 June 2009 12:10 |
I have added some preliminary EAR support that will allow you to run EAR
and WAR projects in the appserver from Eclipse, by right clicking on the
projects and select run on server.
The wars will be deployed in the path specified in the application.xml
file in the EAR project.
The support is included in the latest build in the development update
site at http://q4e.googlecode.com/svn/trunk/updatesite-dev
Caveats:
- to have Eclipse recognize the application.xml file it needs to be in
/META-INF/application.xml, so you'd need to add to the pom' EAR plugin
configuration so Maven generates the application.xml in the right place
<configuration>
<generatedDescriptorLocation>${basedir}/META-INF</generatedDescriptorLocation >
- WAR projects need to be open in the workspace to be deployed. If the
EAR depends on WARs in the repository they are not available for deployment.
Hope you find it useful!
FUDForum. Page generated in 0.23361 seconds
