Home » Archived » BIRT » Why can't the viewer render a document to PDF?
Why can't the viewer render a document to PDF? [message #215669] Wed, 31 January 2007 08:14 Go to next message
Originally posted by: LeahStep.yahoo.com
Why doesn't the viewer support rendering a document as PDF?
Re: Why can't the viewer render a document to PDF? [message #215837 is a reply to message #215669] Wed, 31 January 2007 12:20 Go to previous messageGo to next message
It should. What version are you using?
When you hit the print button it will create a pdf document.
Jason
"Leah Stephens" <LeahStep@yahoo.com> wrote in message
news:bc074f05c518c4612fe5d62c0248f4c7$1@www.eclipse.org...
Re: Why can't the viewer render a document to PDF? [message #215893 is a reply to message #215837] Wed, 31 January 2007 13:00 Go to previous messageGo to next message
Originally posted by: leahStep.yahoo.com
I'm using 2.1
the initial call to the viewer was
/frameset?__document=mydocument.rptdocument
when I click on the print button, I get a new page with a 0 on it with the
following URL: frameset?__document=mydocument.rptdocument&__format=pdf
Leah
Re: Why can't the viewer render a document to PDF? [message #215911 is a reply to message #215893] Wed, 31 January 2007 13:25 Go to previous messageGo to next message
Can you try using the run mapping instead of the frameset?
Jason
"Leah Stephens" <leahStep@yahoo.com> wrote in message
news:3a20f0ed540b1113fef23ed04905b259$1@www.eclipse.org...
> I'm using 2.1
> Thanks
> Leah
Re: Why can't the viewer render a document to PDF? [message #215919 is a reply to message #215911] Wed, 31 January 2007 13:30 Go to previous messageGo to next message
Originally posted by: Carole_l_hargrave.yahoo.ca
If I manually set the URL to
run?__document=myreport.rptdocument&__format=pdf&__o verwrite=false
then it works.
The print button inside the viewer is calling frameset?
Leah
Re: Why can't the viewer render a document to PDF? [message #215941 is a reply to message #215919] Wed, 31 January 2007 14:53 Go to previous messageGo to next message
When I hit the print in 2.1.1 I get
http://localhost:8080/birt2.1.1/frameset?__report=test.rptde sign&sample=my+parameter&__format=pdf
And it formats correctly.
Any chance you can try 2.1.1?
Jason
"Carole Hargrave" <Carole_l_hargrave@yahoo.ca> wrote in message
news:b3bc66441c0d20eb96929c513d8c72e5$1@www.eclipse.org...
> then it works.
> Leah
Re: Why can't the viewer render a document to PDF? [message #215949 is a reply to message #215941] Wed, 31 January 2007 15:11 Go to previous messageGo to next message
I'm sorry, I am running it on 2.1.1.
I've also tried it on 2.2M4 (installed on same server).
I am using Sybase EAServer 5.3 JDK1.4.2
Also, I'm trying to Render the rptdocument to PDF - not the rptdesign.
Carole
Re: Why can't the viewer render a document to PDF? [message #215972 is a reply to message #215949] Wed, 31 January 2007 16:57 Go to previous message
Can you log a bugzilla entry with the log file?
Jason
news:57e8f14d51ed2b4cc5b8db176f5a54b6$1@www.eclipse.org...
> Carole
Previous Topic:pass date parameter to drill-through report - formatting problem
Next Topic:Setting the width of a grid column with JavaScript?
Current Time: Tue Jul 22 12:11:48 EDT 2025
Powered by FUDForum. Page generated in 0.05803 seconds
