Home » Archived » IAM (Eclipse Integration for Apache Maven) » PluginDescriptor not found
PluginDescriptor not found [message #20909] Fri, 05 June 2009 17:49 Go to next message
Hello all,
I have created a custom mojo that I have deployed to a local
artifactory repository and am using in a project. The plugin executes as
expected from the maven command line; however, when I try to execute the
plugin from the Eclipse/IAM integration it bombs with the following
exception:
"The PluginDescriptor for the plugin
edu.letu.maven.plugin:ddl-post-processor was not found. Should have been
in realm:
ClassRealm[/plugins/edu.letu.maven.plugin:ddl-post-processor :1.0-SNAPSHOT@48/thread:Worker-10,
parent: null]"
I have my plugin deploying to the plugins repository in artifactory and
have verified that the plugin.xml file is in the proper place in the jar.
The m2 settings for my profile has a <pluginRepositories> element that
points to the local artifactory repo.
Is there anything I'm missing in my configuration or is this a bonafide
issue?
Thanks in advance for your help!
Dave
Re: PluginDescriptor not found [message #20914 is a reply to message #20909] Mon, 08 June 2009 06:35 Go to previous messageGo to next message
Hello David,
There should be no difference between your plug-in and other external
plugins.
However, if your mojo project is open in the workspace, IAM will try to
use the project (instead of the jar in your local or remote repositories).
In this case, try closing the plug-in project.
If this solves your problem, then probably there is a bug in using plugins
from the workspace.
Hope that helps!
Abel Muiño
David Wolff wrote:
> Hello all,
> exception:
> in realm:
> parent: null]"
> issue?
> Dave
Re: PluginDescriptor not found [message #20918 is a reply to message #20914] Mon, 08 June 2009 12:16 Go to previous messageGo to next message
When I closed down the mojo project in the eclipse workspace everything
ran smooth as butter. Should I report this as a bug?
Thanks!
Dave
Abel Muiño wrote:
> Hello David,
> plugins.
> from the workspace.
> Hope that helps!
> Abel Muiño
Re: PluginDescriptor not found [message #20922 is a reply to message #20918] Mon, 08 June 2009 15:00 Go to previous message
Happy to know!
Sure, go ahead.
If you could provide a simple test case, that would be very useful. A
patch even better :-)
> Thanks!
> Dave
> Abel Muiño wrote:
>> Hello David,
>> plugins.
>> to use the project (instead of the jar in your local or remote
>> repositories). In this case, try closing the plug-in project.
>> plugins from the workspace.
>> Hope that helps!
>> Abel Muiño
Abel Muiño
Re: PluginDescriptor not found [message #569749 is a reply to message #20909] Mon, 08 June 2009 06:35 Go to previous message
Hello David,
plugins.
from the workspace.
Hope that helps!
Abel Muiño
David Wolff wrote:
> Hello all,
> exception:
> in realm:
> parent: null]"
> issue?
> Dave
Re: PluginDescriptor not found [message #569773 is a reply to message #20914] Mon, 08 June 2009 12:16 Go to previous message
Thanks!
Dave
Abel Muiño wrote:
> Hello David,
> plugins.
> from the workspace.
> Hope that helps!
> Abel Muiño
Re: PluginDescriptor not found [message #569791 is a reply to message #20918] Mon, 08 June 2009 15:00 Go to previous message
Happy to know!
Sure, go ahead.
> Thanks!
> Dave
> Abel Muiño wrote:
>> Hello David,
>> plugins.
>> Hope that helps!
>> Abel Muiño
Abel Muiño
Previous Topic:PluginDescriptor not found
Next Topic:Is there any build for Galileo
Current Time: Fri Jul 18 00:24:21 EDT 2025
Powered by FUDForum. Page generated in 0.04984 seconds
