Home » Archived » Voicetools » how configured jdbc
how configured jdbc [message #20902] Tue, 21 October 2008 10:13 Go to next message
hello to everyone. Thanks for the help.
Now I've created a database sqlserver, I have defined a database, table
and database query module, to export my applications asks me to configure
the driver jdbc, but not how to do it.
I Tenf my database sqlserver on another machine.
I need help from someone who could guide me.
thanks
Alejandro Novoa
Re: how configured jdbc [message #20917 is a reply to message #20902] Thu, 23 October 2008 13:09 Go to previous messageGo to next message
Hi Alejandro--
You're going to need a jdbc driver which is specific to SQL Server. Luckily
for us, Microsoft gives one away:
http://msdn.microsoft.com/en-us/data/aa937724.aspx
As for configuring this, it's dependent on your system and setup, so you're
going to have to craft these arguments for yourself. Also, to complicate
things, the syntax of the arguments is dependent of the particular jdbc
driver you're using. This being said, one of the pages in the MS
documentation talks about just this:
http://msdn.microsoft.com/en-us/library/ms378428(SQL.90).aspx
I think this will get you started. Good luck,
Randy
OpenMethods
On 10/21/08 9:13 AM, in article
26aab6be73d96ad8690b4b38290b678a$1@www.eclipse.org, "Alejandro Novoa"
> thanks
> Alejandro Novoa
Re: how configured jdbc (solved) [message #20921 is a reply to message #20917] Tue, 28 October 2008 10:44 Go to previous message
Randy thanks for your response, it has worked perfectly. and also
important that it is necessary to put the driver in the folder
Dependencies of the project.
Re: how configured jdbc [message #577700 is a reply to message #20902] Thu, 23 October 2008 13:09 Go to previous message
Hi Alejandro--
Randy
OpenMethods
> thanks
> Alejandro Novoa
Re: how configured jdbc (solved) [message #577720 is a reply to message #20917] Tue, 28 October 2008 10:44 Go to previous message
Previous Topic:Installing VTP3.0 M5
Next Topic:How to make a "Custom Integration" node?
Current Time: Tue Sep 09 23:52:42 EDT 2025
Powered by FUDForum. Page generated in 0.03198 seconds
