Home » Language IDEs » C / C++ IDE (CDT) » eclipse on suse linux 7.0
eclipse on suse linux 7.0 [message #20931] Sat, 23 February 2002 00:17 Go to next message
Originally posted by: pwgrant.cssi-fl.com
When installed (uncompressed) I get the error cannot find class
java/lang/thread. I can compile java ok from a terminal window (thought
it sounds unrelated. I can't find a java/lang let alone a
java/lang/thread. Any ideas?
patrick
pwgrant@cssi-fl.com
Re: eclipse on suse linux 7.0 [message #24409 is a reply to message #20931] Tue, 16 April 2002 14:21 Go to previous messageGo to next message
Originally posted by: martin.thecla.freserve.co.uk
Do you have java installed and in the PATH?
Martin
"patrick grantham" <pwgrant@cssi-fl.com> wrote in message
news:3C7725F3.6060604@cssi-fl.com...
> patrick
> pwgrant@cssi-fl.com
Re: eclipse on suse linux 7.0 [message #24450 is a reply to message #20931] Tue, 16 April 2002 15:19 Go to previous message
Originally posted by: Adam_Kiezun.oti.com
most likely unrelated but, according to the plan,
eclipse is not supported on suse below 7.3
http://www.eclipse.org/eclipse/eclipse_project_plan_2_0_rev0 326.html
the plan says 'untested'
but, like i said - probably has nothing to do with the problem you see
a.
Previous Topic:wooohoooo !
Next Topic:makefile parser
Current Time: Sat Jul 12 22:50:10 EDT 2025
Powered by FUDForum. Page generated in 0.07557 seconds
