Update problems, Eclipse 3.2.2 [message #215354] |
Wed, 13 June 2007 01:47 |
Originally posted by: alvaro_gmj.yahoo.com.ar
Hi everybody,
I've been using Eclipse for a while, for PHP, Java and some C.
Yesterday I tried to add some plug-ins and I got the error "Update operation
failed", below is the .log file.
My installation was very "dirty", so I download again the program (version
3.2.2) and installed it, removing .eclipse and the .metadata folders, but I
got the same error every single time.
It's also strange that the error pop-ups always when the program has
downloaded ~75KB.
So, any ideas?
This is my .log file
!SESSION 2007-06-12
22:30:46.528 -----------------------------------------------
eclipse.buildId=M20070212-1330
java.version=1.6.0_01
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=es_UY
Command-line arguments: -os linux -ws gtk -arch x86
!ENTRY org.eclipse.update.core 4 0 2007-06-12 22:32:44.064
!MESSAGE Error
retrieving "plugins/com.ibm.icu34.data.update_3.4.5.v20070417_2007e.jar ".
[error in opening zip file]
!STACK 0
java.util.zip.ZipException: error in opening zip file
at java.util.zip.ZipFile.open(Native Method)
at java.util.zip.ZipFile.<init>(ZipFile.java:114)
at java.util.jar.JarFile.<init>(JarFile.java:133)
at java.util.jar.JarFile.<init>(JarFile.java:112)
org.eclipse.update.internal.jarprocessor.JarProcessor.proces sJar(JarProcessor.java:285)
org.eclipse.update.internal.core.FeaturePackagedContentProvi der.retrieveLocalJar(FeaturePackagedContentProvider.java:256 )
org.eclipse.update.internal.core.FeaturePackagedContentProvi der.getPluginEntryArchiveReferences(FeaturePackagedContentPr ovider.java:179)
org.eclipse.update.internal.operations.UpdateUtils.downloadF eatureContent(UpdateUtils.java:628)
org.eclipse.update.internal.ui.wizards.InstallWizard2.downlo ad(InstallWizard2.java:428)
at org.eclipse.update.internal.ui.wizards.InstallWizard2.access $
(InstallWizard2.java:399)
org.eclipse.update.internal.ui.wizards.InstallWizard2$3.run( InstallWizard2.java:352)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
!ENTRY org.eclipse.core.runtime 8 1 2007-06-12 22:33:02.254
!MESSAGE
Thanks in advance and I'm sorry that my first post is a cry for help :-)
Re: Update problems, Eclipse 3.2.2 [message #215436 is a reply to message #215354] |
Wed, 13 June 2007 11:25 |
Álvaro,
Did you install to a new location? Did you trying running with
eclipse.exe -clean? The configuration directory can have a mess of
stuff in it too. The only file that must be in that folder is the
config.ini and the rest is cached information...
Álvaro G. Martínez wrote:
> Hi everybody,
> downloaded ~75KB.
> So, any ideas?
> !SESSION 2007-06-12
> !MESSAGE Error
> !STACK 0
> at
> at
> at
> at
> at
> at
> !MESSAGE
FUDForum. Page generated in 0.04990 seconds
