Is there any build for Galileo [message #20927] |
Wed, 24 June 2009 08:01  |
Is there any build for Galileo?
Current (200505051158) don't work
log:
Cannot complete the install because one or more required items could not
be found.
Software being installed: Eclipse IAM Dependency Viewer
0.9.0.200905051159 (org.eclipse.iam.feature.dependencyviewer.feature.group
0.9.0.200905051159)
Missing requirement: Eclipse IAM Dependency Viewer 0.9.0.200905051159
0.9.0.200905051159) requires 'com.ibm.icu [3.6.0,4.0.0)' but it could not
be found
Re: Is there any build for Galileo [message #20975 is a reply to message #20971] |
Tue, 30 June 2009 00:21  |
I'll install and test with Subclipse to see if I can find what is
causing this.
We usually test with Subversive (hosted at
http://eclipse.org/subversive) instead... maybe that will work for you
as a workaround?
Additionally, you would get the Import from Svn feature (installing the
Subsersive integration from IAM updte site).
Cheers!
BenH wrote:
> BenH wrote:
>> A couple of minutes ago I was able to install into a fresh Eclipse 3.5
>> from:
>> http://q4e.googlecode.com/svn/trunk/updatesite-iam/
>> And, this seems to have cured the Endless Rebuilding problem I posted
>> about last week. Hooray!! 8)
> Oh no, I spoke too soon! Its come back, but I did get a clue that may be
> valuable:
> The Endless Rebuilding may be an interaction with Subclipse. It showed
> up again right after I installed Subclipse 1.6.x into 3.5, and did a SVN
> update to test Subclipse. (Previously I used Subclipse 1.4.x too)
> Smells like some file modification times are being messed with?
> Abel, is there some svn property that might resolve this, svn:ignore or
> similar?
> Note my "target" folder shows as "unversioned" and subclipse doesnt
> allow me to set a SVN property on it.
> -Ben
Re: Is there any build for Galileo [message #569842 is a reply to message #20927] |
Wed, 24 June 2009 10:52  |
There is a version tested against RC4 announced on the dev list (update
site at http://q4e.googlecode.com/svn/trunk/p2-nightly/). Check the
installation instructions:
http://dev.eclipse.org/mhonarc/lists/iam-dev/msg00457.html
I am now testing that version with the final Galileo version and expect
tahat we can publish a fully compatible version later today, with a
propper categorization to make installing simpler.
> log:
> be found.
> 0.9.0.200905051159)
> be found
Re: Is there any build for Galileo [message #569932 is a reply to message #20932] |
Fri, 26 June 2009 03:27  |
>> log:
>> not be found.
>> 0.9.0.200905051159
>> 0.9.0.200905051159)
>> 0.9.0.200905051159
>> not be found
Any progress?
Re: Is there any build for Galileo [message #569951 is a reply to message #20951] |
Sat, 27 June 2009 08:07  |
We'll do a propper announcement later, but a new build compatible with
Galileo has been uploaded to:
Anybody using Eclipse 3.4 and upgrading to this build, note that it
requires EMF Compare 1.0, so the following update site must be added (no
need to check anything from it, dependencies will be resolved and pulled
by p2 automatically):
http://download.eclipse.org/modeling/emft/updates/releases/
Enjoy and share your feedback!
Jens Ohlsson wrote:
>> (update site at http://q4e.googlecode.com/svn/trunk/p2-nightly/).
>> Check the installation instructions:
>> expect tahat we can publish a fully compatible version later today,
>> with a propper categorization to make installing simpler.
>>> log:
>>> not be found.
>>> 0.9.0.200905051159
>>> 0.9.0.200905051159)
>>> 0.9.0.200905051159
>>> not be found
> Any progress?
Re: Is there any build for Galileo [message #570015 is a reply to message #20966] |
Mon, 29 June 2009 20:57  |
> from:
valuable:
The Endless Rebuilding may be an interaction with Subclipse. It showed up
similar?
Note my "target" folder shows as "unversioned" and subclipse doesnt allow
-Ben
Re: Is there any build for Galileo [message #570034 is a reply to message #20971] |
causing this.
as a workaround?
Cheers!
BenH wrote:
>> from:
> valuable:
> similar?
> -Ben
FUDForum. Page generated in 0.26025 seconds
